  • Computer on Module
    Apalis iMX6 Dual/Quad
  • Carrier Board
    Apalis Evaluation Board
  • Computer on Module OS
    Linux
  • Development PC OS
    Linux
Basic UART usage - Apalis Evaluation Board - Apalis iMX6
In this lesson, you will:
The information provided in this guide is based on Toradex's knowledge base article UART (Linux).
Attention: Never connect a RS-232 output pin to a TTL input. This might lead to permanent damage.
Materials Required
  • Jumper wires
Be introduced to the UART protocol:
UART stands for Universal Asynchronous Receiver-Transmitter. These kinds of interfaces are used to achieve asynchronous serial communication between devices. The transmission speed and the data format are configurable.
There are 4 main pins that may be used on a UART interface:
  • RTS, request-to-send
  • CTS, clear-to-send
Note: The RTS and CTS signals are used to achieve hardware flow control. We will not delve into this topic in this tutorial. Therefore, we will only use the RX and TX (and ground) pins.
  • UART Block Diagram
    UART interfaces block diagram
Get used to the naming conventions:
The Apalis Evaluation Board offers 4 UART interfaces common to all SoMs from the Apalis family, presented in the Toradex Name column from the table below. The other columns provide information about the respective protocols, converters or electric standards in which the signals are available on the carrier board:
Toradex Name Serial-to-USB converter RS232 TTL 3.3V Notes
UART1 X29 X28 bottom X6/X7 -
UART2 - X28 top X6/X7 -
UART3 - - X3/X4 X30 - IrDA
UART4 - - X3/X4 X38 - Mezzanine
The following table relates the Toradex Name to the corresponding Linux device file:
Toradex Name Device
UART1 /dev/ttymxc0
UART2 /dev/ttymxc1
UART3 /dev/ttymxc3
UART4 /dev/ttymxc4
In this lesson, the UART2 interface is used in the examples and the Toradex naming convention (Toradex Name) is used unless otherwise stated.
Step 3
UART signals and pins
Step 4
Connect your board's UART2 TX pin (X28.U3) to its RX pin (X28.U2).
  • Apalis UART Wiring
    Apalis UART Wiring
Step 5
From a serial terminal connected to the module, configure the UART2 baud rate using the stty command. We will use a baud rate of 9600 baud:
stty -F /dev/ttymxc1 9600 -echo
cat < /dev/ttymxc1 &
echo "Testing UART" > /dev/ttymxc1
Testing UART
Step 6
A UART loopback test can also be written in C.
License
Step 7
Step 8
Step 9
Step 10
After writing to the serial port, you can read from it. Since it's a loopback, you will read what you just wrote and save it to the buffer variable. Also, don't forget to use the standard system call close() to close the device when you're done. To avoid timing problems, use a delay between writing and reading.
Step 11
Loopback test code
Step 12
Improved loopback test
Step 13
For this example, we will call UART2 "first_uart" and UART3 "second_uart".
Connect UART2_RXD (X20.10) to UART3_TXD (X3.B38) and UART2_TXD (X20.8) to UART3_RXD (X3.B39).
FAQ
How can use another UART interface instead of the one used in this lesson
Can the debug UART be used for general purpose
How can I disable DMA for RX
