Orchid Carrier Board
(Double-Click to Zoom)
Getting Started​
Order details​
warning
Orchid Carrier Board is EOL and cannot be ordered anymore. For alternatives please take a look at the other Colibri Carrier Boards.
The Orchid Carrier Board was specifically designed for the use with only Colibri PXA modules: Colibri PXA270, PXA310 and PXA320.
Having trouble?​
Features​
I/O Support​
  • Compact Flash Card Interface (1x)
  • USB (2x Host, 1x Device)
  • I2C (1x)
  • SPI (2x)
  • UART (2x RS232)
  • IrDA (1x)
  • PWM (4x)
  • GPIO (up to 20)
  • Analog Input (4x)
  • Ethernet (1x 10/100 Mbit)
  • SDIO/SD/MMC (1x 4 Bit)
  • VGA (1x)
  • RGB (1x 18 Bit)
  • Resistive Touch (4-wire)
  • Analog Audio In (1x)
  • Analog Audio Mic in (1x)
  • Analog Audio Headphone out (1x)
  • RTC on Board (1x)
Block Diagram​
Datasheets​
Orchid Carrier Board Datasheet​
Orchid Carrier Board Datasheet V1.2
Compatible Products​
Revision History​
01031000
Orchid Carrier Board V1.0A
Initial Release
Sample Product, No PCN
01031001
Orchid Carrier Board V1.0B
2x RS2322006-04EOL Notice Orchid Carrier Board V1.0B
01021002
Orchid Carrier Board V1.0C
1x RS2322006-08EOL Notice Orchid Carrier Board V1.0C
Errata​
None
