Tegra 30 Product Change Notification Guide
Introductionβ
The version without the level shifter for the Apalis T30 (V1.1Z) / Colibris T30 (V1.1X) loses the camera input functionality. With that, modules using Toradex Linux BSP will have the affected pins left floating after the system boot. This article helps to enable the pull-down on those pins.
Affected Productsβ
Apalis new designs are shown below:
| End of life Product | Part Number | New Product (with limited features to increase availability, group EOL still applies) | New Part Number |
| Apalis T30 2GB V1.1B | 00251101 | Apalis T30 2GB V1.1Z | 00251125 |
| Apalis T30 1GB V1.1B | 00261101 | Apalis T30 1GB V1.1Z | 00261125 |
| Apalis T30 1GB IT V1.1B | 00311101 | Apalis T30 1GB IT V1.1Z | 00311125 |
Description of Changesβ
Removed TI 74AVCA164245ZQLR (level shifter) and related components due to component EOL and shortage. This component is related to the parallel camera interface.
Customers not requiring the parallel camera input are strongly encouraged to use the additional substitution version. Toradex also advises customers to validate the new product version before their production release, we can provide a rework instruction of the additional substitution version.
Hardware Impactβ
The parallel camera interface (Apalis VI_XX pins) wonβt be available in the new V1.1Z version.
No changes are required on the Apalis carrier board.
If the listed Apalis pins are being used as general GPIOs, they keep their functionality as they are in parallel connected to a second pin of the SoC.
Without the level shifter being assembled, the following Tegra pins are floating. (For more details please refer to Figure 5 and Table 5-54 in Apalis T30 datasheet).
| X1 Pin# | Tegra Pin 1 (Removed) | Tegra pin 2 |
| 99 | VI_D11 | KB_COL5 |
| 123 | VI_D10 | KB_COL6 |
| 135 | VI_D0 | KB_ROW8 |
| 159 | VI_D1 | KB_ROW9 |
| 173 | VI_D9 | KB_ROW7 |
| 175 | VI_D8 | KB_ROW6 |
| 177 | VI_D7 | KB_ROW5 |
| 179 | VI_D6 | KB_ROW4 |
| 181 | VI_D5 | KB_ROW3 |
| 183 | VI_D4 | KB_ROW2 |
| 185 | VI_D3 | KB_ROW1 |
| 187 | VI_D2 | KB_ROW0 |
| 191 | VI_PCKL | KB_COL2 |
| 195 | VI_VSYNC | KB_COL3 |
| 197 | VI_HSYNC | KB_COL4 |
Software Impactβ
We request customers check their software in detail to guarantee functionality on the new product version. Please check that no excessive warning or error logging is done in the background which might compromise system performance or flash storage lifetime.
Toradex Linux BSPβ
After boot, If not handled properly, the affected Tegra pins listed above will be left floating as a direct consequence of removing the TI 74AVCA164245ZQLR level shifter. Thus, Toradex strongly recommends enabling the pull-down resistor on these Tegra pins to avoid pin fluctuation.
This can be achieved with the following linux kernel patch:
0001-apalis_t30-pinmux-Set-all-VI-pins-to-PULL_DOWN.patch
diff --git a/arch/arm/mach-tegra/board-apalis_t30-pinmux.c b/arch/arm/mach-tegra/board-apalis_t30-pinmux.c
index ae5e82f..0091dae 100644
--- a/arch/arm/mach-tegra/board-apalis_t30-pinmux.c
+++ b/arch/arm/mach-tegra/board-apalis_t30-pinmux.c
@@ -449,23 +449,23 @@ static __initdata struct tegra_pingroup_config apalis_t30_pinmux[] = {
DEFAULT_PINMUX(ULPI_STP, UARTD, NORMAL, NORMAL, INPUT),
/* VI pins are all level-shifted */
- VI_PINMUX(VI_D0, VI, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_D1, VI, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_D2, VI, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_D3, VI, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_D4, VI, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_D5, VI, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_D6, VI, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_D7, VI, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_D8, VI, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_D9, VI, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_D10, VI, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_D11, VI, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_HSYNC, VI, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D0, VI, PULL_DOWN, NORMAL, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D1, VI, PULL_DOWN, NORMAL, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D2, VI, PULL_DOWN, NORMAL, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D3, VI, PULL_DOWN, NORMAL, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D4, VI, PULL_DOWN, NORMAL, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D5, VI, PULL_DOWN, NORMAL, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D6, VI, PULL_DOWN, NORMAL, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D7, VI, PULL_DOWN, NORMAL, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D8, VI, PULL_DOWN, NORMAL, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D9, VI, PULL_DOWN, NORMAL, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D10, VI, PULL_DOWN, NORMAL, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D11, VI, PULL_DOWN, NORMAL, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_HSYNC, VI, PULL_DOWN, NORMAL, INPUT, DISABLE, DISABLE),
/* GPIO T1: VI_LevelShifter_DIR */
DEFAULT_PINMUX(VI_MCLK, VI, NORMAL, NORMAL, OUTPUT),
- VI_PINMUX(VI_PCLK, VI, PULL_UP, NORMAL, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_VSYNC, VI, NORMAL, NORMAL, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_PCLK, VI, PULL_DOWN, NORMAL, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_VSYNC, VI, PULL_DOWN, NORMAL, INPUT, DISABLE, DISABLE),
#define GPIO_INIT_PIN_MODE(_gpio, _is_input, _value) \
To add this patch with Yocto BSP 2.8, make sure to follow these steps:
Make sure your environment is configured and ready. Follow the Build a Reference Image with Yocto Project/OpenEmbedded for more details.
Create a new custom layer to customize the kernel. Follow the Custom meta layers, recipes and images in Yocto Project (hello-world examples) for more details.
Add a new bbappend file called
linux-toradex_%.bbappendwith the following content:
FILESEXTRAPATHS_prepend := "${THISDIR}/${PN}:"
SRC_URI += "\
file://0001-apalis_t30-pinmux-Set-all-VI-pins-to-PULL_DOWN.patch \
Make sure you have the 0001-apalis_t30-pinmux-Set-all-VI-pins-to-PULL_DOWN.patch in your linux-toradex folder. The final structure should look like this:
βββ conf
β βββ layer.conf
βββ COPYING.MIT
βββ README
βββ recipes-kernel
βββ linux
βββ linux-toradex
β βββ 0001-apalis_t30-pinmux-Set-all-VI-pins-to-PULL_DOWN.patch
βββ linux-toradex_%.bbappend
- Add your new layer and bitbake your new image.
$ bitbake-layers add-layer ../layers/<custom-meta-layer>
$ bitbake <image>
Windows CEβ
The removal of the TI 74AVCA164245ZQLR does not impact the functionality of the software no errors are displayed. All the pins are left on pull-down unless the camera interface is used.
Affected Productsβ
Colibri's new designs are shown below:
| Colibri T30 1GB V1.1G | 00231106 | Colibri T30 1GB V1.1X | 00231123 |
| Colibri T30 1GB IT V1.1B | 00301101 | Colibri T30 1GB IT V1.1X | 00301123 |
Hardware Impactβ
The parallel camera interface wonβt be available in the new V1.1X version.
No changes are required on the Colibri carrier board.
If the listed Colibri pins are being used as general GPIOs, they keep their functionality as they are in parallel connected to a second pin of the SoC.
Without the level shifter being assembled, the following Tegra pins are floating. (For more details please refer to Table 5-18 and Table 4-1 in Colibri T30 datasheet).
| X1 Pin# | Tegra pin 2 (Removed) | Tegra Pin 1 |
| 59 | VI_D7 | SDMMC3_DAT3 |
| 65 | VI_D9 | PEX_L1_CLKREQ_N |
| 67 | VI_D6 | SDMMC3_CMD |
| 69 | VI_D10 | PEX_L1_RST_N |
| 71 | VI_D0 | GPIO_PV2 |
| 77 | VI_D11 | GPIO_PCC2 |
| 79 | VI_D4 | SDMMC1_DAT2 |
| 81 | VI_VSYNC | LCD_PWR1 |
| 85 | VI_D8 | GPIO_PV3 |
| 94 | VI_HSYNC | PEX_L2_CLKREQ_N |
| 96 | VI_PCLK | SDMMC1_CLK |
| 97 | VI_D5 | SDMMC1_DAT3 |
| 98 | VI_D1 | SDMMC1_CMD |
| 101 | VI_D2 | SDMMC1_DAT0 |
| 103 | VI_D3 | SDMMC1_DAT1 |
Software Impactβ
Toradex Linux BSPβ
0001-colibri_t30-pinmux-Set-all-VI-pins-to-PULL_DOWN.patch
diff --git a/arch/arm/mach-tegra/board-colibri_t30-pinmux.c b/arch/arm/mach-tegra/board-colibri_t30-pinmux.c
index 1dac029..c5bb3a6 100644
--- a/arch/arm/mach-tegra/board-colibri_t30-pinmux.c
+++ b/arch/arm/mach-tegra/board-colibri_t30-pinmux.c
@@ -599,23 +599,23 @@ static __initdata struct tegra_pingroup_config colibri_t30_pinmux[] = {
//VI pins are all input level-shifted and multiplexed
//unused VI pins could disable input drivers
- VI_PINMUX(VI_D0, VI, NORMAL, TRISTATE, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_D1, VI, NORMAL, TRISTATE, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_D2, VI, NORMAL, TRISTATE, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_D3, VI, NORMAL, TRISTATE, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_D4, VI, NORMAL, TRISTATE, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_D5, VI, NORMAL, TRISTATE, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_D6, VI, NORMAL, TRISTATE, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_D7, VI, NORMAL, TRISTATE, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_D8, VI, NORMAL, TRISTATE, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_D9, VI, NORMAL, TRISTATE, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_D10, VI, NORMAL, TRISTATE, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_D11, VI, NORMAL, TRISTATE, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_HSYNC, VI, NORMAL, TRISTATE, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D0, VI, PULL_DOWN, TRISTATE, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D1, VI, PULL_DOWN, TRISTATE, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D2, VI, PULL_DOWN, TRISTATE, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D3, VI, PULL_DOWN, TRISTATE, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D4, VI, PULL_DOWN, TRISTATE, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D5, VI, PULL_DOWN, TRISTATE, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D6, VI, PULL_DOWN, TRISTATE, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D7, VI, PULL_DOWN, TRISTATE, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D8, VI, PULL_DOWN, TRISTATE, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D9, VI, PULL_DOWN, TRISTATE, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D10, VI, PULL_DOWN, TRISTATE, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_D11, VI, PULL_DOWN, TRISTATE, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_HSYNC, VI, PULL_DOWN, TRISTATE, INPUT, DISABLE, DISABLE),
//GPIO T1: EN_MIC_GND
- VI_PINMUX(VI_PCLK, VI, PULL_UP, TRISTATE, INPUT, DISABLE, DISABLE),
- VI_PINMUX(VI_VSYNC, VI, NORMAL, TRISTATE, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_PCLK, VI, PULL_DOWN, TRISTATE, INPUT, DISABLE, DISABLE),
+ VI_PINMUX(VI_VSYNC, VI, PULL_DOWN, TRISTATE, INPUT, DISABLE, DISABLE),
SRC_URI += "\
file://0001-colibri_t30-pinmux-Set-all-VI-pins-to-PULL_DOWN.patch \
Make sure you have the 0001-colibri_t30-pinmux-Set-all-VI-pins-to-PULL_DOWN.patch in your linux-toradex folder. The final structure should look like this:
βββ conf
β βββ layer.conf
βββ COPYING.MIT
βββ README
βββ recipes-kernel
βββ linux
βββ linux-toradex
β βββ 0001-colibri_t30-pinmux-Set-all-VI-pins-to-PULL_DOWN.patch
$ bitbake <image>
Windows CEβ
Contactβ
Please feel free to contact Toradex if you have any questions.
For commercial and sales questions, please contact shop@toradex.com.
For technical questions, please contact support@toradex.com or post a question at our community forum.
