OSM iMX93 Power Consumption
Overview​
This is one of a series of posts about Toradex modules' power consumption measurements. This article provides information about the power consumption of OSM iMX93.
The OSM iMX93's power consumption depends on the devices connected to it. Below are the power consumption results of several test cases, demonstrating realistic system configurations at various CPU loads.
Disclaimer​
  • Environmental temperature
  • Particular Silicon Revision of the SoC
  • Versions of the Software Components installed on the module
  • Use cases
Testing Conditions​
  • The tests were performed using 3 different modules of each model.
  • The provided data is the average of the results obtained for each module group.
  • All of the SoMs were heated up first (using a stress test) to simulate the conditions of a continuous use scenario.
0219 OSM iMX93 Dual 2GB IT V1.0A​
Results​
Test caseMean Power Consumption [W]Peak Power Consumption [W]
Idling mode without screen and without eth0.553.23
Idling mode without screen and with eth0.603.26
Idling mode with screen and without eth0.693.30
Idling mode with screen and with eth0.753.31
Stress 1 core(s) without screen0.863.60
Stress 2 core(s)1.233.53
iPerf3 with CPU Stress and eth and with screen1.303.91
iPerf3 eth and without screen0.903.95
CPU stress + video play1.253.51
suspend mode idle0.020.02
poweroff state0.000.00
