Verdin iMX8M Plus Power Consumption
Overviewโ€‹
This is one of a series of posts about Toradex modules' power consumption measurements. This article provides information about the power consumption of Verdin iMX8M Plus.
The Verdin iMX8M Plus's power consumption depends on the devices connected to it. Below are the power consumption results of several test cases, demonstrating realistic system configurations at various CPU loads.
Disclaimerโ€‹
  • Environmental temperature
  • Particular Silicon Revision of the SoC
  • Versions of the Software Components installed on the module
  • Use cases
Testing Conditionsโ€‹
  • The tests were performed using 3 different modules of each model.
  • The provided data is the average of the results obtained for each module group.
  • All of the SoMs were heated up first (using a stress test) to simulate the conditions of a continuous use scenario.
0058 Verdin iMX8M Plus Quad 4GB WB IT V1.0Bโ€‹
Resultsโ€‹
Test CaseMean Power Consumption [W*]Peak Power Consumption [W*]
RTC clock (shutdown)841 nW851 nW
RTC clock (power interrupt)843 nW854 nW
Suspend mode to RAM0.15N.A.
Suspend mode to idle1.26N.A.
Idling mode without Ethernet (cable unplugged, no screen)1.651.98
Idling mode without Ethernet (cable unplugged, with screen)1.872.18
Idling mode with screen2.472.79
Stress 1 cores2.863.22
Stress 2 cores3.133.64
Stress 3 cores3.423.96
Stress 4 cores3.764.23
All cores stressed without screen3.113.61
CPU burn - neon stress script4.594.78
CPU stress + video decoding3.213.64
iperf3 Ethernet PHY on eval board (no screen)1.882.23
iperf3 Ethernet (no screen)2.633.07
CPU stress with iperf3 Ethernet3.894.16
glmark23.694.43
All cores stressed and glmark24.515.41
All cores stressed, glmark2, Ethernet iperf34.365.11
Max stress: all cores stressed, glmark2b,iperf3 wifi 2.4GHz, and Ethernet4.996.10
* Unless explicitly mentioned
0058 Verdin iMX8M Plus Quad 4GB WB IT V1.1Aโ€‹
Resultsโ€‹
RTC clock (proper shutdown)808 nW
RTC clock (power cable removing shutdown )818 nW
Suspend mode idle1.370.00
Suspend mode deep RAM0.310.00
Idling mode with screen1.761.81
Idling without screen1.701.98
Stress 1 cores1.952.23
Stress 2 cores2.252.61
Stress 3 cores2.533.03
All cores (4) stressed without screen2.773.29
CPU stress with iperf3 etEtherneth2.963.38
CPU stress with iperf3 wifi 2.4GHz4.004.47
CPU stress with iperf3 wifi 2.4GHz with rework3.784.30
CPU stress with iperf3 wifi 5GHz with rework3.834.19
CPU stress with iperf3 Ethernet and wifi 2.4GHz4.074.42
CPU stress with iperf3 Ethernet and wifi 5GHz with rework3.834.15
All cores stressed and glmark23.894.89
glmark22.953.60
CPU burn - neon stress script4.094.36
Max stress: all cores stressed, glmark2, iperf3 wifi 2.4GHz and Ethernet4.915.73
Max stress: all cores stressed, glmark2, iperf3 wifi 2.4GHz and Ethernet after rework4.865.71
Max stress: all cores stressed, glmark2, iperf3 wifi 2.4GHz and Ethernet after rework + Ethernet phy on module5.406.28
Max stress: all cores stressed, glmark2, iperf3 wifi 5GHz and Ethernet4.755.55
Max stress: all cores stressed, glmark2, iperf3 wifi 5GHz and Ethernet after rework4.655.48
Max stress: all cores stressed, glmark2, iperf3 wifi 5GHz and Ethernet after rework and eth phy on module5.316.1
iperf3 Wifi 2.4GHz no screen2.652.84
iperf3 Wifi 2.4GHz no screen after rework2.62.73
iperf3 Wifi 5GHz no screen2.863.06
iperf3 Wifi 5GHz no screen after rework2.742.88
iperf3 Ethernet no screen1.922.13
All cores stressed, glmark2, Ethernet iperf33.884.67
CPU stress + video3.143.58
0061 Verdin iMX8M Plus Quad 2GB V1.0Bโ€‹
Resultsโ€‹
Test CaseMean Power Consumption [W]Peak Power Consumption [W]
Idling with screen1.6711.822
Idling mode with screen after 20 min1.6381.805
Max stress: all cores stressed, glmark2, ethernet iperf3, video decoding5.0545.756
Stress 1 cores2.0732.340
Stress 2 cores2.4742.942
Stress 3 cores2.7923.410
Stress 4 cores3.1443.879
All cores stressed and glmark24.8865.672
CPU burn - neon stress script4.6024.987
Full CPU stress with iperf3 Ethernet3.9644.549
Full CPU stress and HD video decoding4.0484.751
Headless idle1.4371.605
Headless idle full CPU stress3.2273.996
Suspend-to-RAM mode0.1000.268
Suspend-to-idle mode1.1531.271
0063 Verdin iMX8M Plus Quad 4GB IT V1.1Aโ€‹
Resultsโ€‹
RTC clock (proper shutdown)822 nW
RTC clock (power cable removing shutdown )821 nW
Suspend mode to idle1.270.00
Suspend mode to ram0.180.00
Idling mode with screen1.691.75
Idling without screen1.511.63
Stress 1 cores1.842.10
Stress 2 cores2.142.51
Stress 3 cores2.432.96
Stress 4 cores2.693.24
CPU stress with iperf3 eth2.883.26
All cores stressed and glmark23.864.89
glmark22.863.53
CPU burn - neon stress script3.753.79
Max stress: all cores stressed, glmark2, iperf3 Ethernet with phy on module4.435.26
Max stress: all cores stressed, glmark2, iperf3 Ethernet3.864.65
iperf3 eth no screen phy on eval1.811.90
iperf3 eth no screen phy on module2.412.54
CPU stress + video decoding2.883.43
0065 Verdin iMX8M Plus QuadLite 1GB IT V1.1Aโ€‹
Resultsโ€‹
Idling mode without screen and withouth Ethernet1.394.05
Idling mode without screen and with Ethernet2.175.12
Idling mode with screen and withouth Ethernet1.694.84
Idling mode with screen and with Ethernet2.445.67
Stress 1 core(s) without screen2.475.81
Stress 2 cores3.007.14
Stress 3 cores3.267.02
Stress 4 cores3.537.07
iPerf3 with CPU Stress and eth and with screen3.627.32
iPerf3 eth and without screen2.636.63
glmark2 with all cores stressed4.358.06
glmark23.667.75
Max stress: all cores stressed, glmark2, iperf3 and Ethernet4.257.94
CPU stress + video play3.547.13
CPU NEON stress script4.537.56
Suspend mode idle--
Poweroff state--
0070 Verdin iMX8M Plus Quad 8GB WB IT V1.1Aโ€‹
Resultsโ€‹
Idling mode without screen and with eth2.283.65
Idling mode with screen and withouth eth1.823.41
Idling mode with screen and with eth2.564.09
Stress 1 core(s) without screen2.573.82
Stress 2 core(s)3.104.70
Stress 3 core(s)3.384.81
Stress 4 core(s)3.644.94
iPerf3 with CPU Stress and eth and with screen3.714.85
iPerf3 with CPU Stress and 2.4GHz and with screen4.425.82
iPerf3 with CPU Stress and eth and 2.4GHz and with screen4.455.84
iPerf3 with CPU Stress and 5GHz and with screen4.907.50
iPerf3 with CPU Stress and eth and 5GHz and without screen4.637.38
iPerf3 eth and without screen2.745.27
iPerf3 5GHz and without screen3.776.70
iPerf3 2.4GHz and without screen3.144.96
glmark2 with all cores stressed4.456.58
glmark23.776.10
Max stress: all cores stressed, glmark2, iperf3 and Ethernet4.346.54
Max stress: all cores stressed, glmark2, iperf3 wifi 2.4GHz and Ethernet5.037.10
Max stress: all cores stressed, glmark2, iperf3 wifi 5GHz and Ethernet5.088.62
CPU stress + video play3.856.62
CPU NEON stress script4.747.45
Power Measurement of Verdin SoMsโ€‹
The Verdin Development Board and the Dahlia Carrier Board have a current, voltage and power measurement IC. It is the Texas Instruments INA219.
You need to enable it in the device tree. Check out the articles Device Tree Customization and Device Tree Overlays (Linux) for instructions on how to do it. Below is the device tree code snippet with the required changes:
&hwmon {
status = "okay";
Then the device will be available on /sys/class/hwmon/hwmonX/. X can be enumerated as 0 or 1, because there is also a temperature sensor attached on the same I2C bus.
If we assume it will be on hwmon0, read the power measurement in microwatts (ยตW):
# cat /sys/class/hwmon/hwmon0/power1_input
Therefore you must divide the result by 1000000 to get the value in watts (W).
Additional Resourcesโ€‹
Product Page and Datasheet: Verdin iMX8M Plus
Specifications and Design Guides: Carrier Board Design Guides
Thermal Management in Toradex Modules: Thermal Management
How to Suspend Your Module Running Linux: Suspend/Resume (Linux)
