Container Hello World
Your progress
The module is flashed with the Torizon operating system. Torizon is a new Linux-based software platform that simplifies the process of developing and maintaining embedded software and allows containerized applications to run (such as Docker containers).
In this module you will:
  • Test Torizon with a hello-world application
Typographic Conventions
For this Getting Started Guide:
  • Development computer with Windows 10 Pro / Enterprise / Education.
For this lesson:
  • Have your host-target communication setup through SSH (using PuTTY client)
  • Have both host and target connected to the same network
Now that you have access through SSH, it is possible to fully explore Docker's capabilities. Run the Docker Hello World:
docker run hello-world
Read the generated prompt to understand what happened and how Docker works.
For something more ambitious, let's run nginx and serve a static webpage. Run:
docker run -d -p 80:80 nginx
Step 3
Check the board IP with the ip command:
ip addr show eth0
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether 00:14:2d:4d:c7:30 brd ff:ff:ff:ff:ff:ff
    inet 10.22.1.123/24 brd 10.22.1.255 scope global dynamic noprefixroute eth0
       valid_lft 84549sec preferred_lft 84549sec
    inet6 fe80::1ee0:6425:8c0:92e/64 scope link noprefixroute
       valid_lft forever preferred_lft forever
In the example above, we see from the inet parameter that the board IP is 10.22.1.123.
Step 4
In your computer, open a web browser of your choice and use the board IP address as the URL parameter:
  • nginx Server
    nginx Server
Step 5
Visit the Docker Hub, search for any image and try to run it with docker run <image>, or following the image documentation.
Warning: You'll only be able to run containers that support the Arm architecture!
FAQ
How relevant is the processor's architecture in containers?
