or cat /etc/issue
on the board.
The Linux Kernel of TorizonCore accepts certain boot-time arguments (parameters) that configure aspects of the kernel itself or its modules. This article briefly describes the method provided by the TorizonCore Builder tool (which is part of the Torizon platform) to perform such configuration.
To summarize, the procedure to set the custom kernel arguments follows the standard use of TorizonCore Builder, that is:
kernel set_custom_args
.union
to merge the changes onto the base image.deploy
to deploy them onto the device or to create a new Easy Installer image.To learn which Linux Kernel version corresponds to the latest TorizonCore versions, check the Embedded Linux Release Matrix.
To use TorizonCore Builder, you need to create an alias. Follow the installation instructions on the TorizonCore Builder article. Make sure to:
For setting the custom kernel arguments, one would simply run:
$ torizoncore-builder kernel set_custom_args "param1=value1" "param2=value2" "param3=value3" 'custom-kargs_overlay.dts' compiles successfully. Overlay custom-kargs_overlay.dtbo successfully applied. Kernel custom arguments successfully configured with "param1=value1 param2=value2 param3=value3".
As shown in the above message, a device tree overlay will be applied to the image to set the custom arguments.
This fact can be verified by using the dto status
command, which will display the custom-kargs_overlay.dtbo
amongst any other applied overlays, like so:
$ torizoncore-builder dto status
Enabled overlays over device tree imx6dl-colibri-eval-v3.dtb:
- colibri-imx6_parallel-rgb_overlay.dtbo
- colibri-imx6_stmpe-ts_overlay.dtbo
- display-edt7_overlay.dtbo
- custom-kargs_overlay.dtbo
Warning: Since the arguments are kept in a device-tree overlay, the user should be careful not to remove that overlay (especially by using dto remove --all
) or the arguments will not be present on the deployed image.
To determine what the current custom kernel arguments are (that is, what configuration would take effect upon the execution of a union
command) use:
$ torizoncore-builder kernel get_custom_args
Currently configured custom kernel arguments: "param1=value1 param2=value2 param3=value3".
Finally, it is also possible to clear any applied custom kernel arguments by doing:
$ torizoncore-builder kernel clear_custom_args Custom kernel arguments successfully cleared.
This will remove the corresponding device-tree overlay (custom-kargs_overlay.dtbo
) as done by dto remove
Now that the custom arguments have been applied, you can use the union and deploy commands to deploy the changes either to your device, or create a custom TorizonCore image for Toradex Easy Installer.
Alternatively or in addition to creating a custom image for Toradex Easy Installer, you can deploy your custom kernel arguments using Torizon OTA. Learn how to do it on Signing and Pushing TorizonCore Images to Torizon OTA.
