Apalis Tegra Power Consumption
Overviewโ€‹
This is one of a series of posts about Toradex modules' power consumption measurements. This article provides information about the power consumption of Apalis T30 and Apalis TK1.
The Apalis Tegras's power consumption depends on the devices connected to it. Below are the power consumption results of several test cases, demonstrating realistic system configurations at various CPU loads.
Disclaimerโ€‹
  • Environmental temperature
  • Particular Silicon Revision of the SoC
  • Versions of the Software Components installed on the module
  • Use cases
Testing Conditionsโ€‹
  • The tests were performed using 3 different modules of each model.
  • The provided data is the average of the results obtained for each module group.
  • All of the SoMs were heated up first (using a stress test) to simulate the conditions of a continuous use scenario.
0031 Apalis T30 1GB IT V1.1Aโ€‹
Software version: To be determined
Resultsโ€‹
Test caseMean Power Consumption [W*]Max Power Consumption [W]
Idling mode with screen and with eth2.644.44
Stress 1 core(s) without screen3.665.38
Stress 2 core(s)4.035.72
Stress 3 core(s)4.787.40
Stress 4 core(s)5.237.65
iPerf3 with CPU Stress and eth and with screen5.578.17
suspend mode idle14.4014.60
poweroff state0.000.40
  • Unless explicitly mentioned
0034 Apalis TK1 2GB V1.2Aโ€‹
Resultsโ€‹
Idle3.063.36
Idle after 20 min3.313.48
Stress 1 core4.404.53
Stress 2 core5.205.49
Stress 3 core5.826.17
Stress 4 core6.867.04
Idle (Headless)2.442.68
Headless & Full stress5.946.48
Headless, Full stress and iperf3 ethernet6.657.30
Iperf3 ethernet & Full stress7.407.85
Glmark2 & Full stress8.1110.45
HD video & Full stress7.267.74
CPU burn - neo stress script4.955.25
Max stress: full stress, iperf3 ethernet and glmark8.4311.46
Suspend1.310.00
RTC after shutdown810 ยตW
RTC after power off26 ยตW
0034 Apalis TK1 2GB V1.3Aโ€‹
Resultsโ€‹
Test CaseAverage [W]Maximum [W]
Idle2.763.01
Idle after 20 min2.753.03
Stress 1 core4.054.15
Stress 2 core4.664.97
Stress 3 core5.285.56
Stress 4 core6.166.28
Headless idle2.242.50
Headless full stress5.435.65
Iperf3 eth full stress6.356.44
Glmark2 full stress10.0613.41
HD video full stress7.187.29
CPU burn - neo stress script4.644.68
Max stress10.6413.70
Suspend1.041.06
Apalis T30 2GBโ€‹
warning
The power consumption test for Apalis T30 was done in the old format. The following results consider the usage of Ixora board and BSP 2.7
S.NoTest CasePowerPowerPowerPowerPower
CPU 2%One CPU 100%Two CPU 100%Three CPU 100%All CPU 100%
1Apalis T30 2GB V1.0C + Ixora Carrier Board V1.1A12.17V - 3.371W12.09V - 4.558W12.05V - 5.157W11.97V - 6.212W11.92V - 6.878W
1Apalis T30 2GB V1.0C + Ixora Carrier Board V1.1A + Resistive Touch Display 7" Parallel (Back-light at 100%)12.05V - 5.338W12.01V - 6.533W11.89V - 7.039W11.93V - 8.053W11.85V - 8.887W
Additional Resourcesโ€‹
Apalis TK1 Page and Datasheet: Apalis TK1
Apalis T30 Page and Datasheet: Apalis T30
Tegra Power Consumption post: Colibri Tegra Power Consumption
Specifications and Design Guides: Carrier Board Design Guides
Thermal Management in Toradex Modules: Thermal Management
How to Suspend Your Module Running Linux: Suspend/Resume (Linux)
