Ixora Carrier Board
Ixora Carrier Board - Front
Ixora Carrier Board - Bottom
(Double-Click to Zoom)
Getting Started
This section contains initial information needed to set-up the Ixora Carrier Board for the first time.
All the products can be ordered online at Toradex Webshop
Getting started for the first time?
For detailed step-by-step instructions about how to start with both, SoM and Carrier Board, please have a look at our step-by-step Getting-Started Guide:
Product-specific information for the Ixora Carrier Board:
Having trouble?
Features
I/O Support
  • USB 2.0 (1x Host, 1x OTG )
  • USB 3.0 (2x Host)
  • PCIe (1x Mini PCIe)
  • I2C (2x)
  • SPI (1x)
  • UART (3x RS232)
  • PWM (4x)
  • GPIO (up to 40)
  • Analog Input (4x)
  • Ethernet (1x 10/100/1000 Mbit)
  • SATA (1x mSATA)
  • SDIO/SD/MMC (1x 4 Bit MicroSD)
  • CAN (2x)
  • LVDS (1x Dual Channel)
  • S/PDIF In/Out (1x)
  • HDMI (1x)
  • RGB (1x 24 Bit)
  • Resistive Touch (4/5-wire)
  • Capacitive Touch connector
  • Camera Parallel Interface (1x)
  • Camera Serial Interface (1x)
  • Analog Audio Line in (1x)
  • Analog Audio Mic in (1x)
  • Analog Audio Headphone out (1x)
  • RTC on Board (1x)
Block Diagram
Datasheets
Ixora V1.3 datasheet
Ixora V1.2 datasheet
Ixora V1.1 datasheet
Ixora V1.0 datasheet
Design Resources
Design data Ixora Carrier Board V1.3
Design data Ixora Carrier Board V1.2
Design data Ixora Carrier Board V1.1
Design data Ixora Carrier Board Archive
Ixora Carrier Board Mechanical Models
A basic 3D model for the Ixora Carrier Board V1.3 can be downloaded here:
Ixora Carrier Board V1.2 Models
Ixora Carrier Board V1.1 Models
Ixora Carrier Board V1.0 Models
Design and Layout Guide
Altium Designer
Compatible Products
[1] For Ixora V1.0A Capacitive Touch Adapter is required, V1.1A or above are directly compatible.
Revision History
Product Number (PID8) Format
Product Numbering Scheme
FieldDescription
Example
0029: Apalis iMX6D 512MB
00: Assembly Variant A
Ixora Carrier Board
PN: 0133
01331000
Ixora V1.0A
  • Initial Release
2013-09-26
PCN Ixora Carrier Board V1.0A 2017-03-06
01331100
Ixora V1.1A
  • Swap Apalis USBH2 with USBH3
  • Use Apalis MMC1 instead of SD1
  • Use new Micro SD cared holder (higher quality)
  • Use SD1 pins as GPIOs to control UART2/3_RS232_FOFF#, FACTORY_DEFAULT#, PCIE_WDISABLE#_R, LED_4_RED, and LED_4_GREEN (before MMC1 pins were used)
  • Add bias-circuit to the microphone input
  • Connect I2C to the LVDS connector X19 to support EDID
  • Add new connector X24 for capacitive touch controller support (compatibility with future Toradex display offerings)
  • Add CSI connector X28
  • Improve battery holder footprint
  • Added footprint for recovery mode jumper JP4 (not assembled)
  • Remove EEPROM (not assembled)
  • Remove CAN termination resistors
  • Change USB 5V regulator to supply the minimum requirement of 900mA as required by USB 3.0
  • Pull-up WAKE1_MICO# to 3.3V instead of 3.3V_SW
  • Increase the maximum power output (from 15W to 20W)
2017-03-24PCN Ixora Carrier Board V1.1A 2020-01-09
01331101
Ixora V1.1B
  • Interim product, only for the Apalis iMX8 Early Access
  • R9 changed to a 0Ω-resistor for sufficient power supply for the Apalis iMX8
2019-05-07Interim version, no PCN. For details of changes in V1.2A, see PCN of V1.1A
01331200
Ixora V1.2A
  • Updated Power Supply
  • EEPROM assembled by default
  • New Micro USB connector
  • New Ethernet connector for Industrial Temperature compliance
  • New Voltage Level translator and ESD protection solution on HDMI interface
  • Modified SD card circuit
  • Load switch ICs added to control CAN1 and CAN2 interface power rails
  • Additional capacitors C162, C163, C164, and C165 (not assembled by default) to 3.3V_PCIE1 and 3.3V_mSATA1 power rails
  • Shared pads resistors connected to SD1_CD# / MXM3_190 pin to eliminate false interrupts
  • Improved EMC design
2020-01-09PCN Ixora Carrier Board V1.2A 2023-01-04
01331300
Ixora V1.3A
  • Replaced the MXM3 socket for the Apalis SoM edge connector
  • Changed the HDMI ESD protection solution
  • Replaced the CAN power switches
  • Updated the USB design to meet the bulk capacitance requirements of the USB 3.1 specification
  • Added support for CAN FD
  • Improved the determinism of the POWER_ENABLE_MOCI signal
  • Modified the value of the USB power enable signals' pull-down resistors
  • Improved the ESD protection of various interfaces and features
  • Replaced the RS232 transceiver with a device that is not prone to backfeeding
  • Changed the HDMI connector to provide compliance with HDMI 2.0
  • Changed the rail of the WAKE1_MICO# signal
  • Other minor changes and improvements
Q2, 2023
Errata/Known issues
Errata Document
Ixora Carrier Board Errata
Migration in Progress
Issue trackers are not yet available in the new developer website. See it on the archived developer website.
