Lino iMX93 Power Consumption
This is one of a series of posts about Toradex modules' power consumption measurements. This article provides information about the power consumption of Lino iMX93.
The Lino iMX93's power consumption depends on the devices connected to it. Below are the power consumption results of several test cases, demonstrating realistic system configurations at various CPU loads.
Disclaimer
  • Environmental temperature
  • Particular Silicon Revision of the SoC
  • Versions of the Software Components installed on the module
  • Use cases
Testing Conditions
  • The tests were performed using 3 different modules of each model.
  • The provided data is the average of the results obtained for each module group.
  • All of the SoMs were heated up first (using a stress test) to simulate the conditions of a continuous use scenario.
0217 Lino iMX93 Dual 2GB IT V1.0A
Results
Test caseMean Power Consumption [W]Peak Power Consumption [W]
Idling mode without screen and without eth0.681.60
Idling mode without screen and with eth1.302.47
Idling mode with screen and without eth0.832.01
Idling mode with screen and with eth1.472.66
Stress 1 core(s) without screen1.622.66
Stress 2 core(s)2.063.16
iperf3 with CPU Stress and eth and with screen2.163.42
iperf3 with CPU Stress and 2.4GHz and with screen2.333.83
iperf3 with CPU Stress and eth and 2.4GHz and with screen2.404.05
iperf3 with CPU Stress and 5GHz and with screen2.694.30
iperf3 with CPU Stress and eth and 5GHz and with screen2.704.51
iperf3 eth and without screen1.673.07
iperf3 2.4GHz and without screen1.733.52
iperf3 5GHz and without screen2.204.00
CPU stress + video play2.103.66
suspend mode idle0.111.61
poweroff state0.001.81
