Aquila Heatsink Active
The Aquila Heatsink Active is a complete thermal solution for Aquila SoMs. Provided as a ready-to-assemble, vibration-resistant solution, it enables immediate deployment and also serves as a reference design for customers developing their own thermal strategies based on Aquila SoMs.
This page provides hardware design resources, documentation, revision history, erratas, compatibility details, and getting started guides for developers working with the Aquila SoM family.
Getting Started
Recommendation for the first-time order
Quickstart Guide
Check out our guide for detailed instructions on how to assemble the heatsink and get your board up and running with Torizon to achieve a faster time to market.
Having trouble?
Product Features
- Compatible with the Aquila AM69
- Contains the Thermal Interface Material (TIM) and come with a pre-mounted DC fan
- Easily mounted to Aquila Carrier Boards by means of 4 screws (M3x14mm)
Compatible Products
Product Documents
Aquila Heatsink Active V1.1
3D Mechanical Models
Aquila Heatsink Active V1.1 Mechanical Models
A basic 3D model for the Aquila Heatsink Active V1.1 can be downloaded here:
Revision History
Product Number (PID8) Format
| Field | Description |
Example
0029: Apalis iMX6D 512MB
00: Assembly Variant A
2314 Aquila Heatsink Active Type 1
| Product # | Product Description | Changes from Previous Version | Release Date | PCN Document |
| 23141000 | Aquila Heatsink Active Type 1 V1.0A | Initial Release | Q4, 2024 | |
| 23141100 | Aquila Heatsink Active Type 1 V1.1A |
| Q1, 2026 |
Errata
None
