Boot From an SD Card / USB Stick / SATA drive
Booting your system from an external storage device such as an SD card, a USB stick or a SATA drive might be useful for some use cases.
- For offline and/or isolated systems that have no other means of installing or upgrading their system.
- For resource-scarce systems or systems that do not provide internal storage
- For development and testing environments which lack a more efficient setup (see Boot from a TFTP/NFS Server)
For (1), Toradex provides the Toradex Easy Installer as well as certain Recovery Modes, whereas (2) is commonly addressed with the NAND-based internal storage that all modules are equipped with. Note that removable storage devices may still be used to provide images to be installed into an already running system (e.g. our Toradex Easy Installer) and as additional storage. This is not considered booting from an external device. Nonetheless, booting from these media might still be desirable in some development and tesing environments or in exceptional cases. This article describes how to proceed.
caution
It is recommended to use SD booting only during development also because normal SD cards aren't reliable for long-term usage. For a simple installation of bootable images please use our Toradex Easy Installer where available.
Requirements
In order to boot from an SD card (hereafter also valid for a USB stick) you need:
- U-Boot running on your module. If this is not the case, please use the Toradex Easy Installer to install a running image first. Alternatively, if not (yet) available for your particular module revert to using the Legacy Update Procedure as outlined in the following table
- An SD card with two partitions. The first holding a FAT filesystem to host the kernel image and device trees, the second holding an ext4 (ext3 on downstream T20/T30) filesystem to hold the rootfs
Procedure
There are two ways to prepare the SD card:
- Using the images provided by Toradex
- Using the wic files as generated by an Angstrom Distribution/OpenEmbedded/Yocto Project build
The second option is faster, but it requires that you build the images first using the OpenEmbedded build system. Use it only if you are actually modifying or debugging the images.
Using Toradex Images
Use your preferred partitioning tool to create the mentioned partitions on your SD card. The size will depend on your module and images, but 100-500MB and 1-2GB should suffice in most cases. The order of the partitions is important since U-boot will look for the kernel in the first, and for the rootfs in the second one.
sudo parted -s /dev/sd? mklabel gpt mkpart primary fat32 1MiB 100MiB mkpart ext4 100MiB 2000MiB name 1 boot name 2 rootfs
sudo mkfs.fat -n boot /dev/sd?1 && sudo mkfs.ext4 -L rootfs /dev/sd?2
sudo lsblk /dev/sd? -o NAME,FSTYPE,LABEL,PARTLABEL (to verify)
Here, sd?
is the device corresponding to the SD card (check yours by looking at dmesg
after plugging the SD to your computer or using the lsblk
command). We have named the partitions boot and rootfs, but you can name them at will. Do not forget to mount the partitions afterwards to be able to access them: sudo mount -L boot /mnt/boot; sudo mount -L rootfs /mnt/rootfs
Now you need to copy the kernel image and the device trees into the first partition, and the rootfs into the second. To do this, first download an image for the Toradex Easy Installer corresponding to your module and look inside for the bootfs and the rootfs. These are named xxx-Image.bootfs.tar.xz and xxx-Image.rootfs.tar.xz. Simply untar each of them into the first and second partition respectively.
sudo tar xf Colibri-iMX6_LXDE-Image.bootfs.tar.xz --no-same-owner -C /mnt/boot
sudo tar xf Colibri-iMX6_LXDE-Image.rootfs.tar.xz -C /mnt/rootfs
The Colibri iMX6 module has been used as an example. Alternatively, if you have a legacy image, you will find the boot files in the <module-name>_bin/
folder (you only need the zImage and the device tree for your module, remember downstream T20/T30 do not yet use a device tree), and the rootfs in the rootfs
folder. Copy them to the partitions as follows:
sudo cp -L colibri-imx6_bin/{zImage,imx6dl-colibri-eval-v3.dtb} /mnt/boot
sudo cp -r rootfs/* /mnt/rootfs
Finally, unmount the partitions with sudo umount /mnt/{boot,rootfs}
, insert the SD card into (one of) the carrier board slot(s) and boot your module entering U-boot (by hitting any key in the early boot screen). At the U-boot prompt you can check that your partitions are recognized with mmc dev 1; mmc part
(where the number may be 0 for non-eMMC modules and 1 or 2 on Apalis depending on the particular slot used). You should see the names you gave them during the partitioning process. You can now boot with run sdboot
, run usb_boot
or run sata_boot
depending on the media you are using.
Using wic Files
The OpenEmbedded build system supports the generation of wic images that can be directly burned to an SD card. By default, this feature is enabled in all our images since release 2.8b4 (on older releases only NXP i.MX modules support it). Thus, if you are building your own images from the Toradex repositories, you can find the corresponding wic image after a build in the deploy/images/name-of-the-board/
folder of your OpenEmbedded tree. The image is compressed and named xxx.wic.gz
(e.g. Console-image-colibri-imx6.wic.gz). Decompress it first to get the original wic image and burn it directly to your SD card using e.g. the dd
utility.
gzip -d xxx.wic.gz
sudo dd if=xxx.wic of=/dev/sd-card-device bs=4M
Or in one go:
zcat xxx.wic.gz | sudo dd of=/dev/sd-card-device bs=4M
where sd-card-device
is the name of the Linux device exposing the SD card (you can find it using lsblk
or looking at the output of dmesg
after plugging the card). Move the SD card to your carrier board slot, turn on your module and quickly trigger the U-boot console (by pressing any key within the first 2 seconds). From there, you can boot from the external media by executing in console run sdboot
, run usb_boot
or run sata_boot
