Clover Carrier Board
(Double-Click to Zoom)
The Clover Carrier Board is a full-featured carrier board that gives you easy access to most of the interfaces of the Aquila System on Modules (SoMs), intended as a development/evaluation platform.
This page provides hardware design resources, documentation, revision history, erratas, compatibility details, and getting started guides for developers working with the Aquila SoM family.
Getting Started
Recommendation for the First-Time Order
Quickstart Guide
Check out our guide for detailed instructions on how to get your board up and running with Torizon:
Having trouble?
Product Features
Hardware Features
Compatible Products
Learn more on the Aquila Product Family Specification.
Accessories & Add-ons
Check other options and compatibility information on the add-ons product pages.
Block Diagram
Clover Carrier Board V1.0
Pinout Evaluation & Planning
Product Documents
Datasheets
Design Resources
The following early-access Altium files may have incomplete features, known or unknown issues, and unexpected behavior. They are shared to support development with the current hardware revision and should not be used as a final reference without careful review.
Clover Carrier Board Design Data V1.0
Design and Layout Guide
Software Ecosystem
Development Resources
Connecting to the Board
Revision History
Product Number (PID8) Format
Product Numbering Scheme
FieldDescription
Example
0029: Apalis iMX6D 512MB
00: Assembly Variant A
0179 Clover Carrier Board
Product #Product DescriptionChanges from Previous VersionRelease DateRelated Documents
01791000
Clover Carrier Board V1.0A
Initial Release
Q3 2025
01791001
Clover Carrier Board V1.0B
  • Series capacitors on USB_2_SS lines removed and replaced with 0R (R66 and R67)
  • R59 removed from VBUS line, and changed the value of R61 to 22Ohm
  • Change UART TX 3.3V pull-up to not assembled
Q2 2026
01791100
Clover Carrier Board V1.1A
  • Corrected the swapped ETH_2_XGMII signal lines, restoring the second Gigabit Ethernet interface, solving HAR-12346
  • Relocated the SIM card holder from the bottom side to the top side, at the board edge
  • Relocated the push buttons (S1/S2) and the JTAG connector from the top side to the bottom side
Q3 2026
Errata/Known Issues
Errata Document
Hardware Issue Tracker
