Writing Your First Dockerfile - ARM64
Your progress
Up to this point, you have been running pre-existing container images from Docker Hub, built by Toradex or other third-party. That is very good and sometimes you will choose to use container images as they are provided.
On the other hand, sometimes you will need to customize a container image with additional libraries, tools and your own application. To fulfill this goal, the Dockerfiles exist.
In this section, you will:
  • Write a Dockerfile.
  • Build a Docker image from the Dockerfile.
  • Upload the image to Docker Hub.
Typographic Conventions
For this Quickstart Guide:
  • Development computer with Ubuntu 18.04 LTS. Warning: Commands and instructions may vary slightly on other Ubuntu releases and Linux distributions.
  • Successfully completed the previous lessons from this guide.
For this lesson:
  • Docker downloaded and running. If you are not sure, please refer to the previous lessons.
Note: Carefully read this module's cover page clicking on "Module 3: Creating my Own Container" on the left menu bar before starting this lesson.
In your Linux machine, create a new folder named getting-started on the Desktop and a new file called Dockerfile inside it.
$ mkdir ~/getting-started
$ touch ~/getting-started/Dockerfile
Copy the following content into the newly created file:
Warning: a standard Dockerfile has no extension, therefore make sure your file is not named Dockerfile.txt, especially since file extensions are hidden by default. Consult this lesson's FAQ for details about naming.
getting-started\Dockerfile
FROM --platform=linux/arm64 torizon/debian:2-bullseye
RUN apt update && apt install nano -y
Note: If you wish, modify the Dockerfile to include more commands, such as RUN apt install python.
In this example, the FROM command shows where to get the base of our Docker image. It is important to set the platform correctly, otherwise when you deploy it to the board, the container may not work or malfunction. We also run some commands to install packages from Debian feeds, to test if the build really works.
From the command-line, in your development PC, login to the Docker CLI:
$ docker login
Follow the prompt with your Docker Hub credentials. Visit Docker Hub page to create a Docker ID if you don't have credentials.
Step 3
Enter the previously created getting-started folder and build the image:
$ cd ~/getting-started
$ docker build --pull -t <username>/gs-torizon .
Note that this <username> is your Docker Hub username.
Step 4
Upload the image to your Docker Hub:
$ docker push <username>/gs-torizon
Now your custom container image is accessible from Docker Hub just like the other images you've used until this lesson.
FAQ
What is a Dockerfile?
What does the created Dockerfile do?
Can I have multiple Dockerfiles with different names?
