Unboxing and Setup Cables - Aster - Colibri iMX6ULL
Your progress
  • System setup block diagram
List of items required
VGA display/monitor
USB Micro-A to Type-A (USB Micro-AB receptacle to Type-A) cable
Ethernet cable
USB keyboard
2.4GHz SMA antenna
SMA to U.FL cable
Remove the Aster Carrier Board and the Colibri Computer on Module from the blisters.
Unpack the SMA antenna and the SMA to U.FL cable.
Connect the SMA antenna to the SMA to U.FL cable as shown in the picture below:
  • Connecting SMA antenna to SMA to U.FL adapter cable
Connect the antenna to the U.FL connector on the Colibri iMX6ULL module as following:
  • Connected U.FL antenna
Insert the computer on module into the X1 connector of the Aster Carrier Board on the bottom side, as tight as possible, with the module inclined ~30 to 45 degree in relation to the carrier board.
  • Connecting the computer on module to the Aster Carrier Board - Bottom side
Warning: Make sure that the module is well connected to the board. The image below has some checkpoints highlighted.
  • Computer on module connected to the Aster Carrier Board - Bottom Side
There are two ways to power the Aster carrier board: a standard 3.5mm power jack barrel connector using a external DC power supply and a USB micro B connector, connector X4. In this guide, we will power the board via the micro USB connector, therefore it is necessary to close the jumper JP1 as shown in the image.
  • Jumper JP1 closed - USB power
Attention: The total power consumption of the system depends on the module/peripheral/accessories used. Please note that power available via micro USB connector may not be sufficient for modules or applications with high power requirements, since this configuration is not fully USB compliant. In such cases, it is recommended to use an external power supply to power the system. While using an external power supply, please remove the shunt jumper (if any) from the USB Power Jumper (JP1) in order to avoid short circuiting USB and external power supplies.
Step 3
  • Connect an VGA monitor to the X13.
  • Connect a USB keyboard to the X9.
  • Connect the Ethernet cable to the X8. Note: Ethernet network must provide DHCP and Internet to the module.
  • Connect a USB micro-B to USB Type-A cable to X4.
  • VGA, Ethernet, USB keyboard, USB micro-B to USB Type-A connected to the Carrier Board
Notice that the micro USB connector (X4) can be employed as a means to power the system and also has an integrated USB-serial converter that provides access to the computer on module debug serial port.
