Apalis iMX8 Mezzanine
Getting Started
This board is an add-on board for the Apalis Evaluation Board. This Mezzanine Board provides access to the type-specific interfaces on the Apalis iMX8 module.
These interfaces may differ between different Apalis modules. Different types of specific mezzanine boards will be available for each Apalis module. Customers are free to develop their own type-specific mezzanine board for prototyping and development purposes.
For more information, please consult the datasheets for each Apalis module.
The Apalis iMX8 Mezzanine should be added to the order if you are planning to order the following composition of components:
Having trouble?
Please contact our technical support. Various technical support options are mentioned in the article below.
Features
Main Features
- 2x MIPI CSI (2x Quad-lane) connector
- 1x MIPI DSI (1x Single-lane) connector
- 1x Recovery mode switch
- 1x Reset switch
- 1x Generic header
- Media Local Bus (MediaLB) interface signals
- Power Pins
- Additional type-specific (TS_XX) signals
- 1x eDP/DP AUX header (only signal available in Apalis iMX8 type specific pins)
- 1x CAN FD transceiver (up to 8 Mbit/s)
- 1X Single channel LVDS Connector (up to 24-bit color)
Datasheets
Apalis iMX8 Mezzanine V1.0 Datasheet
Apalis iMX8 Mezzanine Datasheet
Design Resources
Design Data Apalis iMX8 Mezzanine V1.0
- Apalis iMX8 Mezzanine PDF Schematics
- Apalis iMX8 Mezzanine Assembly Drawing
- Apalis iMX8 Mezzanine Altium Project
- Apalis iMX8 Mezzanine Block Diagram
- Apalis iMX8 Mezzanine Bill of Materials (BOM)
Altium Designer
3D Models
Apalis iMX8 Mezzanine 3D Mechanical Models
The Apalis iMX8 Mezzanine 3D model contains the PCB and the maximum component height on the top and bottom of the module.
This is a SolidWorks CAD model. You can download the free eDrawings model viewer from SolidWorks here.
This is a generic STEP model that can be opened and modified in any 3D CAD.
This is a generic 3D PDF model that can be opened in Adobe Reader.
Compatible Products
Revision History
Product Number (PID8) Format
| Field | Description |
Example
0029: Apalis iMX6D 512MB
00: Assembly Variant A
0154xxxx - Apalis iMX8 Mezzanine
| Product # | Product Description | Changes from Previous Version | Release Date | Related Documents |
| 01541000 | Apalis iMX8 Mezzanine V1.0A | Initial Release | Q4 2023 |
