Basic UART usage - Ixora Carrier Board - Apalis TK1
Your progress
Getting Started with UART
In this lesson, you will:
The information provided in this guide is based in Toradex's knowledge base article UART (Linux).
Materials Required
The Ixora Carrier Board offers 4 UART interfaces:
Serial-to-USB converter RS232 (DB9 connector) Pin header
UART1 - X22
UART2 - X21
UART3 - X21 X27
UART4 - - X27
For this tutorial, we will use the UART2 interface. You will need:
  • Jumper wires
UART stands for Universal Asynchronous Receiver-Transmitter. These kind of interfaces are used to achieve asynchronous serial communication between devices. The transmission speed and the data format are configurable. There are 4 main pins that may be used on a UART interface:
  • RTS, request-to-send
  • CTS, clear-to-send
Note: The RTS and CTS signals are used to achieve hardware flow control. We will not delve into this topic in this tutorial. Therefore, we will only use the RX and TX pins.
  • UART Block Diagram
    UART interfaces block diagram
The following table contains the available UART interfaces along with their designators on the module, the board and Linux device.
Module Base Board Linux device
UART1 UART1 /dev/ttyS0
UART2 UART2 /dev/ttyTHS1
UART3 UART3 /dev/ttyTHS2
UART4 UART4 /dev/ttyTHS3
Step 3
UART signals and pins
Step 4
Connect your board's UART 2 TX pin (X21.5) to its RX pin (X21.3).
  • Ixora UART wiring
    Ixora UART wiring
Step 5
From a serial terminal connected to the module, configure the UART 2 baud rate using the stty command. We will use a baud rate of 9600 baud:
stty -F /dev/ttyTHS1 9600 -echo
cat < /dev/ttyTHS1 &
echo "Testing UART" > /dev/ttyTHS1
Testing UART
Step 6
An UART loopback test can also be written in C.
License
Step 7
Step 8
Step 9
Step 10
After writing to the serial port, you can read from it. Since it's a loopback, you will read what you just wrote and save it to the buffer variable. Also, don't forget to use the standard system call close() to close the device when you're done.
Step 11
Loopback test code
Step 12
License
Improved loopback test
Step 13
For this example, we will call UART_B "first_uart" and UART_C "second_uart".
Connect UART_B_RXD (X21.3) to UART_C_TXD (X21.7) and UART_B_TXD (X21.5) to UART_C_RXD (X21.1).
Example: communicating between UARTs on the same board
FAQ
How can use another UART interface instead of UART2
Can UART1 be used for general purpose
How can I disable DMA for RX
