Verdin AM62P Power Consumption
Overview​
This is one of a series of posts about Toradex modules' power consumption measurements. This article provides information about the power consumption of Verdin AM62P.
The Verdin AM62P's power consumption depends on the devices connected to it. Below are the power consumption results of several test cases, demonstrating realistic system configurations at various CPU loads.
Disclaimer​
  • Environmental temperature
  • Particular Silicon Revision of the SoC
  • Versions of the Software Components installed on the module
  • Use cases
Testing Conditions​
  • The tests were performed using 3 different modules of each model.
  • The provided data is the average of the results obtained for each module group.
  • All of the SoMs were heated up first (using a stress test) to simulate the conditions of a continuous use scenario.
0099 Verdin AM62P Quad 2GB WB V1.0A​
Results​
Test caseMean Power Consumption [W]Peak Power Consumption [W]
Idling mode without screen and without Ethernet1.582.50
Idling mode without screen and with Ethernet1.912.82
Idling mode with screen and without Ethernet1.693.77
Idling mode with screen and with Ethernet2.024.09
Stress 1 core without screen2.113.01
Stress 2 cores2.344.37
Stress 3 cores2.474.54
Stress 4 cores2.604.40
iPerf3 with CPU stress, Ethernet and screen2.604.44
iPerf3 with CPU stress, 5 GHz and screen3.415.44
iPerf3 with CPU stress, Ethernet, 5 GHz and without screen3.385.30
iPerf3 with Ethernet and without screen1.912.78
iPerf3 5 GHz and without screen2.814.29
glmark2 with all cores stressed3.335.61
glmark22.975.04
Max stress: stress-ng, glmark2, iPerf3 and Ethernet3.315.56
Max stress: stress-ng, glmark2, iPerf3, Wi-Fi 5 GHz and Ethernet4.016.60
Max stress: burn-a53, glmark2, iPerf3 and Ethernet3.746.16
Max stress: burn-a53, glmark2, iPerf3, Wi-Fi 2.4 GHz and Ethernet4.156.94
Max stress: burn-a53, glmark2, iPerf3, Wi-Fi 5 GHz and Ethernet4.377.18
CPU stress and video playback2.684.55
burn-a53 stress script3.094.92
Suspend mode idle0.300.40
Powered-off state0.000.00
