Verdin Industrial Heatsink
Verdin Industrial Heatsink - Front
Verdin Industrial Heatsink - Back
(Double-Click to Zoom)
Getting Started
The Verdin Industrial Heatsink is one of the available accessories for the Verdin Family. You can find all technical details such as features, datasheets and software, here.
There are two types of Verdin industrial heatsinks. Check the Compatible Products section to identify the suitable heatsink for your System on Module.
Where do I buy this product?
You can buy all the products from the Toradex webshop.
Having trouble?
Please contact our technical support. You can check the available options on the Technical Support Channels.
Main Features
  • Robust, shock- and vibration-proof.
  • Mounting with 4 screws (included).
  • Includes thermal interface material (TIM).
Datasheets
Verdin Industrial Heatsink Type 1 and Type 2 V1.1
Verdin Industrial Heatsink Type 1 and Type 2 V1.0B
3D Mechanical Models
Verdin Industrial Heatsink Type 1 V1.1A
Verdin Industrial Heatsink Type 1 V1.0B
Verdin Industrial Heatsink Type 2
Compatible Products
Additional Resources
Revision History
Product Number (PID8) Format
Product Numbering Scheme
FieldDescription
Example
0029: Apalis iMX6D 512MB
00: Assembly Variant A
2311 Verdin Industrial Heatsink Type 1
23111000
Verdin Industrial Heatsink Type 1 V1.0A
Initial Release, a pre-production sample
Q2, 2021
Sample Product, No PCN
23111001
  • Blue anodized (starting from the 2nd production lot of V1.0B)
  • Optimized for high volume production
Q4, 2021
PCN Verdin Industrial Heatsink Type 1 V1.0B 2025-09-19
23111100
  • Thermal interface material has changed from Henkel TGP3000 to Henkel TGP5000
  • Thermal interface material size has changed from 22x22x2 mm to 26x22x3.175 mm
  • Product compatibility has been extended to include Verdin AM62 and Verdin iMX95
  • Product Country of Origin has been changed from China to Vietnam
Q2, 2025
2317 Verdin Industrial Heatsink Type 2
23171100
Verdin Industrial Heatsink Type 2 V1.1A
  • Initial Release
  • Based on Verdin Industrial Heatsink Type 1 V1.1A
  • Change TIM thickness from 3.175 mm to 1.524 mm
Q2, 2025
Errata
Verdin Heatsink Type 1
