Basic UART usage - Apalis Evaluation Board - Apalis TK1
Your progress
Getting Started with UART
In this lesson, you will:
The information provided in this guide is based in Toradex's knowledge base article UART (Linux).
Materials Required
The Apalis Evaluation Board offers 4 UART interfaces:
Serial-to-USB converter RS232 (DB9 connector) Pin header Notes
UART1 X29 X28 Bottom X6/X7
UART2 - X28 Top X6/X7
UART3 - - X3/X4
UART4 - - X3/X4
Attention: Never connect a RS-232 output pin to a TTL input. This might lead to permanent damage.
For this tutorial, we will use the UART2 interface. You will need:
  • Jumper wires
  • USB Type-B to Type-A cable
Note: Depending on the module used, the UART interfaces are indexed with numbers (UART1, UART2, etc.) or letters (UARTA, UARTB, etc.). For this tutorial, we'll stick with the nomenclature used by the carrier board, which indexes the UART peripherals using numbers (UART1, UART2, etc.).
UART stands for Universal Asynchronous Receiver-Transmitter. These kind of interfaces are used to achieve asynchronous serial communication between devices. The transmission speed and the data format are configurable. There are 4 main pins that may be used on a UART interface:
  • RTS, request-to-send
  • CTS, clear-to-send
Note: The RTS and CTS signals are used to achieve hardware flow control. We will not delve into this topic in this tutorial. Therefore, we will only use the RX and TX pins.
The following table contains the available UART interfaces along with their designators on the module, the board and Linux device.
Module Base Board Linux device Enabled
UART1/UARTA/UA3 UART1 /dev/ttyS0 RX/TX and RTS/CTS only
UART2/UARTB/IR3/UB3 UART2 /dev/ttyTHS1
UART3/UARTC/UC3 UART3 /dev/ttyTHS2
UART4/UARTD/UD3 UART4 /dev/ttyTHS3
Step 3
UART signals and pins
Step 4
Connect your board's UART2 TX pin (X28.U3) to its RX pin (X28.U2).
  • Apalis UART wiring
    Apalis UART wiring
Step 5
From a serial terminal connected to the module, configure the UART 2 baud rate using the stty command. We will use a baud rate of 9600 baud:
stty -F /dev/ttyTHS1 9600 -echo
cat < /dev/ttyTHS1 &
echo "Testing UART" > /dev/ttyTHS1
Testing UART
Step 6
An UART loopback test can also be written in C.
License
Step 7
Step 8
Step 9
Step 10
After writing to the serial port, you can read from it. Since it's a loopback, you will read what you just wrote and save it to the buffer variable. Also, don't forget to use the standard system call close() to close the device when you're done. To avoid timing problems, use a delay between writing and reading.
Step 11
Loopback test code
Step 12
Improved loopback test
Step 13
For this example, we will call UART2 "first_uart" and UART3 "second_uart".
Connect UART2_RXD (X20.10) to UART3_TXD (X3.B38) and UART2_TXD (X20.8) to UART3_RXD (X3.B39).
FAQ
How can use another UART interface instead of UART2
Can UART1 be used for general purpose
How can I disable DMA for RX
