Colibri Evaluation Board
The Colibri Evaluation Board is a full-featured carrier board that gives you easy access to most of the interfaces of the Colibri System on Modules (SoMs), intended as an evaluation platform.
This page provides hardware design resources, documentation, revision history, erratas, compatibility details, and getting started guides for developers working with the Colibri SoM family.
Getting Started
Recommendation for the First-Time Order
Quickstart Guide
Check out our guide for detailed instructions on how to get your board up and running with Torizon:
Having trouble?
Product Features
Hardware Features
Compatible Products
- Colibri iMX8X
- Colibri iMX6ULL
- Colibri iMX7
- Colibri iMX6
- Colibri VF61
- Colibri VF50
- Colibri T30
- Colibri T20
- Colibri PXA320
- Colibri PXA310
- Colibri PXA270
Accessories & Add-ons
- EDT Display
- Carrier Board Accessory Kit
- Colibri Fastener
- Capacitive Touch Display 7" Parallel [1]
- Resistive Touch Display 7" Parallel
- LM816 USB WiFi
- Analogue Camera Adapter
[1] Capacitive Touch Adapter is required.
Check other options and compatibility information on the add-ons product pages.
Block Diagram
Pinout Evaluation & Planning
Product Documents
Datasheets
Colibri Evaluation Board V3.2
Archive
Design Resources
Colibri Evaluation Board Design Data V3.2
- Colibri Evaluation Board Altium Project (Altium Designer Release 10)
- Colibri Evaluation Board PDF Schematics
- Colibri Evaluation Board Assembly Drawing
- Colibri Evaluation Board Bill of Materials (BOM)
Colibri Evaluation Board Design Data Archive
- Colibri Evaluation Altium Project
- Colibri Evaluation Board Schematics
- Colibri Evaluation Assembly Drawings
Colibri Evaluation Board Mechanical Models
A basic 3D model for the Colibri Evaluation Board can be downloaded here:
Design and Layout Guide
Altium Designer
Software Ecosystem
Torizon OS - open source, easy to use industrial Linux operating system
Yocto Project Reference Images - reference images for Yocto Project, a great starting point for customized Linux images
Development Resources
Connecting to the Board
Revision History
Product Number (PID8) Format
| Field | Description |
Example
0029: Apalis iMX6D 512MB
00: Assembly Variant A
0101 Colibri Evaluation Board
| Product # | Product Description | Changes from Previous Version | Release Date | PCN Document |
| 01012102 | Colibri Evaluation Board V2.1C | Initial Version | 2006 | PCN Colibri Evaluation Board V2.1C 2012-09-21 |
| 01013100 | Colibri Evaluation Board V3.1A | - Rearranged many connectors - Support for USB 2.0 HighSpeed - Support for DVI-I - Support for LVDS - Support for RS422/485 - Changed CAN controller, using SPI now - Removed PCMCIA interface (CF-Card) | 2012-09-12 | Evaluation Product, No PCN |
| 01013200 | Colibri Evaluation Board V3.2A | Improved flexibility: - Added jumper for CAN RX and TX - Added jumper for Ethernet TX Center Tap - Connected RTS and CTS of the debug serial port to the USB to Serial port (X27) - Camera Interface connector X22 pin-out has been updated to be compatible with Apalis Evaluation Board | 2014-11-30 | PCN Colibri Evaluation Board V3.2A 2016-06-03 |
| 01013201 | Colibri Evaluation Board V3.2B | - Correction of Errata: Correct Audio Connector (X26) assembled | 2016-03-11 |
