Mallow Carrier Board
Mallow Carrier Board Top
Mallow Carrier Board Bottom
(Double-Click to Zoom)
Getting Started
This section contains initial information needed to set-up the Mallow Carrier Board for the first time.
Recommendation for the first-time order
Getting started
The Verdin SoMs come with Toradex Easy Installer pre-installed. Once you power-on the board, it will display a list of available images to be installed. Check out how to get started with the Toradex Easy Installer:
For quickstart step-by-step instructions about how to start using Torizon, please have a look at our step-by-step Getting-Started Guide:
The following Linux-based offerings are currently supported:
Debug UART Voltage levels
The debug UART signal levels on the Mallow carrier board are 1.8V, for more details please consult the datasheet. If you want to use USB-UART converters you should make sure that the chosen solution is compatible. It is recommend to use the FTDI TTL-232RG-VREG1V8-WE.
Additional information
For information on how to re-flash an operating system or image on the computer on module please check the Toradex Easy Installer article:
We have quick video tutorials:
For developing software on the platform, please browse through the list of knowledge-base articles provided in the link below:
Having trouble?
Please contact our technical support. Various option of technical support are mentioned below:
Hardware Features
Check the hardware features on the product page in toradex.com:
Block Diagram
Mallow Carrier Board V1.1
Datasheets
Design Resources
Mallow Carrier Board V1.1 Design Data
Verdin Specifications
Mallow Carrier Board V1.1A Mechanical Models
A basic 3D model for the Mallow carrier board can be downloaded here:
Design and Layout Guide
Altium Designer
Compatible Products
Revision History
Product Number (PID8) Format
Product Numbering Scheme
FieldDescription
Example
0029: Apalis iMX6D 512MB
00: Assembly Variant A
PN: 0161
Product #Product DescriptionChanges from Previous VersionRelease DateRelated Documents
01611000Mallow V1.0APreliminary Version-Preliminary Version - No PCN document
01611100Mallow V1.1AInitial Public ReleaseQ3 2023Initial Release - No PCN document
01611101Mallow V1.1B- Change X6 from Phoenix Connector 1843790 to 1995787
- Change MECH15 from Phoenix Connector 1805410 to 1847055
- Allow Wurth 9774070243R as an alternative component on MECH1 and MECH2
- Allow Wurth 9774025243R as an alternative component on MECH3 and MECH4
- Add 2x Screws ISO 1481-ST 2.2x4.5C (Resolves Errata HAR-11025)
- Move to Volume PCB manufacturer
Q3 2024
01611102Mallow V1.1C- Change IC15 from NXP PCA9617ADPJ to TI TCA9509DGKR (Resolves Errata HAR-11226)
- Change R124 and R125 from 1.8k/63mW/5%/0402 to 1.5k/63mW/1%/0402 (Resolves Errata HAR-11226)
- Change assembly state of R122 and R123 from “assembled” to “not assembled”
- Change assembly state of R199 from “assembled” to “not assembled”
- Change R80 from 10k/63mW/5%/0402 to 200k/63mW/1%/0402
- Change R173 from 10k/63mW/5%/0402 to 100k/63mW/1%/0402
- Change R116 from 10k/63mW/5%/0402 to 100k/63mW/1%/0402
Q4 2024
Errata/Known Issues
Errata Document
Mallow Carrier Board Errata
Hardware Errata/Known issues
Migration in Progress
Issue trackers are not yet available in the new developer website. See it on the archived developer website.
