Basic UART usage - Colibri Evaluation Board - Colibri VFxx
Your progress
Getting Started with UART
In this lesson, you will:
The information provided in this guide is based in Toradex' knowledge base article UART (Linux).
Materials Required
The Colibri Evaluation Board offers 3 UART interfaces:
Serial-to-USB converter RS232 (DB9 connector) Pin header
UART_A X27 X25 X11/X12
UART_B X29 X25 X11/X12
UART_C - - X11/X12
Note: Changing the position of jumpers JP17, JP19, JP20 and JP21 routes the UART_A signals from connector X27 to connector X25 (bottom).
For this tutorial, we will use the UART_B interface. You will need:
  • Jumper wires
  • USB Type-B to Type-A cable
Note: Depending on the module used, the UART interfaces are indexed with numbers (UART1, UART2, etc.) or letters (UARTA, UARTB, etc.). For this tutorial, we'll stick with the nomenclature used by the carrier board, which indexes the UART peripherals using letters (UART_A, UART_B, etc.).
UART stands for Universal Asynchronous Receiver-Transmitter. These kind of interfaces are used to achieve asynchronous serial communication between devices. The transmission speed and the data format are configurable. There are 4 main pins that may be used on a UART interface:
  • RTS, request-to-send
  • CTS, clear-to-send
Note: The RTS and CTS signals are used to achieve hardware flow control. We will not delve into this topic in this tutorial. Therefore, we will only use the RX and TX pins.
  • UART Block Diagram
    UART interfaces block diagram
The following table contains the UART interfaces available by default along with their designators on the module, the board and Linux device.
Module Base Board Linux device
UART1 UART_A /dev/ttyLP0
UART2 UART_B /dev/ttyLP1
UART3 UART_C /dev/ttyLP2
Step 3
UART signals and pins
Step 4
Connect your board's UART_B TX pin (X12.17) to its RX pin (X12.16).
  • Colibri UART Wiring
    Colibri UART Wiring
Step 5
From a serial terminal connected to the module, configure the UART_B baud rate using the stty command. We will use a baud rate of 9600 baud:
stty -F /dev/ttyLP1 9600 -echo
cat < /dev/ttyLP1 &
echo "Testing UART" > /dev/ttyLP1
Testing UART
Step 6
An UART loopback test can also be written in C.
License
Step 7
Step 8
Step 9
Step 10
After writing to the serial port, you can read from it. Since it's a loopback, you will read what you just wrote and save it to the buffer variable. Also, don't forget to use the standard system call close() to close the device when you're done.
Step 11
Loopback test code
Step 12
Improved loopback test
Step 13
For this example, we will call UART_B "first_uart" and UART_C "second_uart".
Connect UART_B_RXD (X12.16) to UART_C_TXD (X12.3) and UART_B_TXD (X12.17) to UART_C_RXD (X12.2).
FAQ
How can use another UART interface instead of UART_B
Can UART_A be used for general purpose
How can I disable DMA for RX
