Toradex Easy Installer is a tool that enables you to flash an OS image to the Computer on Module with a few clicks and very easily. It comes pre-installed from factory for seamless out-of-the-box and production programming experiences.
In this module you will:
For this lesson:
Press the on/off switch (SW7):
You should see the Toradex Easy Installer displayed on the monitor attached to the VGA port of the Colibri Evaluation Board. Images available for download are listed. If none are currently shown, check that the Ethernet cable is connected and press "r" to refresh.
As observed in the screenshot above, the IP address in the example is 10.22.1.59
Warning: Make sure you take note of your board's IP address, as highlighted in the picture. You will need it for the next lessons. The /24
at the end is just the ip mask, please disregard it. To use ssh, stick to the default port 22.
Your module should have come with the Toradex Easy Installer pre-installed.
If this isn't the case, you can follow the link below to deploy the Toradex Easy Installer to the module before proceeding:
Loading Toradex Easy Installer
Notice that there are two types of images for Torizon. You will use the one that provides the best out-of-the-box user experience:
TorizonCore with evaluation containers
: to provide the best out-of-the-box experience, this image comes with Portainer, a graphical container manager, pre-installed. We'll use this image on the Quickstart Guide and you will learn more about Portainer in the next lessons.TorizonCore
: this image does not have any evaluation containers pre-installed. It is best suitable for later steps of development. For instance, once you start to customize the TorizonCore base image using tools as the TorizonCore Builder Tool, you'll most likely want to use the TorizonCore
image.To install Torizon use the connected keyboard arrow key buttons to navigate and select the latest version of TorizonCore with evaluation containers
, press i
to install and Enter
to confirm:
Note: While executing this step make sure your board is connected to the internet and connection is established successfully.
After the Image Installed message pops-up, select the Power off option to shut down the system.
