Linux Terminal and Basic Usage - Linux
Your progress
In this module you will:
  • Be introduced to PuTTY.
  • Communicate with the board through SSH.
  • Be introduced to basic Linux commands.
To facilitate the understanding of the lessons, check our typographic convention below:
Typographic Conventions
For this Getting Started Guide:
  • Linux Machine (We tested this guide on Ubuntu 18.04 LTS. However, it can work on other distributions.).
For this lesson:
  • Make sure the host computer and target device are connected to the same network.
  • Have your board's IP address, as seen in the last lesson.
Turn your board back on. Don't worry about the prompt that appears on the monitor connected to your board, for now.
In your host PC, install PuTTy:
$ sudo apt install putty
Open PuTTY and insert your board's IP address at the "Host Name (or IP address)" field. Leave the port configured as 22, which is the default port for the SSH server running on the board, and the other entries as they are. Click "Open" and accept the next dialog.
  • PuTTY Icon
    PuTTy Icon
  • PuTTY Configuration Window
    PuTTy Configuration by using board's IP
On the first connection, Putty will ask permission to add a new server's key entry to Putty's cache. Select "Accept".
  • Putty authorization dialog
    Accept to add the new key to Putty's cache
The default login information is user: torizon and password: torizon. On the first login, you may be requested to change the user password. The login prompt should look like this:
  • PuTTY login
    PuTTY login
Note: as you type the password, there is no visual feedback. In other words, as you type the password, no asterisks or any other characters will be printed.
Step 2 - Alternative - Using hostname instead of the IP address
You can also connect by the board's hostname as mentioned in the previous lessons.
As an example, the board's hostname is apalis-imx8-06438725.
If you are not sure what is the model or processor name of your board, please, refer to Toradex Products page
On PuTTy, insert the hostname of your board. Click "Open" and accept the next dialog box.
Step 3
The success of this step depends on your router keeping the board IP address the same as the one you have retrieved in the previous lesson. Most IP addresses are assigned using DHCP, which means the board IP address can be changed over time without notice. If you suspect the board IP is incorrect, refer to the FAQ at the end of this lesson.
Step 4
If you are new to Linux commands, read the basic Linux commands article.
FAQ
Are there any alternatives to PuTTY?
