eraseflash command
The eraseflash is a CommandPrompt command. It allows to an area on the built in flashdisk.
Usage:
addr: Erases Flash blocks from the start address addr on.
addr size: Erases Flash Range starting from addr for a certain size. Size needs to be provided in bytes
Example:
eraseflash 10 100
