Iris Carrier Board
Getting Started
Toradex recommends to order the following additional products for your fist-time order:
Getting started for the first time?
For detailed step-by-step instructions about how to start with both, SoM and Carrier Board, please have a look at our step-by-step Getting-Started Guide:
Product-specific information for the Iris Carrier Board:
Having trouble?
Features
I/O Support
- USB 2.0 (1x Host, 1x OTG)
- I2C (1x)
- SPI (1x)
- UART (3x RS232)
- PWM (4x)
- GPIO (up to 26)
- Analog Input (4x)
- Ethernet (1x 10/100 Mbit)
- SDIO/SD/MMC (1x 4 Bit MicroSD)
- LVDS (1x Single Channel)
- HDMI (1x, Through DVI-I connector)
- VGA (1x, Through DVI-I connector)
- RGB (1x 18 Bit)
- Resistive Touch (4/5-wire)
- Analog Audio Line in (1x)
- Analog Audio Mic in (1x)
- Analog Audio Headphone out (1x)
Block Diagram
* This is a module-specific feature and may not be supported by all the computer-on-modules in the Colibri family. For more details, refer to the datasheet of Colibri computer-on-modules.
Datasheets
Iris Carrier Board V2.0
Iris Carrier Board V2.0 Datasheet
Iris Carrier Board V1.1
Iris Carrier Board V1.1 Datasheet
Components
Design Resources
Iris Carrier Board Design Data V2.0
- Iris Carrier Board Altium Project (Altium Designer Release 10)
- Iris Carrier Board PDF Schematics
- Iris Carrier Board Assembly Drawing
- Iris Carrier Board Bill of Materials (BOM)
Iris Carrier Board Design Data V1.1
Please also have a look at the Iris Carrier Board Errata Document
Iris Carrier Board Mechanical Models
A basic 3D model for the Iris carrier board can be downloaded here:
Design and Layout Guide
Altium Designer
Compatible Products
- Colibri iMX8X
- Colibri iMX7
- Colibri iMX6
- Colibri iMX6ULL
- Colibri VF61
- Colibri VF50
- Colibri T30
- Colibri T20
- Colibri PXA320
- Colibri PXA310
- Colibri PXA270
- Capacitive Touch Display 7" Parallel [1]
- Resistive Touch Display 7" Parallel
- Capacitive Touch Display 10.1" LVDS [2]
- EDT Display
- Carrier Board Accessory Kit
- Colibri Fastener
- LM816 USB WiFi
[1] Capacitive Touch Adapter is required for Iris V1.1A and V1.1B, but is not required for V2.0 onwards.
[2] The LVDS cable that comes with the Capacitive Touch Display 10.1" LVDS is only compatible with Iris V2.0 onward. The LVDS signal on Iris is provided through an RGB to LVDS transmitter.
Revision History
Product Number (PID8) Format
| Field | Description |
Example
0029: Apalis iMX6D 512MB
00: Assembly Variant A
Iris Carrier Board
PN: 0135
| Product # | Product Description | Changes from Previous Version | Release Date | PCN Document |
01351000 | Iris Carrier Board- V1.0A | Sample Version | 2011-04-05 | Sample Product, No PCN |
01351100 | Iris Carrier Board- V1.1A | Volume Production Version | 2011-07-20 | PCN Iris V1.1A 2017-06-20 |
01351101 | Iris Carrier Board V1.1B | Change of micro SD card holder | July 2017 | |
01352000 | Iris Carrier Board V2.0A |
| 2019-12-12 | PCN Iris V2.0A 2023-03-28 |
01352001 | Iris Carrier Board V2.0B |
| Q2/2023 |
Errata/Known issues
Errata Document
Issue trackers are not yet available in the new developer website. See it on the archived developer website.
