Colibri PXA310
Marvell PXA310 Computer on Module - Colibri PXA310 - Front
(Double-Click to Zoom)
Getting Started
warning
Please note that this Product is no longer available for purchase.
Colibri PXA310 is a member of the Colibri family. You will find all technical details such as features, datasheets, software, etc. here.
What do I need to order?
You will need to order a suitable carrier board. We recommend you order the Colibri Evaluation Board for easy evaluation of Colibri interfaces.
Do I need anything else in addition?
The Carrier Board Accessory Kit includes:
  • Cables: USB, Ethernet, RS232, Jumper Wires
  • Adapters: DVI to VGA, HDMI to DVI, USB to RS232, USB Micro-A to A (USB Micro-AB receptacle to Type A), RS232 Header to D-Sub, Iris Power-adapter
  • Product Flyer with cable connection details
Where do I buy?
You can buy the Colibri PXA310 module, Colibri Evaluation Board and Carrier Board Accessory Kit from the Toradex webshop.
Starting for the first time?
The initial steps before starting your application development depends on the Carrier Board and Operating System, you would like to use along with the module. For all details, please check the article below to set up the module correctly.
We also have quick video tutorials.
For developing software on the platform, please get all the details below.
Having trouble?
Features
Processor
  • Marvell PXA310 - Intel XScale Arm (624MHz)
  • L1 Instruction cache = 32KB
  • L1 Data cache = 32KB
Memory
  • 128MB DDR (32 Bit) RAM
  • 512MB NAND (8 Bit) Flash
Interfaces
  • 16 Bit External Bus
  • USB 2.0 (1x Host, 1x OTG)
  • I2C (1x)
  • SPI (4x)
  • One-wire (1x)
  • UART (3x)
  • IrDA (1x)
  • PWM (4x)
  • GPIOs (up to 92)
  • Analog Input (4x 12 Bit)
  • Ethernet (1x 10/100 Mbit)
  • SDIO/SD/MMC (1x 4 Bit)
  • RGB (1024x768x18bpp)
  • Resistive Touch (4/5-wire)
  • Camera Parallel Interface (1x)
  • Analog Audio Line in (Stereo)
  • Analog Audio Mic in (Mono)
  • Analog Audio Headphone out (Stereo)
Supported operating systems
Datasheets
Module's Datasheet
Colibri PXA310 Datasheet
Colibri PXA3xx CPLD Description
Technical manuals
3rd Party Datasheets
Additional Resources
Software
Get details including free downloads of images and BSPs for operating systems supported by Colibri PXA310.
In-house development and support
3D Models
General Colibri 3D Mechanical Models
The basic Colibri 3D model contains the PCB and the maximum component height on top and bottom of the module.
This is a SolidWorks CAD model. You can download the free eDrawings model viewer from SolidWorks here.
This is a generic STEP model that can be opened and modified in any 3D CAD.
This is a generic 3D pdf model that can be opened in Adobe Reader.
Carrier Boards
Off-the-shelf Carrier Boards
From Toradex
From Partners
Custom Carrier Board Design
Find free reference designs, schematics, 3D designs and tools to build your carrier board easily in the link below.
Accessories
Revision History
00051200
Colibri PXA310 624MHz V1.2APXA310: A2 stepping
PMIC: LP3972
Audio: WM9715L
2008-09-15
00051300Colibri PXA310 624MHz V1.3AChanged reset handling for Ethernet controller
Increased mounting-hole size to 2mm (Colibri standard)
2009-02-15PCN Colibri PXA310 624MHz V1.3A 2010-12-21
00051301Colibri PXA310 624MHz V1.3BChanged processor stepping from A2 to B12011-05-20PCN Colibri PXA310 624MHz V1.3B 2017-01-23
00051302Colibri PXA310 624MHz V1.3CChanged from 512MB NAND Flash Samsung K9F4G08U0D-SIB0 (EOL) to 1GB NAND Flash Cypress S34ML08G101TFI0002017-01-23
Errata
None
