MAC Address
A MAC address is used to identify computers on the network. On SoMs, the MAC address is stored in the flash memory. This article explains how to obtain the MAC address of SoMs by only using their serial numbers, even when the module has two Ethernet ports.
If you want to get and customize MAC addresses of a SoM running Linux, check the Network on Toradex SoMs guide.
Serial Number and MAC Address Relationship
For SoMs, serial numbers are unique and also contain MAC address information. The MAC address has the first 3 bytes fixed (Toradex OUI range):
00:14:2D:XX:XX:XXfor serial numbers lower than16777216.8C:06:CB:XX:XX:XXfor serial numbers ranging from16777216to33554431.
The three least significant bytes represent the serial number in hexadecimal. For instance, for the serial number 02226142, the corresponding MAC address would be 00:14:2D:21:F7:DE.
Second Ethernet Port
Some SoMs feature two Ethernet ports. To obtain the second MAC address, add 0x100000 to the serial number.
00:14:2D:21:F7:DE → 00:14:2D:(21+10):F7:DE → 00:14:2D:31:F7:DE
MAC Address Calculator
To compute your SoM's MAC address, enter its serial number below:
First MAC Address
XX:XX:XX:XX:XX:XX
Second MAC Address
XX:XX:XX:XX:XX:XX
(if available)
