Basic GPIO usage - Aster Carrier Board - Colibri T30
Your progress
In this lesson you will:
  • Debug GPIO configuration.
Materials (Optional)
Since Aster Carrier Board doesn't have buttons and LEDs available for debbuging purposes, we present two alternatives to test GPIOs: the first connects two GPIOs configured as input and output respectively; whereas the second alternative uses an external button and LED to achieve a better user experience, however, the following items are required:
  • 1x LED
  • 1x Button
  • 1x Transistor BC548
  • 2x 2k2Ω Resistor
  • 1x 470Ω Resistor
  • 1x Breadboard
  • Jumper wires
Note: On this getting started we are going to use 2x Resistor 2k2Ω, but you can use anyone between 1kΩ and 10kΩ. For Resistor 470Ω, you can use anyone between 100Ω and 1kΩ. For the transistor BC548, you can use any switch component you want, as MOSFET, just change the circuit according to the component.
To find out which GPIO number to use in the Linux sysfs interface, you have to know the correspondence between available pins in the carrier board, number of the correspondent pins on the SODIMM connector of the Colibri computer on module and number of the pins on Linux.
Download or open in a web browser the Colibri Evaluation Board and the Colibri T30 datasheets from the respective products pages of the developer website:
Aster Carrier Board datasheet
For this introduction guide, some pins configured by default as GPIO in the Toradex BSP were chosen. The choice of pins was made based on their availability on all the carrier boards covered by the getting-started guide. This module will not go through the configuration of other pins as GPIO, although it is possible.
First of all, you need to find the correspondence between the SODIMM and the connectors exposed for the developer on the Aster Carrier Board. Consult the Aster Carrier Board datasheet and fill the table below based in the example provided:
Note: The notation CONNECTOR.PIN will be employed in this lesson, e.g. X12.5 means pin 5 of the X12 connector.
Note: For pin 85, please verify Parallel Camera Interface chapter in Aster's datasheet.
Aster Carrier Board (connector.pin) SODIMM pins
X20.37 79
85
97
98
101
103
133
Table 1 filled
Step 3
Have a look at the table available in the "List Functions" chapter of the Colibri T30 datasheet. It provides a list of most of the Tegra pins available on the SODIMM connector.
The SODIMM pins we are interested at are connected to the Tegra SoC and have names defined by the Tegra Pin Name function. Each pin is multiplexed to have a specific function - among them GPIO, therefore the GPIO function is the column that we are interested at.
Having a look at the GPIO Alphanumeric to GPIO Numeric Assignment article, the correspondence between GPIO and the Linux numeric representation of the GPIO pins is provided as a table. To find it from the GPIO it is possible to use the formula below:
GPIO-(Character).Digit
Linux numeric representation = 8 x (Character - 'A') + Digit
Either by consulting the table from the article pointed above or calculating it, the previous table with the correspondence between Aster Carrier Board pins and SODIMM pins can be extended to have the Tegra pin name (GPIO), formed by GPIO character and digit, as example GPIO-T.02, and the Linux numeric representation. Fill the table below based in the example provided:
Aster Carrier Board (connector.pin) SODIMM pins Tegra pin name (GPIO) Linux GPIO number
X20.37 79 GPIO-Y.05 197
X20.26 85
X20.13 97
X20.16 98
X20.22 101
X20.18 103
Table 2 filled
Step 4
Choose two of the GPIO pins from the list above to make a loopback test. This lesson will use the following pins (Linux GPIO number):
  • 201 as Input
  • 196 as Output
Use jumper wires to connect GPIO 201 to GPIO 196.
Step 5
Note: You need a display and a mouse connected to the system in order to use the GPIO tool. Please go to the beginning of the getting-started guide for more information about assembling the peripherals.
  • Starting the GPIO tool
  • GPIO tool initial screen
Step 6
Locate the pins 201 and 196 in the table. Right click the direction of each of them and configure pin 201 as INPUT and pin 196 as OUTPUT. See the changes reflected in the application.
  • Configuring SODIMM pin
Step 7
Click the Logic checkbox of pin 196 and see the logic checkbox of pin 201 switch on/off.
  • Logic checkbox toggled from GPIO tool
Step 8
From the Linux terminal, export the pins 201 and 196:
echo 201 > /sys/class/gpio/export
echo 196 > /sys/class/gpio/export
echo "in" > /sys/class/gpio/gpio201/direction
echo "out" > /sys/class/gpio/gpio196/direction
Step 9
Read the INPUT value as you toggle OUTPUT value:
echo 1 > /sys/class/gpio/gpio196/value
cat /sys/class/gpio/gpio201/value
echo 0 > /sys/class/gpio/gpio196/value
Steps 10 to 17 (Optional)
The following steps are meant for readers that have the optional items listed in the beginning of this lesson. If you want to go through them, click the dropdown link below:
Steps 10 to 17
FAQ
What is the sysfs interface
