Apalis Evaluation Board
(Double-Click to Zoom)
The Apalis Evaluation Board is a full-featured carrier board that gives you easy access to most of the interfaces of the Apalis System on Modules (SoMs), intended as an evaluation platform.
This page provides hardware design resources, documentation, revision history, erratas, compatibility details, and getting started guides for developers working with the Apalis SoM family.
Getting Started
Recommendation for the First-Time Order
Quickstart Guide
Check out our guide for detailed instructions on how to get your board up and running with Torizon:
Having trouble?
Product Features
Hardware Features
Compatible Products
Learn more on the Apalis Product Family Specification.
Accessories & Add-ons
[1] Capacitive Touch Adapter is required.
Check other options and compatibility information on the add-ons product pages.
Block Diagram
Apalis Evaluation Board V1.2
Apalis Evaluation Board V1.1
Pinout Evaluation & Planning
Product Documents
Datasheets
Design Resources
Apalis Evaluation Board Design Data V1.2
Apalis Evaluation Board Design Data V1.1
Apalis Evaluation Board Design Data V1.0
Apalis Evaluation Board Mechanical Models
A basic 3D model for the Apalis Evaluation board can be downloaded here:
Design and Layout Guide
Altium Designer
Software Ecosystem
Development Resources
Connecting to the Board
Revision History
Product Number (PID8) Format
Product Numbering Scheme
FieldDescription
Example
0029: Apalis iMX6D 512MB
00: Assembly Variant A
0115 Apalis Evaluation Board
01151000
Apalis Evaluation Board V1.0A
Initial Release
2013-03-15
Evaluation Product, No PCN
01151100
Apalis Evaluation Board V1.1A
  • Fixed JTAG connector issue
  • Added ESD protection to some USB and HDMI signals
  • Pull-down POWER_ENABLE_MOCI
  • Added pull-up to the FT232 TxD pin
  • The detailed revision history to this version can be found in the Schematics on the first page
2014-09-15PCN Apalis Evaluation Board V1.1A 2019-11-06
01151101
Apalis Evaluation Board V1.1B
Interim product, only for the Apalis iMX8 Early Access
  • R44 changed to a 0Ω-resistor for sufficient power supply for the Apalis iMX8
2019-05-07Interim Product, no PCN - see V1.1A for PCN
01151102
Apalis Evaluation Board V1.1C
  • R44 changed to a 5mΩ-resistor for sufficient power supply for the Apalis iMX8
  • X18 SD card holder changed from 8-bit to 4-bit due to EOL of the previous part
2019-11-06
01151125
Apalis Evaluation Board V1.1Z
  • Additional version with limited features
  • Removed SPDIF transmitter X21 and related discrete parts
Q1, 2023
01151200
Apalis Evaluation Board V1.2A
  • You can find the detailed revision history of this version in the schematics
Q4, 2024
Errata/Known Issues
Errata Document
Apalis Evaluation Board Errata Document
Hardware Issue Tracker
