Installing the Operating System - Colibri Evaluation Board
Your progress
Toradex Easy Installer is a tool that enables you to flash an OS image to the Computer on Module with a few clicks and very easily. It comes pre-installed from factory for seamless out-of-the-box and production programming experiences.
In this module you will:
  • Power on your system.
  • Use the Toradex Easy Installer graphical user interface to flash Torizon.
Typographic Conventions
For this lesson:
  • Have all cables connected and setup
Press the on/off switch (SW7):
  • On/off switch
    On/off switch
You should see the Toradex Easy Installer displayed on the monitor attached to the VGA port of the Colibri Evaluation Board. Images available for download are listed. If none are currently shown, check that the Ethernet cable is connected and press "r" to refresh.
  • Toradex Easy Installer
Note: The /24 at the end is just the ip mask. To use ssh, stick to the default port 22.
Warning: Make sure you take note of your board's IP address, as highlighted in the picture, you will need it for the next lessons.
If your module doesn't have the Toradex Easy Installer
Your module should have come with the Toradex Easy Installer pre-installed.
If this isn't the case, you can follow the link below to deploy the Toradex Easy Installer to the module before proceeding:
Loading Toradex Easy Installer
To install Torizon use the connected keyboard arrow key buttons to navigate and select the latest version of TorizonCore with evaluation containers.
Due to differences in the revisions of NXP i.MX 8X SoC, different versions of Colibri iMX8X require different software. Examine the label on the Computer on Module to find its version:
  • Find the Version of your Colibri iMX8X
Then, on the Toradex Easy Installer, select the corresponding image to your hardware version, press i to install and Enter to confirm:
  • Torizon Image for Colibri iMX8X V1.0B
  • Torizon Image for Colibri iMX8X V1.0C and Newer
Note: While executing this step make sure your board is connected to the internet and connection is established successfully.
Step 3
  • Torizon Installation
Step 4
After the Image Installed message pops-up, select the Power off option to shut down the system.
  • Installation finished
FAQ
How can I perform an offline install using the Toradex Easy Installer?
My company firewall does not allow the board to access the internet. How should I proceed?
What OS options do I have besides Torizon?
I don't have a display or monitor. Can I perform a headless install?
I had an issue following the steps from this lesson. How should I proceed?
