Create OSTree Union
Article updated at 24 Jul 2019
Warning: the Torizon Update System is a project currently under development at Toradex Labs. It is still an experimental project in it's early stages which is subject to changes without notice. This might impact new releases and/or iterations.
It is possible to create unions for OSTree, which is faster than committing whole changes due to re-checksum of data that already exists. For more information, read the OSTree documentation Writing a buildsystem and managing repositories. The presented instructions go through how to create a OSTree union from an existing one provided by Toradex, as well as modify unions, commit changes and more.
  • OSTree installed in your computer
  • Have existing OSTree ( for example Toradex one - we show how to fetch it in the article )
Create the OSTree Union
This section goes through the process of creating a new root filesystem from an OSTree union.
Pull Toradex OSTree to Your Computer
Commands below will init new ostree repository inside folder toradex-os-tree and add new remote called toradex. In last step it will pull branch torizon/torizon-core-docker. Depth 1 means only latest commit.
$ mkdir toradex-os-tree
$ ostree --repo=toradex-os-tree init --mode=bare-user
$ ostree --repo=toradex-os-tree remote add toradex  http://feeds.toradex.com/ostree/torizon-master/nightly/colibri-imx7/ --no-gpg-verify
$ ostree --repo=toradex-os-tree pull toradex torizon/torizon-core-docker --depth=1
Add Example Files
Create folder for your changes:
$ mkdir my-changes
Create or add any file you want to use for this example. Here we create a text file with the directory structure as presented:
$ tree my-changes
my-changes
└── etc
        └── text.txt
$ echo "test" > my-changes/etc/test.txt
Commit Changes
Commit changes to the existing ostree repository, creating a new branch called my-changes:
$ ostree --repo=toradex-os-tree commit -b my-changes --tree=dir=my-changes
Checkout to New Rootfs
This will checkout rootfs from ostree repository to temporary-rootfs:
$ ostree --repo=toradex-os-tree checkout -U --union torizon/torizon-core-docker temporary-rootfs
Checkout new branch and union it with temporary-rootfs:
$ ostree --repo=toradex-os-tree checkout -U --union my-changes temporary-rootfs
Commit all our changes back to ostree with new branch name final-ostree:
$ ostree --repo=toradex-os-tree commit -b final-ostree --tree=dir=temporary-rootfs
Finally, update information about ostree in summary file:
$ ostree --repo=toradex-os-tree summary -u
This OSTree can now be deployed to supported devices.
Note: When doing multiple changes it is wise to always commit back to same branch. This way history is tracked as it should be.
Make Changes on Already Existing Structure
This part considers that one time configuration was set and folder structure is the same as in previous sections.
Make and Commit Changes
Modify the content of a file:
$ echo "test2" > my-changes/etc/test.txt
Commit changes to existing ostree repository, to branch called my-changes:
Check OSTree diff
Running ostree diff command returns the status of OSTree:
$ ostree --repo=toradex-os-tree diff my-changes
Output:
M    /etc/test.txt
Checkout and Union Changes
Checkout changes and union it with temporary-rootfs:
Commit changes back to ostree with new branch name final-ostree:
Update information about ostree in summary file:
