Update the Linux Image - Colibri Evaluation Board - Colibri T20
Your progress
In this module you will:
  • Format an SD card.
  • Use an SD card to flash the new image to the module.
  • Access the bootloader (U-Boot).
  • Flash a new Linux image to the module.
List of items required
SD card with more than 2GB
Cable USB-micro USB
Note: The following steps are meant to be run in the development workstation, and not on the target module, unless otherwise stated.
sudo apt-get update
sudo apt-get install zlib1g:i386 liblzo2-2:i386 libuuid1:i386 libusb-1.0-0:i386
sudo apt-get install gparted
user@host:~$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 3,9G 0 3,9G 0% /dev
tmpfs 792M 50M 743M 7% /run
/dev/sda7 42G 30G 10G 75% /
tmpfs 3,9G 145M 3,8G 4% /dev/shm
tmpfs 5,0M 8,0K 5,0M 1% /run/lock
tmpfs 3,9G 0 3,9G 0% /sys/fs/cgroup
/dev/sda5 922M 340M 520M 40% /boot
/dev/sda8 178G 28G 141G 17% /usr/local
/dev/sdb5 620G 558G 31G 95% /home
tmpfs 792M 92K 792M 1% /run/user/1000
Step 3
  • Select *do nothing* after SD card insertion
Step 4
user@host:~$ df -h
/dev/mmcblk0p1 7,5G 296M 7,2G 4% /media/<user>/3E18-AADE
Step 5
sudo gparted /dev/mmcblk0
  • Gparted GUI
    Gparted GUI
Step 6
  • Unmount the SD card
    Unmount the SD card
Step 7
  • Delete the current SD card partitions
Step 8
  • Create new partition
Step 9
  • Select FAT32 file system
Step 10
  • Apply all operations
  • Acknowledge warning message
  • Formatting SD card
    Formatting SD card
  • SD card successfully formatted
Step 11
  • Mount the SD card
    Mount the SD card
Step 12
Step 13
sudo tar xjvf Colibri-T20_LXDE-Image_<bsp-version>-<date>.tar.bz2
Step 14
cd Colibri-T20_LXDE-Image_<bsp-version>
./update.sh -o /media/<user>/<partition_label>/
Step 15
Step 16
Insert the SD card in the SD/MMC connector, as illustrated:
  • SD card slot highlighted
Step 17
Make sure that you have a working serial terminal application on your host machine. Note: You can go back to the last section if there are any doubts regarding the serial terminal application and its configuration.
Plug the USB A to micro B cable into the USB Client Connector (x10) to enter the recovery mode.
  • USB A to micro B cable
  • USB A to micro B cable highlighted
Simultaneously apply power to the embedded system and press the SPACE key in your keyboard a few times, while focused in the serial terminal. If you are successful, this procedure will stop the bootloader and you will have a terminal with the following prompt:
Colibri T20 512MB V1.2A SerialNo: 5120465
RAM: 512 MB, CarveOut: 64 MB
Locating kernel image in flash...Done(890)
Decompressing IMAGE(17136826, 33159552) from FLASH(0) to RAM(16000)...Done(373ms)
Jumping to image at 0x80016000...
Toradex Bootloader 2.1 for Tegra Built Feb 20 2018 09:03:40
BootLoader Configuration:
C) Clear Flash Registry
X) Enter CommandPrompt Mode
D) Download image to RAM now
Note: If you press the SPACE key too late, the system will start booting. Power-off and try again.
Step 18
Press X to enter the CommandPrompt mode, then enter the following command to enter recovery mode:
Enter your selection: x
>reboot rcm
Rebooting...
At your host PC use the following command to load the U-Boot bootloader in the module's RAM:
[ Colibri-T20_LXDE-Image_2.7.4 ] $ ./update.sh -d -r 512 -v V1_2
Colibri T20 rootfs detected
Step 19
At your target device terminal, you will see that U-boot automatically starts to run:
U-Boot SPL 2016.11-2.7.4+g1b121c6 (Oct 05 2017 - 04:41:47)
Trying to boot from RAM
U-Boot 2016.11-2.7.4+g1b121c6 (Oct 05 2017 - 04:41:47 +0000)
TEGRA20
DRAM: 512 MiB
NAND: 1024 MiB
MMC: Tegra SD/MMC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: vidconsole
Err: vidconsole
Model: Toradex Colibri T20 512MB IT V1.2A, Serial# 05120465
USB recovery mode, disabled autoboot
Net: No ethernet found.
Run the following commands at your target device terminal to flash the image:
Colibri T20 # nand erase.chip
Colibri T20 # cfgblock create
Is the module an IT version? [y/N] y
Enter the module version (e.g. V1.2A): V1.2A
Enter module serial number: 05120465
Toradex config block successfully written
Colibri T20 # setenv fdt_addr_r 0x01000000
Colibri T20 # saveenv
Colibri T20 # run setupdate
Colibri T20 # run update
After a while, the system boots the updated Linux image and you will see the login message:
  • Login to the Linux terminal
