Basic GPIO usage - Colibri Evaluation Board - Colibri VFxx
Your progress
In this lesson you will:
  • Debug GPIO configuration.
Materials Required
The Colibri Evaluation Board already has buttons and LEDs available for debugging purposes, therefore only jumper wires are required.
To find out which GPIO number to use in the Linux sysfs interface, you have to know the correspondence between available pins in the carrier board, number of the correspondent pins on the SODIMM connector of the Colibri computer on module and number of the pins on Linux.
Download or open in a web browser the Colibri Evaluation Board and the Colibri VFxx datasheets from the respective products pages of the developer website:
Colibri Evaluation Board datasheet
For this introduction guide, some pins configured by default as GPIO in the Toradex BSP were chosen. The choice of pins was made based on their availability on all the carrier boards covered by the getting-started guide. This module will not go through the configuration of other pins as GPIO, although it is possible.
First of all, you need to find the correspondence between the SODIMM and the connectors exposed for the developer on the Colibri Evaluation Board V3.2. Consult the Colibri Evaluation Board datasheet and fill the table below based in the example provided:
Note: The notation CONNECTOR.PIN will be employed in this lesson, e.g. X12.5 means pin 5 of the X12 connector.
Colibri Evaluation Board (connector.pin) SODIMM pins
X22.9 79
85
97
98
101
103
133
Table 1 filled
Warning: The pinout of the Camera Interface connector (X22) has been updated from Colibri Evaluation Board V3.1 to V3.2. Please consult the datasheet if you are using the older version.
Step 3
Have a look at the table available in the "List Functions" chapter of the Colibri VFxx datasheet. It provides a list of most of the Vybrid pins available on the SODIMM connector.
The SODIMM pins we are interested at are connected to the Vybrid SoC and have names defined by the ALT0 function. Each pin is multiplexed to have a specific function - among them GPIO, therefore the GPIO pad, GPIO port and ALT0 functions are the columns that we are interested at.
Having a look at the GPIO Alphanumeric to GPIO Numeric Assignment article, the correspondence between ALT0 and the Linux numeric representation of the GPIO pins is provided as a table. The GPIO pad number corresponds to this number, and to find it from the GPIO port it is possible to use the formula below:
PORTx[y]
Linux numeric representation = 32*x+y
Either by consulting the table from the article pointed above or calculating it, the previous table with the correspondence between Aster Carrier Board pins and SODIMM pins can be extended to have the Vybrid pin name (ALT0), formed by GPIO controller, as example PORT0, plus pin at SoC level, as example [27], and the Linux numeric representation. Fill the table below based in the example provided:
Colibri Evaluation Board (connector.pin) SODIMM pins Vybrid name (ALT0) Linux GPIO number
X22.9 79 PTC4 49
X22.13 85
X22.10 97
X22.18 98
X22.7 101
X22.8 103
X10.41 133
Table 2 filled
Step 4
Choose two of the GPIO pins from the list above to toggle an LED and read the value of a switch. This lesson will use the following pins (Linux GPIO number):
  • 46 for SW
  • 50 for LED
Use jumper wires to connect GPIO 46 to the slide switch SW4 on the connector X21.7, and GPIO 50 to the LED1 on the connector X21.2.
Note: For more informations about pins schematic, please access the Colibri Evaluation Board schematics here.
Note: You may use any other of the LEDs/switches available. Please refer to the section 3.9.2.3 LED / Switches (X21) of the Colibri Evaluation Board datasheet.
  • Connecting the SODIMM pins to the LED and switch
Step 5
Note: You need a display and a mouse connected to the system in order to use the GPIO tool. Please go to the beginning of the getting-started guide for more information about assembling the peripherals.
  • Starting the GPIO tool
  • GPIO tool initial screen
Step 6
Locate the pins 46 and 50 in the table. Right click the direction of each of them and configure pin 46 as INPUT and pin 50 as OUTPUT. See the changes reflected in the application.
  • Configuring SODIMM pin
Step 7
Toggle the switch SW4 and see the Logic checkbox of the pin 46 change its state. Click the Logic checkbox of pin 50 and see the LED switch on/off.
  • LED toggled from GPIO tool
Step 8
From the Linux terminal, export the pins 46 and 50:
echo 46 > /sys/class/gpio/export
echo 50 > /sys/class/gpio/export
echo "in" > /sys/class/gpio/gpio46/direction
echo "out" > /sys/class/gpio/gpio50/direction
Step 9
Read the switch value as you toggle it:
cat /sys/class/gpio/gpio46/value
Step 10
Toggle the LED GPIO:
echo 1 > /sys/class/gpio/gpio50/value
echo 0 > /sys/class/gpio/gpio50/value
Step 11
There is a debug interface provided by the kernel debugfs for GPIO, which holds information about GPIO pins already reserved for drivers, as well as pin configuration and state. See the example below for the Colibri VF61, and try it yourself:
root@colibri-vf:~# cat /sys/kernel/debug/gpio
GPIOs 0-31, platform/40049000.gpio, vf610-gpio:
gpio-8 ( |AC97 link sdata ) out lo
gpio-9 ( |AC97 link sync ) out lo
gpio-13 ( |AC97 link reset ) out hi
GPIOs 32-63, platform/4004a000.gpio, vf610-gpio:
gpio-41 ( |Wake-Up ) in lo IRQ
gpio-42 ( |cd ) in hi IRQ
gpio-45 ( |enable ) out hi
gpio-46 ( |sysfs ) in lo
gpio-50 ( |sysfs ) out lo
GPIOs 64-95, platform/4004b000.gpio, vf610-gpio:
gpio-83 ( |VCC_USB[1-4] ) out lo
GPIOs 96-127, platform/4004c000.gpio, vf610-gpio:
gpio-102 ( |id ) in lo IRQ
GPIOs 128-159, platform/4004d000.gpio, vf610-gpio:
See that the pins 46 and 50, configured as input and output in the previous steps, are the only ones taken by sysfs and are correctly configured as in and out respectively.
Export, unexport, configure and toggle the GPIO pins as you read the debugfs information to see the changes.
Note: If you want additional pin configuration debug, explore the /sys/kernel/debug/pinctrl/ directory.
Step 12
Write a small C application that toggles the LED GPIO. A small source-code is given below for reference and you may copy-paste it to your previously configured Eclipse environment.
Warning: The source-codes provided in this guide are distributed under the 3-clause BSD license terms. See below:
License
Source code 1
Step 13
Write a small C application that reads the switch GPIO. A small source-code is given below for reference and you may copy-paste it to your previously configured Eclipse environment.
Source code 2
Step 14
The GPIO sysfs interface enables the use of interrupts from user space, as long as it is supported by the underlying hardware. Read the sysfs GPIO documentation, have a look at the poll system call and try to implement an application that handles the interrupt. Have a look at the source code below for reference:
Source code 3
To prevent the main loop from blocking, run the GPIO IRQ handling in a separate thread. Try to implement it.
Step 15
Improve the code from the previous steps to handle errors and add other functionality you want. The code below implements a frequency meter by measuring the elapsed time between GPIO interruptions:
Source code 4
FAQ
What is the sysfs interface
