Colibri PXA270
Getting Startedβ
Please note that this Product is no longer available for purchase.
Colibri PXA270 is a member of the Colibri family. You will find all technical details such as features, datasheets, software, etc. here.
What do I need to order?β
You will need to order a suitable carrier board. We recommend you order the Colibri Evaluation Board for easy evaluation of Colibri interfaces.
Do I need anything else in addition?β
The Carrier Board Accessory Kit includes:
- Cables: USB, Ethernet, RS232, Jumper Wires
- Adapters: DVI to VGA, HDMI to DVI, USB to RS232, USB Micro-A to A (USB Micro-AB receptacle to Type A), RS232 Header to D-Sub, Iris Power-adapter
- Product Flyer with cable connection details
Where do I buy?β
You can buy the Colibri PXA270 module, Colibri Evaluation Board and Carrier Board Accessory Kit from the Toradex webshop.
Starting for the first time?β
The initial steps before starting your application development depends on the Carrier Board and Operating System, you would like to use along with the module. For all details, please check the article below to set up the module correctly.
We also have quick video tutorials.
For developing software on the platform, please get all the details below.
Having trouble?β
Featuresβ
Processorβ
- Marvell PXA270 - Intel XScale Arm (312/520MHz)
- L1 Instruction cache = 32KB
- L1 Data cache = 32KB
Memoryβ
- 64MB SDRAM (32 Bit) RAM
- 32MB NOR (32 Bit) Flash
Interfacesβ
- 32 Bit External Bus
- USB 2.0 (1x Host, 1x OTG)
- I2C (1x)
- SPI (3x)
- Compact Flash (1x)
- UART (3x)
- IrDA (1x)
- PWM (4x)
- GPIOs (up to 85)
- Analog Input (4x 12 Bit)
- Ethernet (1x 10/100 Mbit)
- SDIO/SD/MMC (1x 4 Bit)
- RGB (1024x768x18bpp)
- Resistive Touch (4/5-wire)
- Camera Parallel Interface (1x)
- Analog Audio Line in (Stereo)
- Analog Audio Mic in (Mono)
- Analog Audio Headphone out (Stereo)
Supported operating systemsβ
Datasheetsβ
Module's Datasheetβ
Technical Manualsβ
3rd Party Components' Datasheetsβ
- Davicom DM9000 Ethernet Controller
- NXP UCB 1400 Audio Codec and Touch Screen Controller
- Wolfson WM9715L Audio Codec and Touch Screen Controller
- Texas Instruments TPS65020 Power Management IC
- Texas Instruments TPS65021 Power Management IC
Additional Resourcesβ
Softwareβ
Get details including free downloads of images and BSPs for operating systems supported by Colibri PXA270
In-house development and supportβ
3D Modelsβ
General Colibri 3D Mechanical Modelsβ
The basic Colibri 3D model contains the PCB and the maximum component height on top and bottom of the module.
This is a SolidWorks CAD model. You can download the free eDrawings model viewer from SolidWorks here.This is a generic STEP model that can be opened and modified in any 3D CAD.This is a generic 3D pdf model that can be opened in Adobe Reader.Carrier Boardsβ
Off-the-shelf Carrier Boardsβ
From Toradexβ
From Partnersβ
Custom Carrier Board Designβ
Find free reference designs, schematics, 3D designs and tools to build your carrier board easily in the link below.
Accessoriesβ
- Display EDT
- Colibri Fasteners
- Capacitive Multi-Touch Display
- Carrier Board Accessory Kit
- LM816 USB WiFi
- Analogue Camera Adapter
Revision Historyβ
Colibri PXA270 312MHzβ
Product # | Product Description | Changes from Previous Version | Release Date | PCN Document |
00011000 | Colibri PXA270 312MHz V1.0A | Initial Release PMIC: MAX1587 NOR Flash: J3 WinCE license label: V5.0 SODIMM: 2.5V (DDR1) and 1.8V (DDR2) keying | 2005-05-16 | Β |
00011001 | Colibri PXA270 312MHz V1.0B | RoHS compliancy | 2005-08-30 | Β |
00011002 | Colibri PXA270 312MHz V1.0C | Changes in the audio supply SODIMM: 2.5V keying (DDR1) only | 2005-12-27 | Β |
00011003 | Colibri PXA270 312MHz V1.0D | Changed series resistor value | 2006-04-05 (reworked V1.0c) | Β |
00011200 | Colibri PXA270 312MHz V1.2A | PMIC: TPS65020 GPIO`50` is muxed with UIOΒ Reset is generated by VBat VRTC is switched by PMIC | 2006-10-07 | Β |
00011202 | Colibri PXA270 312MHz V1.2C | NOR Flash: P30 | 2006-09-25 | Β |
00011203 | Colibri PXA270 312MHz V1.2D | NOR Flash: J3 WinCE license label: V6.0 | 2007-08-04 | PCN Colibri PXA270 312MHz V1.2D 2010-09-14 |
00082100 | Colibri PXA270 312MHz V2.1A | NOR Flash: Numonyx StrataFlash P33 Audio: Wolfson WM9715L replaced NXP UCB1400 SODIMM pin 95 can be used as RDY signal | 2010-05-25 | PCN Colibri PXA270 312MHz V2.1A 2010-09-14 |
00082201 | Colibri PXA270 312MHz V2.2B | Changed Ethernet CS pull-up from 100k to 22k PCB optimizations for production | 2010-09-14 | PCN Colibri PXA270 312MHz V2.2B 2012-05-25 |
00082400 | Colibri PXA270 312MHz V2.4A | Changed from PXA270 stepping C0 to PXA270M stepping A1 Optimized power-up circuit for shorter reset time | 2012-05-25 | PCN Colibri PXA270 312MHz V2.4A 2015-03-30 |
00082402 | Colibri PXA270 312MHz V2.4C | Using Etron SDRAM instead of Fidelix SDRAM Validated Wolfson WM9712L as a drop-in replacement for Wolfson WM9715L audio codec | 2015-04-30 |
Colibri PXA270 520MHzβ
00021000 | Colibri PXA270 520MHz V1.0A | Initial Release PMIC: MAX1587 NOR Flash: J3 WinCE license label: V5.0 SODIMM: 2.5V (DDR1) and 1.8V (DDR2) keying | 2005-05-16 | Β |
00021001 | Colibri PXA270 520MHz V1.0B | RoHS compliancy | 2005-08-30 | Β |
00021002 | Colibri PXA270 520MHz V1.0C | Changes in the audio supply SODIMM: 2.5V keying (DDR1) only | 2005-12-27 | Β |
00021003 | Colibri PXA270 520MHz V1.0D | Changed series resistor value | 2006-04-05 (reworked V1.0c) | Β |
00021200 | Colibri PXA270 520MHz V1.2A | PMIC: TPS65020 GPIO`50` is muxed with UIO Reset is generated by VBat VRTC is switched by PMIC | 2006-10-07 | Β |
00021201 | Colibri PXA270 520MHz V1.2B | Β | No release | Β |
00021202 | Colibri PXA270 520MHz V1.2C | P30 Flash (32MB) | 2006-09-25 | Β |
00021203 | Colibri PXA270 520MHz V1.2D | NOR Flash: J3 WinCE license label: V6.0 | 2007-08-04 | PCN Colibri PXA270 520MHz V1.2D 2010-09-14 |
00092100 | Colibri PXA270 520MHz V2.1A | NOR Flash: Numonyx StrataFlash P33 Audio: Wolfson WM9715L replaced NXP UCB1400 SODIMM pin 95 can be used as RDY signal | 2010-05-25 | PCN Colibri PXA270 520MHz V2.1A 2010-09-14 |
00092201 | Colibri PXA270 520MHz V2.2B | PCB optimizations for production Changed Ethernet CS pull-up from 100k to 22k Processor: PXA270 | 2010-09-14 | PCN Colibri PXA270 520MHz V2.2B 2012-05-25 |
00092400 | Colibri PXA270 520MHz V2.4A | Changed from PXA270 stepping C0 to PXA270M stepping A1 Optimized power-up circuit for shorter reset time | 2012-05-25 | PCN Colibri PXA270 520MHz V2.4A 2015-03-30 |
00092402 | Colibri PXA270 520MHz V2.4C | Using Etron SDRAM instead of Fidelix SDRAM Validated Wolfson WM9712L as a drop-in replacement for Wolfson WM9715L audio codec | 2015-04-30 |
Errataβ
None
