Colibri iMX8X Power Consumption
This is one of a series of posts about Toradex modules' power consumption measurements. This article provides information about the power consumption of Colibri iMX8X.
The Colibri iMX8X's power consumption depends on the devices connected to it. Below are the power consumption results of several test cases, demonstrating realistic system configurations at various CPU loads.
Disclaimer
- Environmental temperature
- Particular Silicon Revision of the SoC
- Versions of the Software Components installed on the module
- Use cases
Testing Conditions
- The tests were performed using 3 different modules of each model.
- The provided data is the average of the results obtained for each module group.
- All of the SoMs were heated up first (using a stress test) to simulate the conditions of a continuous use scenario.
0038 Colibri iMX8QXP 2GB WB IT V1.0C
Software Version: TBD
Results
| Test case | Average [W] | Maximum [W] |
| RTC clock (proper shutdown) | 0.0141 | na |
| RTC clock (power cable removing shutdown ) | 0.0139 | na |
| Idling mode with screen | 2.58 | 2.71 |
| Stress 1 cores | 2.77 | 2.78 |
| Stress 2 cores | 2.94 | 3.02 |
| Stress 3 cores | 3.09 | 3.17 |
| Stress 4 cores | 3.24 | 3.34 |
| Stress 5 cores (arithmetic core) | 3.25 | 3.34 |
| Headless mode all cores stressed | 2.64 | 2.69 |
| Headless mode, all cores, iperf3 100Mbit/s ETH | 3.07 | 3.21 |
| Headless mode, idling | 1.96 | 1.99 |
| All cores stressed and glmark2 | 4.77 | 5.35 |
| All cores stressed + HD video on screen | 4.39 | 4.54 |
| CPU burn - neon stress script, no screen | 3.15 | 3.82 |
| All cores stressed, glmark2, ethernet iperf3 | 4.85 | 5.47 |
0038 Colibri iMX8QXP 2GB WB IT V1.0D
- Software Distribution: BSP Layers and Reference Images for Yocto Project Software: TDX Wayland
- Software Image: BSP Layers and Reference Images for Yocto Project Software: tdx-reference-multimedia-image
Software Versions:
- 5.0.0-devel-202010+build.3
- TDX Wayland with XWayland 5.1.0-devel-20201014+build.96 (dunfell)
Results
| Test case | Mean Power Consumption [W*] | Max Power Consumption [W*] |
| RTC clock (proper shutdown) | 12.52 μW | 13.38 μW |
| RTC clock (power cable removing shutdown ) | 12.39 μW | 12.90 μW |
| Suspend mode | 0.42 | 0.44 |
| Idling mode with screen | 1.98 | 2.20 |
| Idling mode with screen for 20 minutes | 1.98 | 2.36 |
| Idling without screen | 2.00 | 2.33 |
| Stress 1 cores | 2.36 | 3.25 |
| Stress 2 cores | 2.63 | 3.39 |
| Stress 3 cores | 2.90 | 3.69 |
| Stress 4 cores | 3.13 | 4.21 |
| All cores stressed without screen | 3.08 | 4.02 |
| CPU stress with iperf3 Ethernet | 3.49 | 4.26 |
| CPU stress with iperf3 wifi 2.4GHz | 5.51 | 6.22 |
| CPU stress with iperf3 Ethernet and wifi 2.4GHz | 5.75 | 6.32 |
| All cores stressed and glmark2 | 4.14 | 5.09 |
| CPU burn - neon stress script | 3.18 | 3.79 |
| Max stress: all cores stressed, glmark2 ,iperf3 wifi 5GHz and Ethernet | 5.66 | 6.69 |
| Max stress: all cores stressed, glmark2 ,iperf3 wifi 2.4GHz and Ethernet | 5.85 | 6.95 |
| iperf3 Wifi 2.4GHz no screen | 4.11 | 4.36 |
| iperf3 Wifi 5GHz no screen | 4.19 | 4.48 |
| iperf3 Ethernet no screen | 2.41 | 2.75 |
| All cores stressed, glmark2, iperf3 Ethernet | 3.99 | 4.84 |
- Unless explicitly mentioned
0050 Colibri iMX8QXP 2GB IT V1.0C
Software Versions:
- TDX Wayland with XWayland 0.0.0-devel-20200717+build.9 (dunfell) colibri-imx8x ttyLP3Colibri-iMX8X_Verification-Image
- TDX Wayland with XWayland 4.0.0-devel-20200630+build.134 (zeus) colibri-imx8x ttyLP3Colibri-iMX8X_Verification-Image
- TDX Wayland with XWayland 4.0.0-devel-20200717+build.155 (zeus) colibri-imx8x ttyLP3Colibri-iMX8X_Verification-Image
Results
| Test case | Mean Power Consumption [W] | Max Power Consumption [W] |
| Suspend | 0.202 | 0.240 |
| Idle | 2.043 | 2.099 |
| Idle after 20 min | 1.989 | 2.051 |
| Stress 1 core | 2.245 | 2.796 |
| Stress 2 core | 2.532 | 3.084 |
| Stress 3 core | 2.778 | 3.404 |
| Stress 4 core | 2.990 | 3.637 |
| Headless idle | 1.466 | 1.520 |
| Headless & full stress | 2.483 | 3.164 |
| iperf3 Ethernet & full stress | 3.086 | 3.637 |
| Glmark2 & full stress | 3.906 | 4.613 |
| HD video & full stress | 3.758 | 4.149 |
| CPU burn - neon stress script | 2.855 | 2.924 |
| Max stress: full stress, iperf3 Ethernet and glmark | 3.958 | 4.653 |
0050 Colibri iMX8QXP 2GB IT V1.0D
Software Versions:
- 5.1.0-devel-20201014+build.96 (dunfell)
Results
| RTC clock (proper shutdown) | 12.21 μW | 12.72 μW |
| RTC clock (power cable removing shutdown ) | 12.06 μW | 12.45 μW |
| Suspend mode | 0.15 | 0.17 |
| Idling mode with screen | 1.40 | 1.51 |
| Idling mode with screen for 20 minutes | 1.40 | 1.49 |
| Idling without screen * | 1.39 | 1.50 |
| Stress 1 cores | 1.69 | 2.29 |
| Stress 2 cores | 1.98 | 2.57 |
| Stress 3 cores | 2.25 | 2.94 |
| Stress 4 cores | 2.49 | 3.21 |
| All cores stressed without screen | 2.45 | 3.19 |
| CPU stress with iperf3 eth | 2.75 | 3.28 |
| All cores stressed and glmark2 | 3.36 | 4.14 |
| CPU burn - neon stress script | 2.35 | 2.42 |
| Max stress: all cores stressed, glmark2 ,iperf3 Ethernet | 3.31 | 4.11 |
| ierf3 Ethernet no screen | 1.79 | 1.86 |
0051 Colibri iMX8DX 1GB WB V1.0D
- Software Image: BSP Layers and Reference Images for Yocto Project Software: tdx-reference-multimedia-image 5.7.2+build.21 colibri-imx8x
Results
| Poweroff State | 0.00 | 0.02 |
| Suspend mode idle | 0.37 | 0.39 |
| Idling mode without screen and without eth | 1.33 | 2.73 |
| Idling mode without screen and with eth | 1.38 | 2.90 |
| Idling mode with screen and without eth | 1.46 | 2.89 |
| Idling mode with screen and with eth | 1.50 | 2.94 |
| Stress 1 core(s) without screen | 1.58 | 2.44 |
| Stress 2 core(s) | 1.88 | 2.89 |
| iPerf3 with CPU Stress and eth and with screen | 2.02 | 3.17 |
| iPerf3 with CPU Stress and 2.4GHz and with screen | 2.79 | 4.07 |
| iPerf3 with CPU Stress and eth and 2.4GHz and with screen | 2.85 | 4.20 |
| iPerf3 with CPU Stress and 5GHz and with screen | 3.09 | 4.61 |
| iPerf3 with CPU Stress and eth and 5GHz and without screen | 3.11 | 4.72 |
| iPerf3 eth and without screen | 1.64 | 2.90 |
| iPerf3 5GHz and without screen | 2.83 | 4.76 |
| iPerf3 2.4GHz and without screen | 2.30 | 4.19 |
| glmark2 with all cores stressed | 2.39 | 3.34 |
| glmark2 | 2.27 | 3.88 |
| Max stress: all cores stressed, glmark2, iperf3 and ethernet | 2.39 | 3.44 |
| Max stress: all cores stressed, glmark2, iperf3 wifi 2.4GHz and ethernet | 3.17 | 4.46 |
| Max stress: all cores stressed, glmark2, iperf3 wifi 5GHz and ethernet | 3.22 | 5.14 |
| CPU stress + video play | 2.51 | 3.37 |
0052 Colibri iMX8DX 1GB V1.0D
- Software Image: BSP Layers and Reference Images for Yocto Project Software: tdx-reference-multimedia-image 5.7.2-build.21 colibri-imx8x
Results
| Poweroff state | 0.00 | 0.02 |
| Suspend mode idle | 0.16 | 0.19 |
| Idling mode without screen and without eth | 1.01 | 2.31 |
| Idling mode without screen and with eth | 1.05 | 2.43 |
| Idling mode with screen and without eth | 1.13 | 2.63 |
| Idling mode with screen and with eth | 1.17 | 2.78 |
| Stress 1 core(s) without screen | 1.26 | 2.12 |
| Stress 2 core(s) | 1.56 | 2.51 |
| iPerf3 with CPU Stress and eth and with screen | 1.70 | 2.70 |
| iPerf3 eth and without screen | 1.30 | 2.57 |
| glmark2 with all cores stressed | 2.08 | 3.01 |
| glmark2 | 1.95 | 3.66 |
| Max stress: all cores stressed, glmark2, iperf3 and ethernet | 2.07 | 3.04 |
| CPU stress + video play | 2.17 | 3.12 |
Additional Resources
Product Page and Datasheet: Colibri iMX8X
Specifications and Design Guides: Carrier Board Design Guides
Thermal Management in Toradex Modules: Thermal Management
How to Suspend Your Module Running Linux: Suspend/Resume (Linux)
