Colibri HDMI Adapter
Getting Started
The Colibri HDMI Adapter is an add-on board for the Colibri T20, Colibri T30, Colibri iMX6 and Colibri iMX8X (through Colibri iMX8X DSI to HDMI Adapter) computer-on-modules. It provides a very easy-to-use interface to connect a full HD monitor to the Colibri Module using HDMI interface.
End-user products providing a HDMI interface might be subject to HDMI royalty. Please check the HDMI website for details.
What I need to order
Colibri HDMI Adapter can be ordered along with any Colibri module mentioned above.
Where do I order
All the products can be ordered online at Toradex Webshop
Having trouble?
Features
Main Features
- Provides a HDMI interface for Colibri Txx, and Colibri iMX6 products
- Connects directly to the HDMI FFC connector on the Colibri module
- No external power supply
- 100 mm FFC Cable included
Datasheets
Colibri HDMI Adapter Datasheet
Design Resources
Design Data for Colibri HDMI Adapter
- Colibri HDMI Adapter Altium Project (Altium Designer Release 10)
- Colibri HDMI Adapter PDF Schematics
- Colibri HDMI Adapter Assembly Drawing
- Colibri HDMI Adapter Bill of Materials (BOM)
Mechanical Models
A basic 3D model for the Colibri HDMI Adapter can be downloaded here:
It is a generic STEP model that can be opened and modified in any 3D CAD.
It is a generic 3D pdf model that can be opened in Adobe Reader.
Altium Designer
Compatible Products
[1]: Colibri iMX8X is only compatible by using the Colibri iMX8X DSI to HDMI Adapter.
Revision History
Product Number (PID8) Format
| Field | Description |
Example
0029: Apalis iMX6D 512MB
00: Assembly Variant A
0114xxxx - Colibri HDMI Adapter
| Product # | Product Description | Changes from Previous Version | Release Date | PCN Document |
| 01141000 | Colibri HDMI Adapter V1.0A | Initial Release | 2014-12-15 |
Errata
None
