Updating Containers with Torizon OTA
Your progress
After adding your device to Torizon OTA in the previous lesson, now you can deploy your application.
In this section, you will:
  • Upload a Docker Compose file with example container information. In other words, add your application to Torizon OTA.
  • Remotely update your device with these new containers.
  • The example should execute a web browser on the device.
Typographic Conventions
For this Quickstart Guide:
  • Development computer with Ubuntu 18.04 LTS.
    • Commands and instructions may vary slightly on other Ubuntu releases and Linux distributions.
  • Successfully completed the previous lessons from this guide.
* This is a requisite for the entire Quickstart, but our Torizon OTA app will run on any browser, on any Linux, Windows or MacOS.
Docker Compose is a tool for defining and running multi-container Docker applications.
For this Quickstart lesson, we will provide a Docker Compose file ready to use. Click the button below to download it:
Example Docker Compose file
After downloading the file, go to the dashboard and click on the "Add New Package" button.
  • Add a new package
    Add a new package
Step 3
Click on the "Attach Docker Compose File" button and then select the *.yml file you have just downloaded.
  • Attach your .yml file
After that, click on "Continue".
Step 4
Select my-package as the "Tag".
  • Select your SoM family accordingly
Click on "Upload" and wait until the process concludes.
  • Package Created
    Package Created
Step 5
Go to the dashboard again and click to initiate an update in your device:
  • Initiate Update
    Initiate Update
Step 6
Select the option "Custom Package" and then select the package you've just added.
  • Select the package
    Select the package
Click on "Continue". The update process will take some time. You can see the progress on the icon in the bottom-left part of the screen.
Note: by default, TorizonCore is configured to poll the OTA server once every 5 minutes. That may sound like a lot of time for evaluation, but it is a reasonable default configuration for production. After you finish the Quickstart, you can set a custom polling time.
  • Wait until the update finishes
Step 7
After the update is deployed, the board will automatically reboot and a browser will show up on the external monitor:
  • Web browser on Torizon
Step 8 - Optional
Edit the following line on the docker-compose (*.yml) file to modify the browser initial page:
    command: --browser-mode http://www.toradex.com
Note: Optionally, you can also replace --browser-mode by --window-mode in order to start the browser in fullscreen mode.
After editing and saving the docker-compose file, upload this new version following step 2 onwards.
FAQ
Is Torizon OTA free? What are the plan options?
Do I need to learn Docker Compose?
How can I learn more about Docker Compose?
Where do I find more information about the web browser example?
