EDT Display
EDT Display
EDT Display
(Double-Click to Zoom)
Getting Started
warning
Please note that this Product is going End of Life. For alternative displays, please have a look at the Capacitive Touch Display 7" Parallel or the Resistive Touch Display 7" Parallel.
This page contains a variety of information related to the EDT 5.7" and 7.0" displays and is intended to be used as a single point of access for all information you need. Cables are included with the displays and allow an easy connection to Toradex carrier boards supporting the Unified Display Interface.
What I need to order
EDT Display can be ordered along with any Apalis or Colibri module and carrier board.
Where do I order
First Steps
Please read the following articles before using this product.
Having trouble?
Features
Main Features
EDT 7" Display
  • EDT 7" Display with 800x480px
  • 18-bit RGB
  • 4-Wire Resistive Touch
  • Unified TFT Interface from EDT for easy connection to Toradex carrier boards
  • 250mm FFC cable to connect it with a carrier board
  • No special drivers required
EDT 5.7.0" Display
  • EDT 5.7" Display with 640x480px
  • 18-bit RGB
Datasheets
EDT 5.7" Display
EDT 7.0" Display
Compatible Products
Revision History
1203xxxx - Display EDT 5.7" TFT VGA with Touch
12031000
Display EDT 5.7" TFT VGA with Touch V1.0A
Initial Release
2013-12-25
PCN Display EDT 5.7" TFT VGA with Touch V1.0A 2017-02-22
1204xxxx - Display EDT 7.0" TFT WVGA with Touch
12041000
Display EDT 7.0" TFT WVGA with Touch V1.0A
Initial Release
2013-12-25
PCN Display EDT 7.0" TFT WVGA with Touch V1.0A 2017-02-22
Errata
None
