Colibri PXA300
PXA300 Computer on Module - Colibri PXA300 - Front
(Double-Click to Zoom)
Welcome to the product page for the Colibri PXA300 (XT) computer on module.
This page contains a variety of information relating to the Colibri PXA300 (XT) product and is intended to be used as a single point of access for all information you need.
Getting Started​
If you are new to the Colibri family of computer on modules, this section is intended to help get you up and running fast.
What do I need to order?​
As well as the Colibri module, you will need to order a suitable carrier board. All carrier boards are compatible with all Colibri modules, but we recommend you order either the Colibri Evaluation Board or the Iris Carrier Board, depending on your individual needs.
Do I need anything else in addition?​
The Carrier Board Accessory Kit includes:
  • Cables: USB, Ethernet, RS232, Jumper Wires
  • Adapters: DVI to VGA, DVI to HDMI, USB to RS232, USB Micro-A to A (USB Micro-AB receptacle to Type A), RS232 Header to D-Sub, Iris Power-adapter
  • Power Adapter: 12VDC 30W with international plugs (not suitable for Viola carrier board)
  • Product Flyer with cable connection details
Toradex has Carrier Board Accessory Kit available on our webshop.
Where do I buy this product?​
Toradex distributes directly to customers, exclusively via the internet. To place your order, please use our webshop.
Starting the system for the first time​
Depending on which carrier board you have purchased you can go through the articles: First Steps with Colibri Evaluation Board, Iris, Viola.
We also have quick video tutorials.
Updating to the latest software image version​
For Windows CE customers, please use the update tool to update to the latest image version.
Get started with application software development​
Please go through this article to setup your computer module.
For Windows CE customers, please check out our getting started section for information on getting development environment setup and start writing your first "hello world" application.
Having trouble?​
If you are having trouble getting started, then our support team is here to help you. Please refer the article - how to contact support.
Main Features​
Features of the Colibri PXA300 (XT) are given below.
Processor​
  • Marvell PXA300 208 MHz
Memory​
  • 64 MByte of DDR SDRAM (16 Bit)
  • 128 MByte of NAND FLASH (8 Bit)
Interfaces​
  • 16 Bit demultiplexed DFI bus
  • LCD (up to 1024x768)
  • CMOS/CCD image sensor interface
  • I2C
  • SPI
  • 2x SDCard (SDIO, MMC)
  • Up to 120 GPIOs
  • 100 MBit Ethernet
  • One-Wire
  • Keypad
  • Consumer Infrared
  • USIM
  • USB host / device
  • USB 2.0 device (requires external UTMI chip)
Colibri PXA300 XT only:
  • Audio in-/output; Mic-in
  • 4 Analog input
  • 4/5-Wire resistive touch-screen interface
Supported operating systems​
  • Windows CE 5/6
  • Embedded Linux Kernel 2.6
Datasheets​
Product Datasheet:
Colibri PXA3xx CPLD Description:
Technical references manuals, user guides and related material for the PXA3xx processors as used on the Colibri PXA3xx range of computer on modules can be found here:
Datasheets for other components used on the Colibri PXA3xx range of computer modules can be found here:
Design Guides and Application Notes​
Migration and Design Guide:
Designing your own custom carrier board/hardware?​
Check out our carrier board design guide including electronic design data (schematics, layout and libraries) at no cost.
Software Downloads​
Windows CE​
The following table lists Bootloader, OS images, BSPs and Platform Builder Workspaces, which are available for the range of Colibri PXAxxx modules.
Windows CE 5.0
(CE5)
Windows Embedded CE 6.0
(CE6)
OS Image
BSP
Workspace
Linux​
The following Linux BSP is available for the Colibri PXAxxx. Please note that the Linux BSP is not being actively developed by Toradex at present and therefore support is limited.
Colibri PXAxxx U-Boot and Linux BSP
Further Information​
For further information and downloads, check out our software resources section here
Android​
The following Android BSP is available for the Colibri PXAxxx. Please note that the Android BSP is not being actively developed by Toradex at present and therefore support is limited.
Colibri PXAxxx Android BSP
Compatible Products and Accessories​
Product Revision History​
Product revision history for the Colibri PXA300 (XT) computer modules.
Colibri PXA300 208MHz​
00041000
Colibri PXA300 624MHz V1.0A
Initial
No release
00041001
Colibri PXA300 208MHz V1.0B
No release
00041100
Colibri PXA300 208MHz V1.1A
PXA300 208 MHz A2 stepping
PMIC: MAX8661
LAN: AX88796B
Added signal RD_nWR on SODIMM
2007-10-30
00041101
Colibri PXA300 208MHz V1.1B
Changed assembly option to provide pin compatibility with Colibri PXA270/320 for VLIO devices
2008-02-07
00041300Colibri PXA300 208MHz V1.3AThe PMIC (Power Management IC) has been changed from the Maxim MAX8661 to the National LP3972S2010-12-21
PCN.2015.03.26.1 (replaces PCN.2014.10.06.1)
00041301Colibri PXA300 208MHz V1.3BUsing EON Flash instead of Samsung Flash2015-04-15
  Product not recommended for new designs. Please check PCN.2014.10.06.1
Colibri PXA300 208MHz XT​
00071300
Colibri PXA300 208MHz XT V1.3A
Initial
2013-05-31
PCN.2014.10.06.1
