Colibri Tegra Power Consumption
This is one of a series of posts about Toradex modules' power consumption measurements. This article provides information about the power consumption of Colibri T20 and Colibri T30.
The Colibri Txx's power consumption depends on the devices connected to it. Below are the power consumption results of several test cases, demonstrating realistic system configurations at various CPU loads.
Disclaimer
  • Environmental temperature
  • Particular Silicon Revision of the SoC
  • Versions of the Software Components installed on the module
  • Use cases
Testing Conditions
  • The tests were performed using 3 different modules of each model.
  • The provided data is the average of the results obtained for each module group.
  • All of the SoMs were heated up first (using a stress test) to simulate the conditions of a continuous use scenario.
Colibri T20 512MB with Viola
warning
The power consumption test for Colibri T20 was done in the old format. The following results consider the usage of Viola board and BSP 2.7.
S.NoTest CasePowerPowerPower
CPU 2%One CPU 100%Both CPU 100%
1Colibri T20 512MB V1.2A + Plus Viola 1.1A Carrier Board4.80V - 1.162W4.72V - 1.510W4.67V - 1.751W
Colibri T20 512MB IT with Viola
warning
1Colibri T20 512MB IT V1.2A + Plus Viola 1.1A Carrier Board4.85V - 1.082W4.78V - 1.410W4.74V - 1.649W
0023 Colibri T30 1GB V1.2A
Software version: To be determined
Results
Test CaseAverage [W]Maximum [W]
Idle0.831.24
Idle after 20 min0.831.17
Stress 1 core2.402.46
Stress 2 core3.023.08
Stress 3 core3.453.54
Stress 4 core4.074.14
Idle (headless)0.751.13
Headless full stress3.883.95
Iperf3 eth full stress4.064.14
Glmark2 full stress4.476.15
HD video full stress4.554.90
CPUburn-neo3.353.58
Max stress4.685.79
Suspend0.350.37
0030 Colibri T30 1GB IT V1.2A
Results
Idling mode with screen0.901.20
Idling without screen0.891.19
Stress 1 cores2.412.50
Stress 2 cores2.963.04
Stress 3 cores3.613.75
Stress 4 cores3.984.16
CPU stress with iperf3 eth4.304.96
All cores stressed and glmark24.965.91
Glmark22.213.42
Max stress: all cores stressed, glmark2 ,iperf3 ethernet4.715.74
Iperf3 ethernet no screen1.262.04
Suspend0.390.00
CPU stress + video decoding4.294.70
RTC clock (proper shutdown)171uW178uW
RTC clock (power cable removing shutdown )197uW211uW
Additional Resources
Colibri T20 Page and Datasheet: Colibri T20
Colibri T30 Page and Datasheet: Colibri T30
Tegra Power Consumption post: Apalis Tegra Power Consumption
Specifications and Design Guides: Carrier Board Design Guides
Thermal Management in Toradex Modules: Thermal Management
How to Suspend Your Module Running Linux: Suspend/Resume (Linux)
