Update the Linux Image - Ixora Carrier Board - Apalis T30
Your progress
In this module you will:
  • Format an SD card.
  • Use an SD card to flash the new image to the module.
  • Access the bootloader (U-Boot).
  • Flash a new Linux image to the module.
List of items required
Micro SD card with more than 2GB
Note: The following steps are meant to be run in the development workstation, and not on the target module, unless otherwise stated. Note: Whenever there is a reference to SD card, it means the micro SD card plus an adapter connected to the host machine, unless otherwise noted.
sudo apt-get update
sudo apt-get install zlib1g:i386 liblzo2-2:i386 libuuid1:i386 libusb-1.0-0:i386
sudo apt-get install gparted
user@host:~$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 3,9G 0 3,9G 0% /dev
tmpfs 792M 50M 743M 7% /run
/dev/sda7 42G 30G 10G 75% /
tmpfs 3,9G 145M 3,8G 4% /dev/shm
tmpfs 5,0M 8,0K 5,0M 1% /run/lock
tmpfs 3,9G 0 3,9G 0% /sys/fs/cgroup
/dev/sda5 922M 340M 520M 40% /boot
/dev/sda8 178G 28G 141G 17% /usr/local
/dev/sdb5 620G 558G 31G 95% /home
tmpfs 792M 92K 792M 1% /run/user/1000
Step 3
  • Select *do nothing* after SD card insertion
Step 4
user@host:~$ df -h
/dev/mmcblk0p1 7,5G 296M 7,2G 4% /media/<user>/3E18-AADE
Step 5
Note: The following steps assume the SD card is listed as /dev/mmcblk0. Please adjust the instructions accordingly.
Warning: Backup your SD card data. The SD card will be formatted and all data will be lost.
sudo gparted /dev/mmcblk0
  • Gparted GUI
    Gparted GUI
Step 6
  • Unmount the SD card
    Unmount the SD card
Step 7
  • Delete the current SD card partitions
Step 8
  • Create new partition
Step 9
  • Select FAT32 file system
Step 10
  • Apply all operations
  • Acknowledge warning message
  • Formatting SD card
    Formatting SD card
  • SD card successfully formatted
Step 11
  • Mount the SD card
    Mount the SD card
Step 12
Step 13
sudo tar xjvf Apalis-TK1_LXDE-Image_<bsp-version>-<date>.tar.bz2
Step 14
cd Apalis-TK1_LXDE-Image_<bsp-version>
./update.sh -o /media/<user>/<partition_label>/
Step 15
Step 16
Insert the micro SD card in the SD/MMC connector, as illustrated. Notice that for this step, the SD/USB adapter is not required:
  • Micro SD card slot highlighted
Step 17
Make sure that you have a working serial terminal application on your host machine.
Note: You can go back to the last section if there are any doubts regarding the serial terminal application and its configuration.
Simultaneously apply power to the embedded system and press any key in your keyboard a few times, while focused in the serial terminal. If you are successful, this procedure will stop the bootloader and you will have a terminal with the following prompt:
Apalis TK1 #
Note: If you press any key too late, the system will start booting. Power-off and try again.
Step 18
To update the system, run the commands:
run setupdate
run update
  • Updating the module
    Updating the module
After a while, the system will boot with the updated Linux image and you will see the login message:
  • Login to the Linux terminal
Note: The "resizing filesystem" messages are expected and happen only on the first boot after the update.
Step 19
If you are updating from an image 2.7b3 or older to 2.7b4 or newer, an additional step is required, otherwise the boot process hangs. Reset the system and enter the U-Boot command-line again, then reload the default U-Boot environment and save it, as presented in the commands below:
Note: If you have custom U-Boot variables set, please make sure to copy them before proceeding, since this will erase any custom variables.
env default -a
saveenv
boot
