Module 2: First Steps with Torizon
In this module, you will get used to the experience of using Torizon. Run some basic applications, easily serve a static webpage, use our ease-of-use Debian application, develop a hello world application on Visual Studio using our Torizon Microsoft Environment, cross-build it for a target device and deploy and debug it remotely.
Warning: Follow precautions for handling electrostatic sensitive devices (ESD)
Typographic Conventions
Throughout the Torizon documentation, the following typographic conventions are used:
$ (dollar sign) Command in the host computer (e.g. your PC)
$ Command in your PC
$$ (double dollar sign) Command in a container in the host computer (e.g. your PC)
$$ Command inside a container in your PC
# (hashtag) Command in the target device/board (e.g. Linux terminal)
# Command in the target board, e.g. Colibri iMX6
## (double hashtag) Command inside a container in the target device (Torizon)
## Command inside a container in Torizon
> (greater-than sign) Command in the bootloader (e.g. U-Boot console)
> Command in the Bootloader
No symbol: Command output
$ Command waiting for output
Output
Contents
Container Hello World
Toradex Debian Image - Arm64
Install the Build Environment for Torizon
Build and Run your First Application - Visual Studio Code
