Basic UART usage - Iris Carrier Board - Colibri iMX6ULL
Your progress
In this lesson, you will:
The information provided in this guide is based on Toradex's knowledge base article UART (Linux).
Attention: Never connect a RS-232 output pin to a TTL input. This might lead to permanent damage.
Materials Required
  • Jumper wires
Be introduced to the UART protocol:
UART stands for Universal Asynchronous Receiver-Transmitter. These kinds of interfaces are used to achieve asynchronous serial communication between devices. The transmission speed and the data format are configurable.
There are 4 main pins that may be used on a UART interface:
  • RTS, request-to-send
  • CTS, clear-to-send
Note: The RTS and CTS signals are used to achieve hardware flow control. We will not delve into this topic in this tutorial. Therefore, we will only use the RX and TX (and ground) pins.
  • UART Block Diagram
    UART interfaces block diagram
Get used to the naming conventions:
The Iris Carrier Board offers 3 UART interfaces common to all SoMs from the Colibri family, presented in the Toradex Name column from the table below. The other columns provide information about the respective protocols, converters or electric standards in which the signals are available on the carrier board:
Toradex Name RS232 TTL 3.3V
UART_A X13 X16
UART_B X14 X16
UART_C X14 X16
The following table relates the Toradex Name to the corresponding Linux device file:
Toradex Name Device
UART_A /dev/ttymxc0
UART_B /dev/ttymxc1
UART_C /dev/ttymxc4
In this lesson, the UART_B interface is used in the examples and the Toradex naming convention (Toradex Name) is used unless otherwise stated.
Step 3
UART signals and pins
Step 4
Connect your board's UART_B TX pin (X16.32) to its RX pin (X16.31).
  • Iris UART Wiring
    Iris UART Wiring
Step 5
From a serial terminal connected to the module, configure the UART_B baud rate using the stty command. We will use a baud rate of 9600 baud:
stty -F /dev/ttymxc1 9600 -echo
cat < /dev/ttymxc1 &
echo "Testing UART" > /dev/ttymxc1
Testing UART
Now we need to stop the cat-command in the background, to make the UART accessable again. You can do that by killing all running cat-commands.
killall cat
Step 6
A UART loopback test can also be written in C.
License
Step 7
Step 8
Step 9
Step 10
After writing to the serial port, you can read from it. Since it's a loopback, you will read what you just wrote and save it to the buffer variable. Also, don't forget to use the standard system call close() to close the device when you're done. To avoid timing problems, use a delay between writing and reading.
Step 11
Loopback test code
Step 12
Improved loopback test
Step 13
For this example, we will call UART_B "first_uart" and UART_C "second_uart".
Connect UART_B_RXD (X16.31) to UART_C_TXD (X16.35) and UART_B_TXD (X16.32) to UART_C_RXD (X16.34).
FAQ
How can use another UART interface instead of the one used in this lesson
Can the debug UART be used for general purpose
How can I disable DMA for RX
