Reset State of the i.MX 8/8X SoC Pins
The reset states of the GPIO pins of the i.MX 8 and i.MX 8X SoCs have been documented in the datasheets of the Apalis iMX8, Colibri iMX8X, and Apalis iMX8X modules.
However, the i.MX 8/8X SoCs feature a System Controller Unit (SCU) that handles all of the pin configurations. The SCU comes with firmware (SCFW) that has its own default pin configurations. By the time of the release of the RESET_MOCI# signal, the SCU already overrides the pin configurations. Therefore, the SCU default settings are the relevant reset states for the pins. In the case of some of the GPIO-capable pins, the SCFW reset states are different from the register reset states.
The Apalis iMX8, Colibri iMX8X, and Apalis iMX8X module datasheets have been updated to these values, please have more information for each one of the modules below:
- Apalis iMX8 Datasheet (starting from revision 1.2)
- Colibri iMX8X (starting from revision 0.98)
- Apalis iMX8X (starting from revision 1.8)
This document compares the reset state previously stated in the datasheet (SoC's register reset state) with the relevant SCUFW reset state.
This article applies to the following Toradex SoMs:
Reset state
Reset state comparison
Abbreviations:
PD: Pull-down PU: Pull-up
- Apalis iMX8
- Colibri iMX8X
- Apalis iMX8X
Apalis iMX8
| X1 Pin | i.MX 8 Ball Name | Apalis Signal Name | Reset State (Register) | Reset State (SCFW) | Differ |
| 1 | M40_GPIO0_00 | GPIO1 | PD | PD | - |
| 3 | M40_GPIO0_01 | GPIO2 | PD | PD | - |
| 5 | M41_GPIO0_00 | GPIO3 | PD | PD | - |
| 7 | M41_GPIO0_01 | GPIO4 | PD | PD | - |
| 11 | FLEXCAN2_RX | GPIO5 | PD | PD | - |
| 13 | FLEXCAN2_TX | GPIO6 | Drive-1 | PD | Yes |
| 15 | MLB_SIG | GPIO7 | PD | PD | - |
| 17 | MLB_DATA | GPIO8 | PD | PD | - |
| 35 | ESAI1_TX0 | SATA1_ACT# | PD | PD | - |
| 37 | SPI3_CS0 | WAKE1_MICO | PD | PD | - |
| 63 | MLB_CLK | TS_1 | PD | PD | - |
| 87 | LVDS0_I2C0_SCL | TS_2 | PD | PU | Yes |
| 99 | LVDS0_I2C0_SDA | TS_3 | PD | PU | Yes |
| 123 | MIPI_DSI1_GPIO0_00 | TS_4 | PD | PD | - |
| 135 | SIM0_IO | TS_5 | Drive-0 | PD | Yes |
| 159 | USDHC1_STROBE | TS_6 | PD | PU | Yes |
| 173 | MIPI_DSI1_I2C0_SCL | CAM1_D7 | PD | PU | Yes |
| 175 | MIPI_DSI1_I2C0_SDA | CAM1_D6 | PD | PU | Yes |
| 177 | ESAI0_TX0 | CAM1_D5 | PD | PD | - |
| 179 | ESAI0_TX1 | CAM1_D4 | PD | PD | - |
| 181 | ESAI0_TX2_RX3 | CAM1_D3 | PD | PD | - |
| 183 | ESAI0_TX3_RX2 | CAM1_D2 | PD | PD | - |
| 185 | ESAI0_TX4_RX1 | CAM1_D1 | PD | PD | - |
| 187 | ESAI0_TX5_RX0 | CAM1_D0 | PD | PD | - |
| 191 | MCLK_IN0 | CAM1_PCLK | PD | PD | - |
| 193 | SPI3_SDO | CAM1_MCLK | Drive-1 | PD | Yes |
| 195 | ESAI0_SCKR | CAM1_VSYNC | PD | PD | - |
| 197 | ESAI0_SCKT | CAM1_HSYNC | PD | PD | - |
| 201 | SIM0_POWER_EN | I2C3_SDA (CAM) | Drive-0 | PD | Yes |
| 203 | SIM0_PD | I2C3_SCL (CAM) | PD | PD | - |
| 209 | GPT1_CAPTURE | I2C1_SDA | PD | PD | - |
| 211 | GPT1_CLK | I2C1_SCL | PD | PD | - |
| 215 | SPDIF0_TX | SPDIF1_OUT | Drive-0 | PD | Yes |
| 217 | SPDIF0_RX | SPDIF1_IN | PD | PD | - |
| 221 | SPI0_SCK | SPI1_CLK | PD | PD | - |
| 223 | SPI0_SDI | SPI1_MISO | PD | PD | - |
| 225 | SPI0_SDO | SPI1_MOSI | Drive-1 | PD | Yes |
| 227 | SPI0_CS0 | SPI1_CS | PD | PD | - |
| 229 | SPI2_SDI | SPI2_MISO | PD | PD | - |
| 231 | SPI2_SDO | SPI2_MOSI | Drive-1 | PD | Yes |
| 233 | SPI2_CS0 | SPI2_CS | PD | PD | - |
| 235 | SPI2_SCK | SPI2_CLK | PD | PD | - |
| 239 | LVDS1_GPIO00 | BKL1_PWM | PD | PD | - |
| 243 | ENET1_RGMII_RXD3 | LCD1_PCLK | PD | PD | - |
| 245 | ENET1_RGMII_RXD2 | LCD1_VSYNC | PD | PD | - |
| 247 | ENET1_RGMII_RXD1 | LCD1_HSYNC | PD | PD | - |
| 249 | ENET1_RGMII_RXD0 | LCD1_DE | PD | PD | - |
| 251 | ENET1_MDIO | LCD1_R0 | PD | PU | Yes |
| 253 | ENET1_MDC | LCD1_R1 | Drive-0 | PD | Yes |
| 255 | ENET1_RGMII_TXD2 | LCD1_R2 | Drive-0 | PD | Yes |
| 257 | ENET1_RGMII_TXD1 | LCD1_R3 | Drive-0 | PD | Yes |
| 259 | ENET1_RGMII_TXD0 | LCD1_R4 | Drive-0 | PD | Yes |
| 261 | ENET1_RGMII_TXC | LCD1_R5 | Drive-0 | PD | Yes |
| 263 | ENET1_RGMII_TX_CTL | LCD1_R6 | Drive-0 | PD | Yes |
| 265 | ENET1_RGMII_RX_CTL | LCD1_R7 | PD | PD | - |
| 269 | ENET1_REFCLK_125M_25M | LCD1_G0 | Drive-0 | PD | Yes |
| 271 | ESAI0_FSR | LCD1_G1 | PD | PD | - |
| 273 | ESAI0_FST | LCD1_G2 | PD | PD | - |
| 275 | SIM0_GPIO0_00 | LCD1_G3 | Drive-0 | PD | Yes |
| 277 | SIM0_RST | LCD1_G4 | Drive-0 | PD | Yes |
| 279 | SIM0_CLK | LCD1_G5 | Drive-0 | PD | Yes |
| 281 | LVDS1_I2C0_SCL | LCD1_G6 | PD | PU | Yes |
| 283 | LVDS1_I2C0_SDA | LCD1_G7 | PD | PU | Yes |
| 287 | QSPI1A_DATA0 | LCD1_B0 | PD | PD | - |
| 289 | QSPI1A_DATA1 | LCD1_B1 | PD | PD | - |
| 291 | QSPI1A_DATA2 | LCD1_B2 | PD | PD | - |
| 293 | QSPI1A_DATA3 | LCD1_B3 | PD | PD | - |
| 295 | QSPI1A_SS0_B | LCD1_B4 | PD | PU | Yes |
| 297 | QSPI1A_DQS | LCD1_B5 | PD | PD | - |
| 299 | QSPI1A_SS1_B | LCD1_B6 | PD | PU | Yes |
| 301 | QSPI1A_SCLK | LCD1_B7 | PD | PD | - |
| 305 | ADC_IN0 | AN1_ADC0 | PD | PD | - |
| 307 | ADC_IN1 | AN1_ADC1 | PD | PD | - |
| 309 | ADC_IN2 | AN1_ADC2 | PD | PD | - |
| 311 | ADC_IN3 | AN1_TSWIP_ADC3 | PD | PD | - |
| 315 | ADC_IN4 | AN1_TSPX | PD | PD | - |
| 317 | ADC_IN5 | AN1_TSMX | PD | PD | - |
| 319 | ADC_IN6 | AN1_TSPY | PD | PD | - |
| 321 | ADC_IN7 | AN1_TSMY | PD | PD | - |
| 2 | GPT1_COMPARE | PWM1 | PD | PD | - |
| 4 | GPT0_COMPARE | PWM2 | PD | PD | - |
| 6 | UART0_RTS_B | PWM3 | Drive-1 | PD | Yes |
| 8 | UART0_CTS_B | PWM4 | PD | PD | - |
| 12 | FLEXCAN0_RX | CAN1_RX | PD | PD | - |
| 14 | FLEXCAN0_TX | CAN1_TX | Drive-1 | PD | Yes |
| 16 | FLEXCAN1_RX | CAN2_RX | PD | PD | - |
| 18 | FLEXCAN1_TX | CAN2_TX | Drive-1 | PD | Yes |
| 84 | USB_SS3_TC1 | USBH_EN | PD | PU | Yes |
| 96 | USB_SS3_TC3 | USBH_OC# | PD | PU | Yes |
| 110 | M40_I2C0_SCL | UART1_DTR | PD | PU | Yes |
| 112 | UART1_TX | UART1_TXD | Drive-1 | PD | Yes |
| 114 | UART1_RTS_B | UART1_RTS | Drive-1 | PD | Yes |
| 116 | UART1_CTS_B | UART1_CTS | PD | PD | - |
| 118 | UART1_RX | UART1_RXD | PD | PD | - |
| 120 | M40_I2C0_SDA | UART1_DSR | PD | PU | Yes |
| 122 | M41_I2C0_SDA | UART1_RI | PD | PU | Yes |
| 124 | M41_I2C0_SCL | UART1_DCD | PD | PU | Yes |
| 126 | LVDS1_I2C1_SCL | UART2_TXD | PD | PU | Yes |
| 128 | ENET1_RGMII_TXD3 | UART2_RTS | Drive-0 | PD | Yes |
| 130 | ENET1_RGMII_RXC | UART2_CTS | PD | PD | - |
| 132 | LVDS1_I2C1_SDA | UART2_RXD | PD | PU | Yes |
| 134 | UART0_TX | UART3_TXD | Drive-1 | PD | Yes |
| 136 | UART0_RX | UART3_RXD | PD | PD | - |
| 138 | LVDS0_I2C1_SCL | UART4_TXD | PD | PU | Yes |
| 140 | LVDS0_I2C1_SDA | UART4_RXD | PD | PU | Yes |
| 144 | USDHC1_DATA2 | MMC1_D2 | PD | PU | Yes |
| 146 | USDHC1_DATA3 | MMC1_D3 | PD | PU | Yes |
| 148 | USDHC1_DATA4 | MMC1_D4 | PD | PU | Yes |
| 150 | USDHC1_CMD | MMC1_CMD | PD | PD | - |
| 152 | USDHC1_DATA5 | MMC1_D5 | PD | PU | Yes |
| 154 | USDHC1_CLK | MMC1_CLK | Drive-0 | Drive-0 | - |
| 156 | USDHC1_DATA6 | MMC1_D6 | PD | PU | Yes |
| 158 | USDHC1_DATA7 | MMC1_D7 | PD | PU | Yes |
| 160 | USDHC1_DATA0 | MMC1_D0 | PD | PU | Yes |
| 162 | USDHC1_DATA1 | MMC1_D1 | PD | PU | Yes |
| 164 | ESAI1_TX1 | MMC1_CD# | PD | PD | - |
| 176 | USDHC2_DATA2 | SD1_D2 | PD | PU | Yes |
| 178 | USDHC2_DATA3 | SD1_D3 | PD | PU | Yes |
| 180 | USDHC2_CMD | SD1_CMD | PD | PD | - |
| 184 | USDHC2_CLK | SD1_CLK | Drive-0 | PD | Yes |
| 186 | USDHC2_DATA0 | SD1_D0 | PD | PU | Yes |
| 188 | USDHC2_DATA1 | SD1_D1 | PD | PU | Yes |
| 190 | USDHC2_CD_B | SD1_CD# | PD | PU | Yes |
| 194 | SPI3_SDI | DAP1_MCLK | PD | PD | - |
| 196 | SAI1_RXC | DAP1_D_OUT | PD | PD | - |
| 198 | ESAI1_SCKT | DAP1_RESET | PD | PD | - |
| 200 | SPI0_CS1 | DAP1_BIT_CLK | PD | PD | - |
| 202 | SAI1_RXFS | DAP1_D_IN | PD | PD | - |
| 204 | SPI2_CS1 | DAP1_SYNC | PD | PD | - |
| 262 | USB_SS3_TC2 | USBO1_OC# | PD | PU | Yes |
| 274 | USB_SS3_TC0 | USBO1_EN | PD | PU | Yes |
| 286 | LVDS0_GPIO00 | BKL1_ON | PD | PD | - |
Impacts on Toradex Carrier Boards
Four pins could have the following impact with the Toradex carrier boards:
| Pin | Difference | Effect |
| USBO1_EN | pulled-up instead of pulled-down | The USB power gets enabled during reset |
| USBH_EN | pulled-up instead of pulled-down | Depending on the carrier board, the USB power gets enabled during the reset |
| MMC1_D5 | pulled-up instead of pulled-down | On Ixora, this pin is used for driving an LED (LED5_GREEN). This LED could be lit during the reset state |
| MMC1_D6 | pulled-up instead of pulled-down | On Ixora, this pin is used for driving an LED (LED5_RED). This LED could be lit during the reset state |
Colibri iMX8X
| X1 Pin | i.MX 8X Ball Name | Colibri Signal Name | Reset State (Register) | Reset State (SCFW) | Differ |
| 19 | UART2_RX | UART_C_RXD | PD | PD | - |
| 21 | UART2_TX | UART_C_TXD | PD | PD | - |
| 23 | MIPI_DSI1_GPIO0_01 | UART_A_DTR | PD | PD | - |
| 25 | SAI1_RXD | UART_A_CTS | PD | PD | - |
| 27 | SAI1_RXC | UART_A_RTS, SSPSYSCLK | PD | PD | - |
| 29 | CSI_RESET | UART_A_DSR | PD | PD | - |
| 31 | USDHC1_CD_B | UART_A_DCD | PU | PU | - |
| 33 | FLEXCAN2_RX | UART_A_RXD | PD | PD | - |
| 35 | FLEXCAN2_TX | UART_A_TXD | PD | PD | - |
| 37 | CSI_EN | UART_A_RI | PD | PD | - |
| 43 | QSPI0A_DATA0 | GPIO: MMCD, WAKEUP Source0 | PD | PD | - |
| 45 | QSPI0A_DATA1 | GPIO: PRDY, WAKEUP Source1 | PD | PD | - |
| 47 | USDHC1_CLK | MMC_CLK | PD | PD | - |
| 49 | USDHC1_DATA1 | MMC_DAT1 | PU | PU | - |
| 51 | USDHC1_DATA2 | MMC_DAT2 | PU | PU | - |
| 53 | USDHC1_DATA3 | MMC_DAT3 | PU | PU | - |
| 55 | FLEXCAN1_TX | GPIO: PS2.SDA1 | PD | PD | - |
| 57 | SPI3_CS1 | LDD<16> | PD | PD | - |
| 57 | ENET0_RGMII_TXD2 | LDD<16> | PD | PD | - |
| 59 | SPI0_CS1 | PWM<A>/VID7 | PD | PD | - |
| 59 | CSI_D05 | PWM<A>/VID7 | PD | PD | - |
| 61 | UART1_CTS_B | LDD<17> | PD | PD | - |
| 63 | FLEXCAN1_RX | GPIO: PS2.SCL1 | PD | PD | - |
| 65 | CSI_D07 | GPIO: PS2.SDA2/VID9 | PD | PD | - |
| 65 | ENET0_RGMII_TXD3 | GPIO: PS2.SDA2/VID9 | PD | PD | - |
| 67 | UART1_RTS_B | PWM<D>/VID6 | PD | PD | - |
| 67 | CSI_D04 | PWM<D>/VID6 | PD | PD | - |
| 69 | QSPI0A_DATA2 | GPIO: PS2.SCL2/VID10 | PD | PD | - |
| 71 | QSPI0A_DATA3 | GPIO: BL_ON/VID0 | PD | PD | - |
| 73 | QSPI0A_DQS | GPIO: CAN_INT | PD | PD | - |
| 75 | CSI_MCLK | GPIO: PRST/VIDMCLK | PD | PD | - |
| 79 | SAI0_TXC | GPIO: PBVD1/VID4 | PD | PD | - |
| 79 | CSI_D02 | GPIO: PBVD1/VID4 | PD | PD | - |
| 81 | CSI_VSYNC | GPIO: PCD/VIDVSYNC | PD | PD | - |
| 81 | PCIE_CTRL0_PERST_B | GPIO: PCD/VIDVSYNC | PD | PD | - |
| 85 | CSI_D06 | GPIO: nPPEN/VID8 | PD | PD | - |
| 85 | ENET0_RGMII_RXC | GPIO: nPPEN/VID8 | PD | PD | - |
| 95 | QSPI0B_SCLK | RDY | PD | PD | - |
| 97 | SAI0_RXD | nPOE/VID5 | PD | PD | - |
| 97 | CSI_D03 | nPOE/VID5 | PD | PD | - |
| 99 | QSPI0B_DATA0 | nPWE | PD | PD | - |
| 101 | SAI0_TXFS | nPIOW/VID2 | PD | PD | - |
| 101 | CSI_D00 | nPIOW/VID2 | PD | PD | - |
| 103 | SAI0_TXD | nPIOR/VID3 | PD | PD | - |
| 103 | CSI_D01 | nPIOR/VID3 | PD | PD | - |
| 105 | QSPI0B_DATA1 | nCS_CAN | PD | PD | - |
| 107 | QSPI0B_DATA2 | nEXT_CS1 | PD | PD | - |
| 127 | USB_SS3_TC2 | GPIO: EXT_IO2 | PU | PD | Yes |
| 129 | USB_SS3_TC0 | USBH_PEN | PD | PD | - |
| 131 | USB_SS3_TC3 | USBH_OC | PU | PD | Yes |
| 133 | USB_SS3_TC1 | GPIO: EXT_IO1 | PD | PD | - |
| 135 | ENET0_RGMII_RXD3 | GPIO: EXT_IO0 / USB_ID/SPDIF_IN | PD | PD | - |
| 137 | ENET0_REFCLK_125M_25M | GPIO: USBC_DET(VBUS)/SPDIF/OUT | PD | PD | - |
| 2 | ADC_IN5 | AD3 | PD | PD | - |
| 4 | ADC_IN4 | AD2 | PD | PD | - |
| 6 | ADC_IN1 | AD1 | PD | PD | - |
| 8 | ADC_IN0 | AD0 | PD | PD | - |
| 28 | UART1_TX | PWM<B> | PD | PD | - |
| 30 | UART1_RX | PWM<C> | PD | PD | - |
| 32 | FLEXCAN0_TX | UART_B_CTS | PD | PD | - |
| 34 | FLEXCAN0_RX | UART_B_RTS | PD | PD | - |
| 36 | UART0_RX | UART_B_RXD | PD | PD | - |
| 38 | UART0_TX | UART_B_TXD | PD | PD | - |
| 44 | MCLK_IN1 | L_BIAS | PD | PD | - |
| 44 | USDHC1_RESET_B | L_BIAS | PU | PU | - |
| 46 | ESAI0_TX3_RX2 | LDD<7> | PD | PD | - |
| 48 | ESAI0_TX5_RX0 | LDD<9> | PD | PD | - |
| 50 | SPDIF0_TX | LDD<11> | PD | PD | - |
| 52 | SPDIF0_EXT_CLK | LDD<12> | PD | PD | - |
| 54 | SPI3_SCK | LDD<13> | PD | PD | - |
| 56 | MCLK_OUT0 | L_PCLK_WR | PD | PD | - |
| 58 | ESAI0_SCKT | LDD<3> | PD | PD | - |
| 60 | ESAI0_SCKR | LDD<2> | PD | PD | - |
| 62 | ESAI0_TX4_RX1 | LDD<8> | PD | PD | - |
| 64 | SPI3_SDI | LDD<15> | PD | PD | - |
| 66 | SPI3_SDO | LDD<14> | PD | PD | - |
| 68 | SPI3_CS0 | L_LCLK_A0 | PD | PD | - |
| 70 | ESAI0_FST | LDD<1> | PD | PD | - |
| 72 | ESAI0_TX1 | LDD<5> | PD | PD | - |
| 74 | SPDIF0_RX | LDD<10> | PD | PD | - |
| 76 | ESAI0_FSR | LDD<0> | PD | PD | - |
| 76 | USDHC1_WP | LDD<0> | PD | PD | - |
| 78 | ESAI0_TX0 | LDD<4> | PD | PD | - |
| 80 | ESAI0_TX2_RX3 | LDD<6> | PD | PD | - |
| 82 | MCLK_IN0 | L_FCLK_RD | PD | PD | - |
| 86 | SPI2_CS0 | SSPFRM | PD | PD | - |
| 88 | SPI2_SCK | SPSCLK | PD | PD | - |
| 90 | SPI2_SDI | SSPRXD | PD | PD | - |
| 92 | SPI2_SDO | SSPTXD | PD | PD | - |
| 94 | CSI_HSYNC | nPCE1/VIDHSYNC | PD | PD | - |
| 94 | PCIE_CTRL0_WAKE_B | nPCE1/VIDHSYNC | PU | PU | - |
| 96 | CSI_PCLK | nPCE2/VIDPCLK | PD | PD | - |
| 98 | QSPI0B_DATA3 | nPREG/VID1 | PD | PD | - |
| 100 | SAI1_RXFS | nPXCVREN | PD | PD | - |
| 102 | QSPI0B_DQS | nPWAIT | PD | PD | - |
| 104 | QSPI0B_SS0_B | nIOIS16 | PU | PU | - |
| 106 | QSPI0B_SS1_B | nEXT_CS2 | PU | PU | - |
| 144 | SCU_GPIO0_00 | ADDRESS20/LCD_R0 | PD | PD | - |
| 146 | SCU_GPIO0_01 | ADDRESS19/LCD_R1 | PU | PU | - |
| 178 | PCIE_CTRL0_CLKREQ_B | DATA30 | PD | PD | - |
| 180 | ENET0_MDIO | DATA31 | PU | PU | - |
| 184 | ENET0_MDC | ADDRESS18 | PD | PD | - |
| 190 | USDHC1_CMD | MMC_CMD | PU | PU | - |
| 192 | USDHC1_DATA0 | MMC_DAT0 | PU | PU | - |
| 194 | MIPI_DSI0_GPIO0_01 | I2C_SDA | PD | PD | - |
| 196 | MIPI_DSI0_GPIO0_00 | I2C_SCL | PD | PD | - |
Apalis iMX8X
| X1 Pin | i.MX 8X Ball Name | Apalis Signal Name | Reset State (Register) | Reset State (SCFW) | Differ |
| 11 | QSPI0B_SCLK | GPIO5 | PD | PD | - |
| 13 | QSPI0B_DATA0 | GPIO6 | PD | PD | - |
| 35 | MIPI_DSI0_I2C0_SCL | SATA1_ACT# | PU | PU | - |
| 37 | MIPI_DSI0_I2C0_SDA | WAKE1_MICO | PU | PU | - |
| 173 | CSI_D07 | CAM1_D7 | PD | PD | - |
| 175 | CSI_D06 | CAM1_D6 | PD | PD | - |
| 177 | CSI_D05 | CAM1_D5 | PD | PD | - |
| 179 | CSI_D04 | CAM1_D4 | PD | PD | - |
| 181 | CSI_D03 | CAM1_D3 | PD | PD | - |
| 183 | CSI_D02 | CAM1_D2 | PD | PD | - |
| 185 | CSI_D01 | CAM1_D1 | PD | PD | - |
| 187 | CSI_D00 | CAM1_D0 | PD | PD | - |
| 191 | CSI_PCLK | CAM1_PCLK | PD | PD | - |
| 193 | CSI_MCLK | CAM1_MCLK | PD | PD | - |
| 195 | CSI_VSYNC | CAM1_VSYNC | PD | PD | - |
| 197 | CSI_HSYNC | CAM1_HSYNC | PD | PD | - |
| 201 | CSI_RESET | I2C3_SDA (CAM) | PD | PD | - |
| 203 | CSI_EN | I2C3_SCL (CAM) | PD | PD | - |
| 205 | MIPI_DSI1_I2C0_SDA | I2C2_SDA (DDC) | PU | PU | - |
| 207 | MIPI_DSI1_I2C0_SCL | I2C2_SCL (DDC) | PU | PU | - |
| 209 | USB_SS3_TC3 | I2C1_SDA | PU | PD | Yes |
| 211 | USB_SS3_TC0 | I2C1_SCL | PD | PD | - |
| 225 | SPI0_SDO | SPI1_MOSI | PD | PD | - |
| 229 | SPI2_SCK | SPI2_MISO | PD | PD | - |
| 231 | SPI2_SDI | SPI2_MOSI | PD | PD | - |
| 233 | SPI2_SDO | SPI2_CS | PD | PD | - |
| 235 | SPI2_CS0 | SPI2_CLK | PD | PD | - |
| 239 | MIPI_DSI1_GPIO0_00 | BKL1_PWM | PD | PD | - |
| 243 | MCLK_OUT0 | LCD1_PCLK | PD | PD | - |
| 245 | MCLK_IN0 | LCD1_VSYNC | PD | PD | - |
| 247 | SPI3_CS0 | LCD1_HSYNC | PD | PD | - |
| 249 | MCLK_IN1 | LCD1_DE | PD | PD | - |
| 255 | SPDIF0_EXT_CLK | LCD1_R2 | PD | PD | - |
| 257 | SPI3_SCK | LCD1_R3 | PD | PD | - |
| 259 | SPI3_SDO | LCD1_R4 | PD | PD | - |
| 261 | SPI3_SDI | LCD1_R5 | PD | PD | - |
| 263 | SPI3_CS1 | LCD1_R6 | PD | PD | - |
| 265 | UART1_CTS_B | LCD1_R7 | PD | PD | - |
| 273 | ESAI0_TX2_RX3 | LCD1_G2 | PD | PD | - |
| 275 | ESAI0_TX3_RX2 | LCD1_G3 | PD | PD | - |
| 277 | ESAI0_TX4_RX1 | LCD1_G4 | PD | PD | - |
| 279 | ESAI0_TX5_RX0 | LCD1_G5 | PD | PD | - |
| 281 | SPDIF0_RX | LCD1_G6 | PD | PD | - |
| 283 | SPDIF0_TX | LCD1_G7 | PD | PD | - |
| 291 | ESAI0_FSR | LCD1_B2 | PD | PD | - |
| 293 | ESAI0_FST | LCD1_B3 | PD | PD | - |
| 295 | ESAI0_SCKR | LCD1_B4 | PD | PD | - |
| 297 | ESAI0_SCKT | LCD1_B5 | PD | PD | - |
| 299 | ESAI0_TX0 | LCD1_B6 | PD | PD | - |
| 301 | ESAI0_TX1 | LCD1_B7 | PD | PD | - |
| 309 | ADC_IN4 | AN1_ADC2 | PD | PD | - |
| 311 | ADC_IN5 | AN1_TSWIP_ADC3 | PD | PD | - |
| 2 | UART1_RTS_B | PWM1 | PD | PD | - |
| 4 | MIPI_DSI0_GPIO0_00 | PWM2 | PD | PD | - |
| 6 | MIPI_DSI0_GPIO0_01 | PWM3 | PD | PD | - |
| 8 | MIPI_DSI1_GPIO0_01 | PWM4 | PD | PD | - |
| 12 | FLEXCAN1_RX | CAN1_RX | PD | PD | - |
| 14 | FLEXCAN1_TX | CAN1_TX | PD | PD | - |
| 16 | FLEXCAN2_RX | CAN2_RX | PD | PD | - |
| 18 | FLEXCAN2_TX | CAN2_TX | PD | PD | - |
| 84 | USB_SS3_TC1 | USBH_EN | PD | PD | - |
| 96 | QSPI0A_DATA0 | USBH_OC# | PD | PD | - |
| 112 | UART1_TX | UART1_TXD | PD | PD | - |
| 114 | QSPI0A_DATA2 | UART1_RTS | PD | PD | - |
| 116 | QSPI0A_DATA3 | UART1_CTS | PD | PD | - |
| 126 | UART0_TX | UART2_TXD | PD | PD | - |
| 128 | FLEXCAN0_RX | UART2_RTS | PD | PD | - |
| 130 | FLEXCAN0_TX | UART2_CTS | PD | PD | - |
| 132 | UART0_RX | UART2_RXD | PD | PD | - |
| 134 | UART2_TX | UART3_TXD | PD | PD | - |
| 136 | UART2_RX | UART3_RXD | PD | PD | - |
| 138 | SCU_GPIO0_01 | UART4_TXD | PU | PU | - |
| 140 | SCU_GPIO0_00 | UART4_RXD | PD | PD | - |
| 144 | USDHC1_DATA2 | MMC1_D2 | PU | PU | - |
| 146 | USDHC1_DATA3 | MMC1_D3 | PU | PU | - |
| 148 | QSPI0A_DATA1 | MMC1_D4 | PD | PD | - |
| 150 | USDHC1_CMD | MMC1_CMD | PU | PU | - |
| 152 | USDHC1_RESET_B | MMC1_D5 | PU | PU | - |
| 154 | USDHC1_CLK | MMC1_CLK | PD | PD | - |
| 156 | USDHC1_WP | MMC1_D6 | PD | PD | - |
| 158 | QSPI0A_SS0_B | MMC1_D7 | PU | PU | - |
| 160 | USDHC1_DATA0 | MMC1_D0 | PU | PU | - |
| 162 | USDHC1_DATA1 | MMC1_D1 | PU | PU | - |
| 164 | USDHC1_CD_B | MMC1_CD# | PU | PU | - |
| 194 | ADC_IN3 | DAP1_MCLK | PD | PD | - |
| 196 | SAI0_TXD | DAP1_D_OUT | PD | PD | - |
| 198 | QSPI0A_SS1_B | DAP1_RESET | PU | PU | - |
| 200 | SAI0_TXC | DAP1_BIT_CLK | PD | PD | - |
| 202 | SAI0_RXD | DAP1_D_IN | PD | PD | - |
| 204 | SAI0_TXFS | DAP1_SYNC | PD | PD | - |
| 262 | USB_SS3_TC2 | USBO1_OC# | PU | PD | Yes |
| 274 | QSPI0A_SCLK | USBO1_EN | PD | PD | - |
| 286 | QSPI0A_DQS | BKL1_ON | PD | PD | - |
| 310 | SAI1_RXD | AAP1_LIN_L | PD | PD | - |
| 312 | SAI1_RXC | AAP1_LIN_R | PD | PD | - |
| 316 | SPI0_CS1 | AAP1_HP_L | PD | PD | - |
| 318 | SAI1_RXFS | AAP1_HP_R | PD | PD | - |
