Aquila iMX95 Power Consumption
This is one of a series of posts about Toradex modules' power consumption measurements. This article provides information about the power consumption of Aquila iMX95.
The Aquila iMX95's power consumption depends on the devices connected to it. Below are the power consumption results of several test cases, demonstrating realistic system configurations at various CPU loads.
Disclaimer
- Environmental temperature
- Particular Silicon Revision of the SoC
- Versions of the Software Components installed on the module
- Use cases
Testing Conditions
- The tests were performed using 3 different modules of each model.
- The provided data is the average of the results obtained for each module group.
- All of the SoMs were heated up first (using a stress test) to simulate the conditions of a continuous use scenario.
0098 Aquila iMX95 Hexa 8GB WB IT V1.0A
Results
- Software Distribution: BSP Layers and Reference Images for Yocto Project Software: TDX Wayland
- Software Image: BSP Layers and Reference Images for Yocto Project Software 7.5.0+build.11 (scarthgap)
| Test case | Mean Power Consumption [W] | Peak Power Consumption [W] |
| Idling mode without screen and without eth | 3.22 | 6.45 |
| Idling mode without screen and with eth | 3.76 | 6.86 |
| Idling mode with screen and without eth | 3.89 | 6.74 |
| Idling mode with screen and with eth | 4.45 | 8.93 |
| Stress 1 core(s) without screen | 4.29 | 6.85 |
| Stress 2 core(s) | 5.11 | 9.17 |
| Stress 3 core(s) | 5.33 | 9.37 |
| Stress 4 core(s) | 5.56 | 11.57 |
| Stress 5 core(s) | 5.80 | 9.93 |
| Stress 6 core(s) | 6.06 | 11.80 |
| iperf3 with CPU Stress and eth and with screen | 6.10 | 11.81 |
| iperf3 with CPU Stress and 2.4GHz and with screen | 6.39 | 12.14 |
| iperf3 with CPU Stress and eth and 2.4GHz and with screen | 6.48 | 12.14 |
| iperf3 with CPU Stress and 5GHz and with screen | 7.23 | 12.36 |
| iperf3 with CPU Stress and eth and 5GHz and with screen | 7.31 | 12.47 |
| iperf3 eth and without screen | 4.32 | 9.02 |
| iperf3 2.4GHz and without screen | 4.32 | 9.59 |
| iperf3 5GHz and without screen | 5.34 | 11.98 |
| glmark2 with all cores stressed | 5.98 | 12.02 |
| glmark2 | 4.52 | 9.99 |
| max stress: stress-ng, glmark2, iperf3 and ethernet | 6.00 | 12.15 |
| max stress: stress-ng, glmark2, iperf3 wifi 2.4GHz and ethernet | 6.65 | 12.58 |
| max stress: stress-ng, glmark2, iperf3 wifi 5GHz and ethernet | 7.41 | 12.80 |
| CPU stress + video play | 5.85 | 11.68 |
suspend mode idle | 0.40 | 0.81 | poweroff state | 0.00 | 0.09 |
