In this module you will:
List of items required |
Micro SD card with more than 2GB |
Note: The following steps are meant to be run in the development workstation, and not on the target module, unless otherwise stated. Note: Whenever there is a reference to SD card, it means the micro SD card plus an adapter connected to the host machine, unless otherwise noted.
sudo dpkg --add-architecture i386sudo apt-get updatesudo apt-get install dosfstools e2fsprogs gawk mtools partedsudo apt-get install zlib1g:i386 liblzo2-2:i386 libuuid1:i386 libusb-1.0-0:i386sudo apt-get install gparted
user@host:~$ df -hFilesystem Size Used Avail Use% Mounted onudev 3,9G 0 3,9G 0% /devtmpfs 792M 50M 743M 7% /run/dev/sda7 42G 30G 10G 75% /tmpfs 3,9G 145M 3,8G 4% /dev/shmtmpfs 5,0M 8,0K 5,0M 1% /run/locktmpfs 3,9G 0 3,9G 0% /sys/fs/cgroup/dev/sda5 922M 340M 520M 40% /boot/dev/sda8 178G 28G 141G 17% /usr/local/dev/sdb5 620G 558G 31G 95% /hometmpfs 792M 92K 792M 1% /run/user/1000
user@host:~$ df -hFilesystem Size Used Avail Use% Mounted onudev 3,9G 0 3,9G 0% /devtmpfs 792M 50M 743M 7% /run/dev/sda7 42G 30G 10G 75% /tmpfs 3,9G 145M 3,8G 4% /dev/shmtmpfs 5,0M 8,0K 5,0M 1% /run/locktmpfs 3,9G 0 3,9G 0% /sys/fs/cgroup/dev/sda5 922M 340M 520M 40% /boot/dev/sda8 178G 28G 141G 17% /usr/local/dev/sdb5 620G 558G 31G 95% /hometmpfs 792M 92K 792M 1% /run/user/1000/dev/mmcblk0p1 7,5G 296M 7,2G 4% /media/<user>/3E18-AADE
Note: The following steps assume the SD card is listed as /dev/mmcblk0. Please adjust the instructions accordingly.
Warning: Backup your SD card data. The SD card will be formatted and all data will be lost.
sudo gparted /dev/mmcblk0
sudo tar xjvf Colibri-<SoC-reference>_LXDE-Image_<bsp-version>-<date>.tar.bz2
cd Colibri-<SoC-reference>_LXDE-Image_<bsp-version>./update.sh -o /media/<user>/<partition_label>/
Insert the micro SD card in the SD/MMC connector, as illustrated. Notice that for this step, the SD/USB adapter is not required:
Make sure that you have a working serial terminal application on your host machine. Note: You can go back to the last section if there are any doubts regarding the serial terminal application and its configuration.
Plug the USB A to micro B cable into the USB Client Connector (x12) to enter the recovery mode.
Simultaneously apply power to the embedded system and press the SPACE key in your keyboard a few times, while focused in the serial terminal. If you are successful, this procedure will stop the bootloader and you will have a terminal with the following prompt:
Colibri T20 512MB V1.2A SerialNo: 5120465RAM: 512 MB, CarveOut: 64 MBLocating kernel image in flash...Done(890)Decompressing IMAGE(17136826, 33159552) from FLASH(0) to RAM(16000)...Done(373ms)Jumping to image at 0x80016000...Toradex Bootloader 2.1 for Tegra Built Feb 20 2018 09:03:40Press [SPACE] to enter Bootloader MenuBootLoader Configuration:C) Clear Flash RegistryX) Enter CommandPrompt ModeD) Download image to RAM nowF) Download image to FLASH nowL) Launch existing flash resident image now
Note: If you press the SPACE key too late, the system will start booting. Power-off and try again.
Press X to enter the CommandPrompt mode, then enter the following command to enter recovery mode:
Enter your selection: x>reboot rcmRebooting...
At your host PC use the following command to load the U-Boot bootloader in the module's RAM:
[ Colibri-T20_LXDE-Image_<bsp_version> ] $ ./update.sh -d -r 512 -v V1_2Colibri T20 rootfs detected
At your target device terminal, you will see that U-boot automatically starts to run:
U-Boot SPL 2016.11-2.7.4+g1b121c6 (Oct 05 2017 - 04:41:47)Trying to boot from RAMU-Boot 2016.11-2.7.4+g1b121c6 (Oct 05 2017 - 04:41:47 +0000)TEGRA20DRAM: 512 MiBNAND: 1024 MiBMMC: Tegra SD/MMC: 0*** Warning - bad CRC, using default environmentIn: serialOut: vidconsoleErr: vidconsoleModel: Toradex Colibri T20 512MB IT V1.2A, Serial# 05120465USB recovery mode, disabled autobootNet: No ethernet found.
Run the following commands at your target device terminal to flash the image:
Colibri T20 # nand erase.chipColibri T20 # cfgblock createIs the module an IT version? [y/N] yEnter the module version (e.g. V1.2A): V1.2AEnter module serial number: 05120465Toradex config block successfully writtenColibri T20 # setenv fdt_addr_r 0x01000000Colibri T20 # saveenvColibri T20 # run setupdateColibri T20 # run update
After a while, the system boots the updated Linux image and you will see the login message:
