In this module you will:
List of items required |
SD card with more than 2GB |
Cable USB-micro USB |
Note: The following steps are meant to be run in the development workstation, and not on the target module, unless otherwise stated.
sudo dpkg --add-architecture i386sudo apt-get updatesudo apt-get install dosfstools e2fsprogs gawk mtools partedsudo apt-get install zlib1g:i386 liblzo2-2:i386 libuuid1:i386 libusb-1.0-0:i386sudo apt-get install gparted
user@host:~$ df -hFilesystem Size Used Avail Use% Mounted onudev 3,9G 0 3,9G 0% /devtmpfs 792M 50M 743M 7% /run/dev/sda7 42G 30G 10G 75% /tmpfs 3,9G 145M 3,8G 4% /dev/shmtmpfs 5,0M 8,0K 5,0M 1% /run/locktmpfs 3,9G 0 3,9G 0% /sys/fs/cgroup/dev/sda5 922M 340M 520M 40% /boot/dev/sda8 178G 28G 141G 17% /usr/local/dev/sdb5 620G 558G 31G 95% /hometmpfs 792M 92K 792M 1% /run/user/1000
user@host:~$ df -hFilesystem Size Used Avail Use% Mounted onudev 3,9G 0 3,9G 0% /devtmpfs 792M 50M 743M 7% /run/dev/sda7 42G 30G 10G 75% /tmpfs 3,9G 145M 3,8G 4% /dev/shmtmpfs 5,0M 8,0K 5,0M 1% /run/locktmpfs 3,9G 0 3,9G 0% /sys/fs/cgroup/dev/sda5 922M 340M 520M 40% /boot/dev/sda8 178G 28G 141G 17% /usr/local/dev/sdb5 620G 558G 31G 95% /hometmpfs 792M 92K 792M 1% /run/user/1000/dev/mmcblk0p1 7,5G 296M 7,2G 4% /media/<user>/3E18-AADE
sudo gparted /dev/mmcblk0
sudo tar xjvf Colibri-<SoC-reference>_LXDE-Image_<bsp-version>-<date>.tar.bz2
cd Colibri-<SoC-reference>_LXDE-Image_<bsp-version>./update.sh -o /media/<user>/<partition_label>/
Insert the SD card in the SD/MMC connector, as illustrated:
Make sure that you have a working serial terminal application on your host machine. Note: You can go back to the last section if there are any doubts regarding the serial terminal application and its configuration.
Plug the USB A to micro B cable cable into the USB Client Connector (x10) to enter the recovery mode.
Simultaneously apply power to the embedded system and press the SPACE key in your keyboard a few times, while focused in the serial terminal. If you are successful, this procedure will stop the bootloader and you will have a terminal with the following prompt:
Toradex Bootloader 2.1b2 for Tegra Built Aug 8 2017 14:58:18Press [SPACE] to enter Bootloader MenuBootLoader Configuration:C) Clear Flash RegistryX) Enter CommandPrompt ModeD) Download image to RAM nowF) Download image to FLASH nowL) Launch existing flash resident image nowEnter your selection:
Note: If you press the SPACE key too late, the system will start booting. Power-off and try again.
Press X to enter the CommandPrompt mode, then enter the following command to enter recovery mode:
Enter your selection: x>reboot rcmRebooting...
At your host PC use the following command to load the U-Boot bootloader in the module's RAM:
[ Colibri-T30_LXDE-Image_2.7.4 ] $ ./update.sh -dColibri T30 rootfs detected
At your target device terminal, you will see that U-boot automatically starts to run:
U-Boot SPL 2016.11-2.7.4+g1b121c6 (Oct 05 2017 - 04:24:38)Trying to boot from RAMU-Boot 2016.11-2.7.4+g1b121c6 (Oct 05 2017 - 04:24:38 +0000)TEGRA30DRAM: 1 GiBMMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1*** Warning - bad CRC, using default environmentIn: serialOut: vidconsoleErr: vidconsoleMISSING TORADEX CONFIG BLOCKModel: Toradex Colibri T30 1GBUSB recovery mode, disabled autobootNet: No ethernet found.
Run the following commands at your target device terminal to flash the image:
Colibri T30 # run setupdatereading flash_blk.img710 bytes read in 13 ms (52.7 KiB/s)## Executing script at 81000000reading colibri_t30/flash_blk.img5083 bytes read in 23 ms (215.8 KiB/s)## Executing script at 81000000enter "run update" to update the entire moduleColibri T30 # run update
After a while, the system boots the updated Linux image and you will see the login message:
