Toradex does extensive functional testing for verification and validation of its computer on modules before shipping. Every module has a unique serial number fully traceable.
At the end of the assembly line, every module goes through a functional tester and is validated.
A sample output from a functional tester log file is provided below:
functional-test-sample.log<00000040><11:32:30.680> Info: SomFCT Software Version: xxxx <00000030><11:32:30.681> Info: FPGA: \Network\fctbin\bin_FCT\FPGA\fct_top.bit Build: xxxx Version: 18 <00000060><11:32:30.681> Info: Tester: xxxx <00000090><11:32:30.681> Info: Tester controller module (xxxx): xxxx <00000070><11:32:30.681> Info: Tester fixture serial number : xxxx <00000080><11:32:30.682> Info: Tester adapter (xxxx): xxxx <00000140><11:32:30.682> Info: Insertion count: 687 <00000100><11:32:30.682> Info: Site: xxxx <00000050><11:32:30.683> Info: Test Start Time: xxxx <00000150><11:32:30.683> Info: Using Serialport BaudRate: 115200 StopBits: One Parity: None <00000210><11:32:30.683> Info: File \Network\fctbin\bin_FCT\CM\unmanaged.dll version: xxxx <00000180><11:32:30.683> Info: DUT.ini file version: 2.0.11683 <00000190><11:32:30.684> Info: Site.ini file version: 2.0.11414 <00000200><11:32:30.684> Info: Tester_ALL.ini file version: 2.0.11414 <00020100><11:32:30.684> Info: GPIOTest Start <00021000><11:32:30.684> Info: Detected 1 JTAG device(s) in scan chain <00020160><11:32:30.685> Info: Starting GpioTest over JTAG: Walking 0 <00020180><11:32:30.685> Info: Walking 0 test finished successfully <00020190><11:32:30.685> Info: Starting GpioTest over JTAG: Walking 1 <00020210><11:32:30.686> Info: Walking 1 test finished successfully <00020120><11:32:30.686> Info: GPIOTest Passed <00003060><11:32:30.686> Info: Download Start <00004010><11:32:30.686> Info: Power up DUT <00003030><11:32:30.687> Info: Starting to download U-Boot <00000210><11:32:30.687> Info: File \Network\fctbin\bin_FCT\NVFlash\NVFlash_t30.exe version: 2.5.0-20180618 <00003130><11:32:30.687> Serial: Download SerialInput Initial PowerOn Start U-Boot SPL 2016.11-2.7.5+g37f21896ec Trying to boot from RAM U-Boot TEGRA30 DRAM: 1 GiB MMC: <00008040><11:32:30.687> Serial: SerialInput End <00003070><11:32:30.688> Serial: Download SerialOutput Start <00008030><11:32:30.688> Serial: SerialOutput End <00003080><11:32:30.688> Serial: Download SerialInput Start Tegra SD/MMC: 0, Tegra SD/MMC: 1, Tegra SD/MMC: 2 Using default environment In: serial Out: vidconsole Err: vidconsole MISSING TORADEX CONFIG BLOCK Model: Toradex Apalis T30 1GB USB recovery mode, disabled autoboot Net: No ethernet found. Apalis T30 # Apalis T30 # <00008040><11:32:30.688> Serial: SerialInput End <00009230><11:32:30.689> Info: i_bat_uboot = 17e-6 [A] <00009250><11:32:30.689> Info: i_main_uboot = 564e-3 [A] <00006050><11:32:30.689> Info: ConfigBlock Serial number does not exist in flash <00024240><11:32:30.690> Serial: Info SerialOutput Start setenv stdout serial <00008030><11:32:30.690> Serial: SerialOutput End <00024230><11:32:30.690> Serial: Info SerialInput Start setenv stdout serial Apalis T30 # <00008040><11:32:30.691> Serial: SerialInput End <00007000><11:32:30.691> Info: Flushing UART buffer <00003070><11:32:30.691> Serial: Download SerialOutput Start <00008030><11:32:30.691> Serial: SerialOutput End <00003080><11:32:30.692> Serial: Download SerialInput Start Apalis T30 # <00008040><11:32:30.692> Serial: SerialInput End <00027000><11:32:30.692> Info: Eraseing Storage <00024240><11:32:30.692> Serial: Info SerialOutput Start mmc dev 0 1 <00008030><11:32:30.693> Serial: SerialOutput End <00024230><11:32:30.693> Serial: Info SerialInput Start mmc dev 0 1 switch to partitions #1, OK mmc0(part 1) is current device Apalis T30 # <00008040><11:32:30.693> Serial: SerialInput End <00024240><11:32:30.694> Serial: Info SerialOutput Start mmc read ${loadaddr} 0x7fffffff 1 <00008030><11:32:30.694> Serial: SerialOutput End <00024230><11:32:30.694> Serial: Info SerialInput Start mmc read ${loadaddr} 0x7fffffff 1 MMC read: dev # 0, block # 2147483647, count 1 ... MMC: block number 0x80000000 exceeds max(0x8000) 0 blocks read: ERROR Apalis T30 # <00008040><11:32:30.694> Serial: SerialInput End <00024240><11:32:30.695> Serial: Info SerialOutput Start mmc erase 0 0x8000 <00008030><11:32:30.695> Serial: SerialOutput End <00024230><11:32:30.695> Serial: Info SerialInput Start mmc erase 0 0x8000 MMC erase: dev # 0, block # 0, count 32768 ... 32768 blocks erased: OK Apalis T30 # <00008040><11:32:30.695> Serial: SerialInput End <00027100><11:32:30.696> Info: Erasing device 0 partition 1 OK. <00027000><11:32:30.696> Info: Eraseing Storage <00024240><11:32:30.696> Serial: Info SerialOutput Start mmc dev 0 2 <00008030><11:32:30.696> Serial: SerialOutput End <00024230><11:32:30.697> Serial: Info SerialInput Start mmc dev 0 2 switch to partitions #2, OK mmc0(part 2) is current device Apalis T30 # <00008040><11:32:30.697> Serial: SerialInput End <00024240><11:32:30.697> Serial: Info SerialOutput Start mmc read ${loadaddr} 0x7fffffff 1 <00008030><11:32:30.698> Serial: SerialOutput End <00024230><11:32:30.698> Serial: Info SerialInput Start mmc read ${loadaddr} 0x7fffffff 1 MMC read: dev # 0, block # 2147483647, count 1 ... MMC: block number 0x80000000 exceeds max(0x8000) 0 blocks read Apalis T30 # <00008040><11:32:30.698> Serial: SerialInput End <00024240><11:32:30.699> Serial: Info SerialOutput Start mmc erase 0 0x8000 <00008030><11:32:30.699> Serial: SerialOutput End <00024230><11:32:30.699> Serial: Info SerialInput Start mmc erase 0 0x8000 MMC erase: dev # 0, block # 0, count 32768 ... 32768 blocks erased: OK Apalis T30 # <00008040><11:32:30.699> Serial: SerialInput End <00027100><11:32:30.700> Info: Erasing device 0 partition 2 OK. <00006000><11:32:30.700> Info: Start to (re)create the config block <00006090><11:32:30.700> Serial: ConfigBlock SerialOutput Start cfgblock create <00008030><11:32:30.701> Serial: SerialOutput End <00006080><11:32:30.701> Serial: ConfigBlock SerialInput Start cfgblock create Toradex config block successfully written Apalis T30 # <00008040><11:32:30.701> Serial: SerialInput End <00006060><11:32:30.702> Info: Passed to (re)create the config block <00007000><11:32:30.702> Info: Flashing U-Boot to eMMC <00024240><11:32:30.702> Serial: Info SerialOutput Start setenv set_blkcnt 'setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200' <00008030><11:32:30.702> Serial: SerialOutput End <00024230><11:32:30.703> Serial: Info SerialInput Start setenv set_blkcnt 'setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200' Apalis T30 # <00008040><11:32:30.703> Serial: SerialInput End <00024240><11:32:30.703> Serial: Info SerialOutput Start load mmc 2:1 ${loadaddr} ApalisT30/FactoryImage/apalis_t30.img <00008030><11:32:30.703> Serial: SerialOutput End <00024230><11:32:30.704> Serial: Info SerialInput Start load mmc 2:1 ${loadaddr} ApalisT30/FactoryImage/apalis_t30.img reading ApalisT30/FactoryImage/apalis_t30.img 568832 bytes read in 60 ms (9 MiB/s) Apalis T30 # <00008040><11:32:30.704> Serial: SerialInput End <00024240><11:32:30.704> Serial: Info SerialOutput Start run set_blkcnt && mmc dev 0 1 <00008030><11:32:30.704> Serial: SerialOutput End <00024230><11:32:30.705> Serial: Info SerialInput Start run set_blkcnt && mmc dev 0 1 switch to partitions #1, OK mmc0(part 1) is current device Apalis T30 # <00008040><11:32:30.705> Serial: SerialInput End <00024240><11:32:30.705> Serial: Info SerialOutput Start mmc write ${loadaddr} 0x0 ${blkcnt} <00008030><11:32:30.706> Serial: SerialOutput End <00024230><11:32:30.706> Serial: Info SerialInput Start mmc write ${loadaddr} 0x0 ${blkcnt} MMC write: dev # 0, block # 0, count 1111 ... 1111 blocks written: OK Apalis T30 # <00008040><11:32:30.706> Serial: SerialInput End <00024240><11:32:30.706> Serial: Info SerialOutput Start load mmc 2:1 ${fdt_addr_r} ApalisT30/FactoryImage/mbr.bin && mmc dev 0 0 && mmc write ${fdt_addr_r} 0x0 0x1 <00008030><11:32:30.707> Serial: SerialOutput End <00024230><11:32:30.707> Serial: Info SerialInput Start load mmc 2:1 ${fdt_addr_r} ApalisT30/FactoryImage/mbr.bin && mmc dev 0 0 && mmc write ${fdt_addr_r} 0x0 0x1 reading ApalisT30/FactoryImage/mbr.bin 512 bytes read in 18 ms (27.3 KiB/s) switch to partitions #0, OK mmc0(part 0) is current device MMC write: dev # 0, block # 0, count 1 ... 1 blocks written: OK Apalis T30 # <00008040><11:32:30.707> Serial: SerialInput End <00024240><11:32:30.707> Serial: Info SerialOutput Start load mmc 2:1 ${fdt_addr_r} ApalisT30/FactoryImage/boot.vfat && run set_blkcnt && mmc dev 0 0 && mmc write ${fdt_addr_r} 0x2000 ${blkcnt} <00008030><11:32:30.708> Serial: SerialOutput End <00024230><11:32:30.708> Serial: Info SerialInput Start load mmc 2:1 ${fdt_addr_r} ApalisT30/FactoryImage/boot.vfat && run set_blkcnt && mmc dev 0 0 && mmc write ${fdt_addr_r} 0x2000 ${blkcnt} reading ApalisT30/FactoryImage/boot.vfat 16777216 bytes read in 949 ms (16.9 MiB/s) switch to partitions #0, OK mmc0(part 0) is current device MMC write: dev # 0, block # 8192, count 32768 ... 32768 blocks written: OK Apalis T30 # <00008040><11:32:30.708> Serial: SerialInput End <00007008><11:32:30.708> Info: Passed to Flash U-Boot to eMMC <00007020><11:32:30.709> Info: Flashing Passed <00024240><11:32:30.709> Serial: Info SerialOutput Start mmcinfo <00008030><11:32:30.709> Serial: SerialOutput End <00024230><11:32:30.710> Serial: Info SerialInput Start mmcinfo Device: Tegra SD/MMC Manufacturer ID: 13 OEM: 14e Name: Q2J54 Tran Speed: 52000000 Rd Block Len: 512 MMC version 5.0 High Capacity: Yes Capacity: 3.6 GiB Bus Width: 8-bit Erase Group Size: 512 KiB HC WP Group Size: 8 MiB User Capacity: 3.6 GiB WRREL Boot Capacity: 16 MiB ENH RPMB Capacity: 512 KiB ENH Apalis T30 # <00008040><11:32:30.710> Serial: SerialInput End <00023200><11:32:30.710> Info: eMMC Size 3.6 GiB OK. <00024240><11:32:30.710> Serial: Info SerialOutput Start mmcinfo <00008030><11:32:30.711> Serial: SerialOutput End <00024230><11:32:30.711> Serial: Info SerialInput Start mmcinfo Device: Tegra SD/MMC Manufacturer ID: 13 OEM: 14e Name: Q2J54 Tran Speed: 52000000 Rd Block Len: 512 MMC version 5.0 High Capacity: Yes Capacity: 3.6 GiB Bus Width: 8-bit Erase Group Size: 512 KiB HC WP Group Size: 8 MiB User Capacity: 3.6 GiB WRREL Boot Capacity: 16 MiB ENH RPMB Capacity: 512 KiB ENH Apalis T30 # <00008040><11:32:30.711> Serial: SerialInput End <00023230><11:32:30.712> Info: eMMC Boot Size 16 MiB OK. <00024240><11:32:30.712> Serial: Info SerialOutput Start ver <00008030><11:32:30.712> Serial: SerialOutput End <00024230><11:32:30.712> Serial: Info SerialInput Start ver U-Boot 2016.11-2.7.5+g37f21896ec (Jun 07 2018 - 06:54:12 +0200) arm-oe-linux-gnueabi-gcc (Linaro GCC 6.2-2016.11) 6.2.1 20161016 GNU ld (GNU Binutils) 2.27.0.20160806 Apalis T30 # <00008040><11:32:30.713> Serial: SerialInput End <00005023><11:32:30.713> Info: FctDutUboot version: U-Boot 2016.11-2.7.5+g37f21896ec <00024240><11:32:30.713> Serial: Info SerialOutput Start bdinfo <00008030><11:32:30.714> Serial: SerialOutput End <00024230><11:32:30.714> Serial: Info SerialInput Start bdinfo arch_number = 0x000011A1 boot_params = 0x80000100 DRAM bank = 0x00000000 -> start = 0x80000000 -> size = 0x40000000 baudrate = 115200 bps TLB addr = 0xBFFF0000 relocaddr = 0xBFC51000 reloc off = 0x3FB41000 irq_sp = 0xBD748A20 sp start = 0xBD748A10 Early malloc usage: 160 / 1800 Apalis T30 # <00008040><11:32:30.714> Serial: SerialInput End <00023000><11:32:30.714> Info: Info Memory Size OK <00019020><11:32:30.715> Info: MemoryTest Start <00019060><11:32:30.715> Serial: MemoryTest SerialOutput Start mtest 80000000 82000000 0 1 <00008030><11:32:30.715> Serial: SerialOutput End <00019050><11:32:30.715> Serial: MemoryTest SerialInput Start mtest 80000000 82000000 0 1 Testing 80000000 ... 82000000: Iteration: 1 Pattern 00000000 Writing... Reading...Tested 1 iteration(s) with 0 errors. Apalis T30 # <00008040><11:32:30.716> Serial: SerialInput End <00019010><11:32:30.716> Info: MemoryTest Passed <00005050><11:32:30.716> Info: BootTest Booting Fct Dut Linux <00005130><11:32:30.717> Serial: BootTest SerialOutput Start setenv bootargs video=HDMI-A-1:640x480-32@60 console=ttyS0,115200n rootfstype=squashfs igb_mac=${ethaddr} autoinstall root=/dev/ram lp0_vec=2064@0xf46ff000 core_edp_mv=1150 core_edp_ma=4000 usb_port_owner_info=2 lane_owner_info=6 emc_max_dvfs=0 user_debug=30 && load mmc 2:1 ${kernel_addr_r} ApalisT30/TestingImage/zImage && load mmc 2:1 ${fdt_addr_r} ApalisT30/TestingImage/zImage-tegra30-apalis-eval.dtb && load mmc 2:1 ${ramdisk_addr_r} ApalisT30/TestingImage/tester-apalis-t30-mainline.squashfs &&bootz ${kernel_addr_r} ${ramdisk_addr_r}:${filesize} ${fdt_addr_r} <00008030><11:32:30.717> Serial: SerialOutput End <00005120><11:32:30.717> Serial: BootTest SerialInput Start setenv bootargs video=HDMI-A-1:640x480-32@60 console=ttyS0,115200n rootfstype=squashfs igb_mac=${ethaddr} autoinstall root=/dev/ram lp0_vec=2064@0xf46ff000 core_edp_mv=1150 core_edp_ma=4000 usb_port_owner_info=2 lane_owner_info=6 emc_max_dvfs=0 user_debug=30 && load mmc 2:1 ${kernel_addr_r} ApalisT30/TestingImage/zImage && load mmc 2:1 ${fdt_addr_r} ApalisT30/TestingImage/zImage-tegra30-apalis-eval.dtb && load mmc 2:1 ${ramdisk_addr_r} ApalisT30/TestingImage/tester-apalis-t30-mainline.squashfs &&bootz ${kernel_addr_r} ${ramdisk_addr_r}:${filesize} ${fdt_addr_r} reading ApalisT30/TestingImage/zImage 6190336 bytes read in 355 ms (16.6 MiB/s) reading ApalisT30/TestingImage/zImage-tegra30-apalis-eval.dtb 30719 bytes read in 28 ms (1 MiB/s) reading ApalisT30/TestingImage/tester-apalis-t30-mainline.squashfs 21983232 bytes read in 1241 ms (16.9 MiB/s) ## Flattened Device Tree blob at 82000000 Booting using the fdt blob at 0x82000000 Using Device Tree in place at 82000000, end 8200a7fe Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.14.48-2.7.5 (pil@linuxdev2.toradex.int) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11)) #6 SMP Thu Jun 7 12:50:09 CEST 2018 [ 0.000000] CPU: ARMv7 Processor [412fc099] revision 9 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: Toradex Apalis T30 on Apalis Evaluation Board [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] cma: Reserved 320 MiB at 0xac000000 [ 0.000000] percpu: Embedded 16 pages/cpu @ab700000 s34892 r8192 d22452 u65536 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 260096 [ 0.000000] Kernel command line: video=HDMI-A-1:640x480-32@60 console=ttyS0,115200n rootfstype=squashfs igb_mac=00:14:2d:00:00:00 autoinstall root=/dev/ram lp0_vec=2064@0xf46ff000 core_edp_mv=1150 core_edp_ma=4000 usb_port_owner_info=2 lane_owner_info=6 emc_max_dvfs=0 user_debug=30 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 675280K/1048576K available (9216K kernel code, 367K rwdata, 2544K rodata, 1024K init, 413K bss, 45616K reserved, 327680K cma-reserved, 0K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xc0800000 - 0xff800000 (1008 MB) [ 0.000000] lowmem : 0x80000000 - 0xc0000000 (1024 MB) [ 0.000000] pkmap : 0x7fe00000 - 0x80000000 ( 2 MB) [ 0.000000] modules : 0x7f000000 - 0x7fe00000 ( 14 MB) [ 0.000000] .text : 0x80008000 - 0x80a00000 (10208 kB) [ 0.000000] .init : 0x80d00000 - 0x80e00000 (1024 kB) [ 0.000000] .data : 0x80e00000 - 0x80e5bd40 ( 368 kB) [ 0.000000] .bss : 0x80e5d000 - 0x80ec463c ( 414 kB) [ 0.000000] Hierarchical RCU implementation. [ 0.000000] RCU event tracing is enabled. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] /interrupt-controller@60004000: 160 interrupts forwarded to /interrupt-controller@50041000 [ 0.000000] L2C: platform modifies aux control register: 0x02080000 -> 0x3e480001 [ 0.000000] L2C: DT/platform modifies aux control register: 0x02080000 -> 0x3e480001 [ 0.000000] L2C-310 erratum 769419 enabled [ 0.000000] L2C-310 enabling early BRESP for Cortex-A9 [ 0.000000] L2C-310: enabling full line of zeros but not enabled in Cortex-A9 [ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled [ 0.000000] L2C-310 cache controller enabled, 8 ways, 1024 kB [ 0.000000] L2C-310: CACHE_ID 0x410000c7, AUX_CTRL 0x4e480001 [ 0.000017] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns [ 0.000050] clocksource: timer_us: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns [ 0.000068] Switching to timer-based delay loop, resolution 1000ns [ 0.001011] Console: colour dummy device 80x30 [ 0.001045] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000) [ 0.001067] pid_max: default: 32768 minimum: 301 [ 0.001251] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001271] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001986] CPU: Testing write buffer coherency: ok [ 0.002353] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.002817] Setting up static identity map for 0x80100000 - 0x801000a0 [ 0.002977] Hierarchical SRCU implementation. [ 0.003758] Tegra Unknown SKU 176 [ 0.003798] Tegra Revision: A03 SKU: 176 CPU Process: 0 SoC Process: 0 [ 0.004950] smp: Bringing up secondary CPUs ... [ 0.010359] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.020349] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [ 0.030325] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [ 0.030453] smp: Brought up 1 node, 4 CPUs [ 0.030480] SMP: Total of 4 processors activated (8.00 BogoMIPS). [ 0.030489] CPU: All CPU(s) started in SVC mode. [ 0.031610] devtmpfs: initialized [ 0.039624] random: get_random_u32 called from bucket_table_alloc+0x100/0x250 with crng_init=0 [ 0.040260] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [ 0.040574] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.040600] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 0.060141] pinctrl core: initialized pinctrl subsystem [ 0.061249] NET: Registered protocol family 16 [ 0.065059] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.066036] cpuidle: using governor menu [ 0.090958] No ATAGs? [ 0.091130] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers. [ 0.091149] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.092831] tegra-mc 7000f000.memory-controller: no memory timings for RAM code 0 registered [ 0.093018] iommu: Adding device reg-dummy to group 0 [ 0.093071] iommu: Adding device 3000.pcie to group 1 [ 0.093123] iommu: Adding device 50000000.host1x to group 2 [ 0.093165] iommu: Adding device 54040000.mpe to group 3 [ 0.093213] iommu: Adding device 54080000.vi to group 4 [ 0.093255] iommu: Adding device 540c0000.epp to group 5 [ 0.093297] iommu: Adding device 54100000.isp to group 6 [ 0.093337] iommu: Adding device 54140000.gr2d to group 7 [ 0.093377] iommu: Adding device 54180000.gr3d to group 8 [ 0.093469] iommu: Adding device 54200000.dc to group 9 [ 0.093550] iommu: Adding device 54240000.dc to group 10 [ 0.093595] iommu: Adding device 54280000.hdmi to group 11 [ 0.093646] iommu: Adding device 50040600.timer to group 12 [ 0.093688] iommu: Adding device 50043000.cache-controller to group 13 [ 0.093729] iommu: Adding device 60005000.timer to group 14 [ 0.093770] iommu: Adding device 60007000.flow-controller to group 15 [ 0.093813] iommu: Adding device 6000a000.dma to group 16 [ 0.093858] iommu: Adding device 6000c000.ahb to group 17 [ 0.093900] iommu: Adding device 6000d000.gpio to group 18 [ 0.093939] iommu: Adding device 70000800.apbmisc to group 19 [ 0.093978] iommu: Adding device 70000868.pinmux to group 20 [ 0.094024] iommu: Adding device 70006000.serial to group 21 [ 0.094066] iommu: Adding device 70006040.serial to group 22 [ 0.094113] iommu: Adding device 70006200.serial to group 23 [ 0.094155] iommu: Adding device 70006300.serial to group 24 [ 0.094197] iommu: Adding device 7000a000.pwm to group 25 [ 0.094237] iommu: Adding device 7000e000.rtc to group 26 [ 0.094278] iommu: Adding device 7000c000.i2c to group 27 [ 0.094319] iommu: Adding device 7000c500.i2c to group 28 [ 0.094361] iommu: Adding device 7000c700.i2c to group 29 [ 0.094403] iommu: Adding device 7000d000.i2c to group 30 [ 0.094449] iommu: Adding device 7000d400.spi to group 31 [ 0.094491] iommu: Adding device 7000da00.spi to group 32 [ 0.094538] iommu: Adding device 7000dc00.spi to group 33 [ 0.094579] iommu: Adding device 7000de00.spi to group 34 [ 0.094620] iommu: Adding device 7000e400.pmc to group 35 [ 0.094661] iommu: Adding device 7000f000.memory-controller to group 36 [ 0.094701] iommu: Adding device 7000f800.fuse to group 37 [ 0.094741] iommu: Adding device 70030000.hda to group 38 [ 0.094782] iommu: Adding device 70080000.ahub to group 39 [ 0.094827] iommu: Adding device 78000000.sdhci to group 40 [ 0.094869] iommu: Adding device 78000400.sdhci to group 41 [ 0.094911] iommu: Adding device 78000600.sdhci to group 42 [ 0.094953] iommu: Adding device 7d000000.usb to group 43 [ 0.095001] iommu: Adding device 7d000000.usb-phy to group 44 [ 0.095042] iommu: Adding device 7d004000.usb to group 45 [ 0.095083] iommu: Adding device 7d004000.usb-phy to group 46 [ 0.095124] iommu: Adding device 7d008000.usb to group 47 [ 0.095170] iommu: Adding device 7d008000.usb-phy to group 48 [ 0.095213] iommu: Adding device pmu to group 49 [ 0.095253] iommu: Adding device clocks to group 50 [ 0.095292] iommu: Adding device regulators to group 51 [ 0.095333] iommu: Adding device regulators:regulator@100 to group 52 [ 0.095373] iommu: Adding device regulators:regulator@101 to group 53 [ 0.095415] iommu: Adding device regulators:regulator@102 to group 54 [ 0.095464] iommu: Adding device regulators:regulator@103 to group 55 [ 0.095505] iommu: Adding device regulators:regulator@1 to group 56 [ 0.095547] iommu: Adding device regulators:regulator@2 to group 57 [ 0.095593] iommu: Adding device regulators:regulator@3 to group 58 [ 0.095633] iommu: Adding device sound to group 59 [ 0.095673] iommu: Adding device backlight to group 60 [ 0.095712] iommu: Adding device gpio-keys to group 61 [ 0.095751] iommu: Adding device panel to group 62 [ 0.095790] iommu: Adding device pwmleds to group 63 [ 0.108115] 5v0: Failed to create debugfs directory [ 0.108267] usbo1_vbus: Failed to request enable GPIO157: -517 [ 0.108288] reg-fixed-voltage regulators:regulator@2: Failed to register regulator: -517 [ 0.108408] usbh_vbus: Failed to request enable GPIO233: -517 [ 0.108426] reg-fixed-voltage regulators:regulator@3: Failed to register regulator: -517 [ 0.109555] vgaarb: loaded [ 0.110113] SCSI subsystem initialized [ 0.110574] usbcore: registered new interface driver usbfs [ 0.110640] usbcore: registered new interface driver hub [ 0.110745] usbcore: registered new device driver usb [ 0.116597] iommu: Adding device tps65910-gpio to group 64 [ 0.117058] iommu: Adding device tps65910-pmic to group 65 [ 0.119798] vrtc: supplied by 5v0 [ 0.123301] vio: supplied by 3v3 [ 0.132042] vdd1: supplied by 3v3 [ 0.142028] vdd2: supplied by 3v3 [ 0.143489] vdd_pexa,vdd_pexb,vdd_sata: Bringing 1500000uV into 1050000-1050000uV [ 0.146841] vdd_cpu,vdd_sys: Bringing 1012500uV into 1150000-1150000uV [ 0.151982] ldo1: supplied by vdd_1v8_gen [ 0.154545] ldo2: supplied by vdd_1v8_gen [ 0.155078] en_3v3: Bringing 1200000uV into 3300000-3300000uV [ 0.162002] ldo3: supplied by 3v3 [ 0.162526] avdd_dsi_csi,pwrdet_mipi: Bringing 1000000uV into 1200000-1200000uV [ 0.164947] ldo4: supplied by 3v3 [ 0.172005] ldo5: supplied by 3v3 [ 0.172527] avdd_vdac: Bringing 1000000uV into 2800000-2800000uV [ 0.182002] ldo6: supplied by vdd_1v8_gen [ 0.182541] avdd_plle: Bringing 1000000uV into 1100000-1100000uV [ 0.184941] ldo7: supplied by vdd_1v8_gen [ 0.191995] ldo8: supplied by vdd_1v8_gen [ 0.200247] iommu: Adding device tps65910-rtc to group 66 [ 0.200380] iommu: Adding device tps65910-power to group 67 [ 0.201330] stmpe-i2c 3-0041: stmpe811 detected, chip id: 0x811 [ 0.231131] iommu: Adding device stmpe-ts to group 68 [ 0.232106] random: fast init done [ 0.233616] Linux video capture interface: v2.00 [ 0.233687] pps_core: LinuxPPS API ver. 1 registered [ 0.233698] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.233725] PTP clock support registered [ 0.234174] Advanced Linux Sound Architecture Driver Initialized. [ 0.235046] iommu: Adding device regulatory.0 to group 69 [ 0.236057] clocksource: Switched to clocksource timer_us [ 0.236223] VFS: Disk quotas dquot_6.6.0 [ 0.236316] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.246748] NET: Registered protocol family 2 [ 0.247490] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 0.247596] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 0.247759] TCP: Hash tables configured (established 8192 bind 8192) [ 0.247923] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.247996] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.248225] NET: Registered protocol family 1 [ 0.248741] RPC: Registered named UNIX socket transport module. [ 0.248755] RPC: Registered udp transport module. [ 0.248764] RPC: Registered tcp transport module. [ 0.248773] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.249016] Trying to unpack rootfs image as initramfs... [ 0.249276] rootfs image is not initramfs (junk in compressed archive); looks like an initrd [ 0.369179] Freeing initrd memory: 21468K [ 0.370333] hw perfevents: no interrupt-affinity property for /pmu, guessing. [ 0.370833] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available [ 0.371509] iommu: Adding device alarmtimer to group 70 [ 0.372684] workingset: timestamp_bits=30 max_order=18 bucket_order=0 [ 0.373302] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.373646] NFS: Registering the id_resolver key type [ 0.373685] Key type id_resolver registered [ 0.373695] Key type id_legacy registered [ 0.373717] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.374158] ntfs: driver 2.1.32 [Flags: R/W]. [ 0.374401] fuse init (API version 7.26) [ 0.382064] io scheduler noop registered (default) [ 0.382081] io scheduler mq-deadline registered [ 0.382092] io scheduler kyber registered [ 0.389910] tegra-pcie 3000.pcie: 4x1, 1x2 configuration [ 0.393076] tegra-pcie 3000.pcie: probing port 0, using 4 lanes [ 0.799776] tegra-pcie 3000.pcie: link 0 down, retrying [ 1.206631] tegra-pcie 3000.pcie: link 0 down, retrying [ 1.613480] tegra-pcie 3000.pcie: link 0 down, retrying [ 1.616523] tegra-pcie 3000.pcie: link 0 down, ignoring [ 1.616623] tegra-pcie 3000.pcie: probing port 1, using 1 lanes [ 1.654002] tegra-pcie 3000.pcie: probing port 2, using 1 lanes [ 1.683494] tegra-pcie 3000.pcie: PCI host bridge to bus 0000:00 [ 1.683515] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] [ 1.683531] pci_bus 0000:00: root bus resource [mem 0x20000000-0x27ffffff] [ 1.683547] pci_bus 0000:00: root bus resource [mem 0x28000000-0x3fffffff pref] [ 1.683564] pci_bus 0000:00: root bus resource [bus 00-ff] [ 1.683644] pci_bus 0000:00: 2-byte config write to 0000:00:02.0 offset 0x4 may corrupt adjacent RW1C bits [ 1.683664] pci_bus 0000:00: 2-byte config write to 0000:00:02.0 offset 0x4 may corrupt adjacent RW1C bits [ 1.683701] pci 0000:00:02.0: enabling Extended Tags [ 1.683719] pci_bus 0000:00: 2-byte config write to 0000:00:02.0 offset 0x88 may corrupt adjacent RW1C bits [ 1.683765] pci_bus 0000:00: 2-byte config write to 0000:00:02.0 offset 0x52 may corrupt adjacent RW1C bits [ 1.683823] pci_bus 0000:00: 2-byte config write to 0000:00:02.0 offset 0x4c may corrupt adjacent RW1C bits [ 1.684130] pci_bus 0000:00: 2-byte config write to 0000:00:03.0 offset 0x4 may corrupt adjacent RW1C bits [ 1.684150] pci_bus 0000:00: 2-byte config write to 0000:00:03.0 offset 0x4 may corrupt adjacent RW1C bits [ 1.684182] pci 0000:00:03.0: enabling Extended Tags [ 1.684201] pci_bus 0000:00: 2-byte config write to 0000:00:03.0 offset 0x88 may corrupt adjacent RW1C bits [ 1.684237] pci_bus 0000:00: 2-byte config write to 0000:00:03.0 offset 0x52 may corrupt adjacent RW1C bits [ 1.684287] pci_bus 0000:00: 2-byte config write to 0000:00:03.0 offset 0x4c may corrupt adjacent RW1C bits [ 1.684543] PCI: bus0: Fast back to back transfers disabled [ 1.684563] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 1.684584] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 1.706135] PCI: bus1: Fast back to back transfers disabled [ 1.736118] PCI: bus2: Fast back to back transfers disabled [ 1.736194] pci 0000:00:03.0: BAR 8: assigned [mem 0x20000000-0x20bfffff] [ 1.736214] pci 0000:00:02.0: BAR 8: assigned [mem 0x20c00000-0x20cfffff] [ 1.736231] pci 0000:00:03.0: BAR 7: assigned [io 0x1000-0x1fff] [ 1.736252] pci 0000:01:00.0: BAR 0: assigned [mem 0x20c00000-0x20c01fff 64bit] [ 1.736291] pci 0000:00:02.0: PCI bridge to [bus 01] [ 1.736310] pci 0000:00:02.0: bridge window [mem 0x20c00000-0x20cfffff] [ 1.736335] pci 0000:02:00.0: BAR 0: assigned [mem 0x20000000-0x207fffff] [ 1.736356] pci 0000:02:00.0: BAR 3: assigned [mem 0x20800000-0x20803fff] [ 1.736375] pci 0000:02:00.0: BAR 2: assigned [io 0x1000-0x101f] [ 1.736394] pci 0000:00:03.0: PCI bridge to [bus 02] [ 1.736408] pci 0000:00:03.0: bridge window [io 0x1000-0x1fff] [ 1.736424] pci 0000:00:03.0: bridge window [mem 0x20000000-0x20bfffff] [ 1.736468] pci 0000:00:02.0: nv_msi_ht_cap_quirk didn't locate host bridge [ 1.736614] pcieport 0000:00:02.0: enabling device (0140 -> 0142) [ 1.736911] pcieport 0000:00:02.0: Signaling PME with IRQ 384 [ 1.737058] pci 0000:00:03.0: nv_msi_ht_cap_quirk didn't locate host bridge [ 1.737170] pcieport 0000:00:03.0: enabling device (0140 -> 0143) [ 1.737428] pcieport 0000:00:03.0: Signaling PME with IRQ 385 [ 1.737572] pci 0000:01:00.0: enabling device (0140 -> 0142) [ 1.738389] pwm-backlight backlight: backlight supply power not found, using dummy regulator [ 1.743373] tegra-apbdma 6000a000.dma: Tegra20 APB DMA driver register 32 channels [ 1.744961] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled. [ 1.745549] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 1.745693] iommu: Adding device serial8250 to group 71 [ 1.747675] console [ttyS0] disabled [ 1.747750] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 331, base_baud = 25500000) is a Tegra [ 3.326281] console [ttyS0] enabled [ 3.330741] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 332, base_baud = 0) is a TEGRA_UART [ 3.340101] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 333, base_baud = 0) is a TEGRA_UART [ 3.349459] 70006300.serial: ttyTHS3 at MMIO 0x70006300 (irq = 334, base_baud = 0) is a TEGRA_UART [ 3.360580] tegra-dc 54200000.dc: failed to probe RGB output: -517 [ 3.367617] tegra-hdmi 54280000.hdmi: 54280000.hdmi supply hdmi not found, using dummy regulator [ 3.376507] tegra-hdmi 54280000.hdmi: failed to get PLL regulator [ 3.387372] panel-simple panel: panel supply power not found, using dummy regulator [ 3.404274] brd: module loaded [ 3.416384] loop: module loaded [ 3.426930] iommu: Adding device Fixed MDIO bus.0 to group 72 [ 3.432864] libphy: Fixed MDIO Bus: probed [ 3.436981] CAN device driver interface [ 3.451890] mcp251x spi1.1 can0: MCP2515 successfully initialized. [ 3.469064] mcp251x spi3.0 can1: MCP2515 successfully initialized. [ 3.475296] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k [ 3.482279] igb: Copyright (c) 2007-2014 Intel Corporation. [ 3.488030] igb 0000:02:00.0: enabling device (0140 -> 0142) [ 3.727204] pps pps0: new PPS source ptp0 [ 3.731218] igb 0000:02:00.0: added PHC on eth0 [ 3.735743] igb 0000:02:00.0: Intel(R) Gigabit Ethernet Network Connection [ 3.742645] igb 0000:02:00.0: eth0: (PCIe:2.5Gb/s:Width x1) 00:14:2d:00:00:00 [ 3.749795] igb 0000:02:00.0: eth0: PBA No: FFFFFF-0FF [ 3.754931] igb 0000:02:00.0: Using MSI-X interrupts. 4 rx queue(s), 4 tx queue(s) [ 3.762662] usbcore: registered new interface driver asix [ 3.768153] usbcore: registered new interface driver ax88179_178a [ 3.774280] usbcore: registered new interface driver cdc_ether [ 3.780170] usbcore: registered new interface driver cdc_eem [ 3.785861] usbcore: registered new interface driver net1080 [ 3.791574] usbcore: registered new interface driver rndis_host [ 3.797549] usbcore: registered new interface driver cdc_subset [ 3.803497] usbcore: registered new interface driver zaurus [ 3.809146] usbcore: registered new interface driver cdc_ncm [ 3.815565] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 3.822113] ehci-pci: EHCI PCI platform driver [ 3.826626] tegra-ehci: Tegra EHCI driver [ 3.831281] xhci_hcd 0000:01:00.0: Resetting [ 4.886356] xhci_hcd 0000:01:00.0: xHCI Host Controller [ 4.891608] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1 [ 4.905094] xhci_hcd 0000:01:00.0: hcc params 0x014051cf hci version 0x100 quirks 0x00000090 [ 4.914972] hub 1-0:1.0: USB hub found [ 4.918791] hub 1-0:1.0: 2 ports detected [ 4.923337] xhci_hcd 0000:01:00.0: xHCI Host Controller [ 4.928597] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2 [ 4.935996] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed [ 4.942461] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 4.951279] hub 2-0:1.0: USB hub found [ 4.955067] hub 2-0:1.0: 2 ports detected [ 4.960094] usbcore: registered new interface driver cdc_acm [ 4.965745] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 4.973810] usbcore: registered new interface driver cdc_wdm [ 4.979603] usbcore: registered new interface driver usb-storage [ 4.985711] usbcore: registered new interface driver usbserial [ 4.991603] usbcore: registered new interface driver usbserial_generic [ 4.998175] usbserial: USB Serial support registered for generic [ 5.004214] usbcore: registered new interface driver ftdi_sio [ 5.010009] usbserial: USB Serial support registered for FTDI USB Serial Device [ 5.017524] usbcore: registered new interface driver pl2303 [ 5.023120] usbserial: USB Serial support registered for pl2303 [ 5.030854] tegra-udc 7d000000.usb: failed to get PHY: -517 [ 5.044205] input: stmpe-ts as /devices/soc0/7000d000.i2c/i2c-3/3-0041/stmpe-ts/input/input0 [ 6.086124] tegra-i2c 7000c000.i2c: i2c transfer timed out [ 6.091737] rtc-ds1307: probe of 0-0068 failed with error -110 [ 6.098311] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc2 [ 6.105492] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock [ 6.125369] tps65910-rtc tps65910-rtc: rtc core: registered tps65910-rtc as rtc1 [ 6.132843] i2c /dev entries driver [ 6.137286] IR NEC protocol handler initialized [ 6.141812] IR RC5(x/sz) protocol handler initialized [ 6.146891] IR RC6 protocol handler initialized [ 6.151414] IR JVC protocol handler initialized [ 6.155934] IR Sony protocol handler initialized [ 6.160563] IR SANYO protocol handler initialized [ 6.165258] IR Sharp protocol handler initialized [ 6.169971] IR MCE Keyboard/mouse protocol handler initialized [ 6.175793] IR XMP protocol handler initialized [ 6.182548] tegra-wdt 60005000.timer: initialized (heartbeat = 120 sec, nowayout = 0) [ 6.191123] sdhci: Secure Digital Host Controller Interface driver [ 6.197321] sdhci: Copyright(c) Pierre Ossman [ 6.201670] sdhci-pltfm: SDHCI platform and OF driver helper [ 6.207807] sdhci-tegra 78000000.sdhci: Got CD GPIO [ 6.221058] mmc2: Invalid maximum block size, assuming 512 bytes [ 6.286309] mmc2: SDHCI controller on 78000000.sdhci [78000000.sdhci] using ADMA [ 6.295089] sdhci-tegra 78000400.sdhci: Got CD GPIO [ 6.310995] mmc1: Invalid maximum block size, assuming 512 bytes [ 6.340524] mmc2: host does not support reading read-only switch, assuming write-enable [ 6.349805] mmc2: new high speed SDHC card at address 59b4 [ 6.355693] mmcblk2: mmc2:59b4 USD 3.75 GiB [ 6.361254] mmcblk2: p1 [ 6.376259] mmc1: SDHCI controller on 78000400.sdhci [78000400.sdhci] using ADMA [ 6.390292] mmc0: Invalid maximum block size, assuming 512 bytes [ 6.456120] mmc0: SDHCI controller on 78000600.sdhci [78000600.sdhci] using ADMA [ 6.468274] usbcore: registered new interface driver usbhid [ 6.473900] usbhid: USB HID core driver [ 6.482981] iommu: Adding device snd-soc-dummy to group 73 [ 6.490040] sgtl5000 3-000a: sgtl5000 revision 0x11 [ 6.496789] sgtl5000 3-000a: Using internal LDO instead of VDDD: check ER1 [ 6.516786] mmc0: new high speed MMC card at address 0001 [ 6.522614] mmcblk0: mmc0:0001 Q2J54A 3.59 GiB [ 6.527381] mmcblk0boot0: mmc0:0001 Q2J54A partition 1 16.0 MiB [ 6.533491] mmcblk0boot1: mmc0:0001 Q2J54A partition 2 16.0 MiB [ 6.539631] mmcblk0rpmb: mmc0:0001 Q2J54A partition 3 512 KiB [ 6.546518] mmcblk0: p1 p2 [ 6.549524] mmcblk0: p2 size 15175680 extends beyond EOD, truncated [ 6.558998] iommu: Adding device 70080500.i2s to group 74 [ 6.565377] tegra30-i2s 70080500.i2s: DMA channels sourced from device 70080000.ahub [ 6.583604] tegra-snd-sgtl5000 sound: sgtl5000 <-> 70080500.i2s mapping ok [ 6.591978] NET: Registered protocol family 10 [ 6.597791] Segment Routing with IPv6 [ 6.601548] mip6: Mobile IPv6 [ 6.604513] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 6.611817] NET: Registered protocol family 17 [ 6.616313] NET: Registered protocol family 15 [ 6.620751] can: controller area network core (rev 20170425 abi 9) [ 6.627010] NET: Registered protocol family 29 [ 6.631480] can: raw protocol (rev 20170425) [ 6.635744] can: broadcast manager protocol (rev 20170425 t) [ 6.641421] can: netlink gateway (rev 20170425) max_hops=1 [ 6.647195] Key type dns_resolver registered [ 6.652131] Registering SWP/SWPB emulation handler [ 6.668944] +V1.8_AVDD_HDMI_PLL: supplied by vdd_1v8_gen [ 6.674715] +V3.3_AVDD_HDMI: supplied by 3v3 [ 6.679432] usbo1_vbus: supplied by 5v0 [ 6.683646] usbh_vbus: supplied by 5v0 [ 6.688449] tegra-hdmi 54280000.hdmi: 54280000.hdmi supply hdmi not found, using dummy regulator [ 6.701649] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 6.708304] [drm] No driver support for vblank timestamp query. [ 6.779671] Console: switching to colour frame buffer device 80x30 [ 6.802195] drm drm: fb0: frame buffer device [ 6.806697] [drm] Initialized tegra 0.0.0 20120330 for drm on minor 0 [ 6.818815] tegra-ehci 7d004000.usb: EHCI Host Controller [ 6.824241] tegra-ehci 7d004000.usb: new USB bus registered, assigned bus number 3 [ 6.832272] tegra-ehci 7d004000.usb: irq 351, io mem 0x7d004000 [ 6.866439] tegra-ehci 7d004000.usb: USB 2.0 started, EHCI 1.00 [ 6.873178] hub 3-0:1.0: USB hub found [ 6.877021] hub 3-0:1.0: 1 port detected [ 6.881847] tegra-ehci 7d008000.usb: EHCI Host Controller [ 6.887301] tegra-ehci 7d008000.usb: new USB bus registered, assigned bus number 4 [ 6.895214] tegra-ehci 7d008000.usb: irq 352, io mem 0x7d008000 [ 6.926436] tegra-ehci 7d008000.usb: USB 2.0 started, EHCI 1.00 [ 6.933113] hub 4-0:1.0: USB hub found [ 6.936951] hub 4-0:1.0: 1 port detected [ 6.941801] iommu: Adding device ci_hdrc.0 to group 75 [ 6.952200] input: gpio-keys as /devices/soc0/gpio-keys/input/input1 [ 6.958940] hctosys: unable to open rtc device (rtc0) [ 6.964629] ALSA device list: [ 6.967626] #1: Toradex Apalis T30 [ 7.236747] RAMDISK: squashfs filesystem found at block 0 [ 7.236956] input: tegra-hda HDMI/DP,pcm=3 as /devices/soc0/70030000.hda/sound/card0/input2 [ 7.250615] RAMDISK: Loading 21465KiB [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/- [ 7.412270] \|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\ [ 7.579990] |/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\| [ 7.747941] /-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/ [ 7.791270] done. [ 8.012971] VFS: Mounted root (squashfs filesystem) readonly on device 1:0. [ 8.020619] devtmpfs: mounted [ 8.025407] Freeing unused kernel memory: 1024K Running /etc/rc.local... / # <00008040><11:32:30.726> Serial: SerialInput End <00005130><11:32:30.727> Serial: BootTest SerialOutput Start stty columns 200 <00008030><11:32:30.727> Serial: SerialOutput End <00005140><11:32:30.728> Serial: BootTest Extend Line Lenght Start stty columns 200 / # <00008040><11:32:30.728> Serial: SerialInput End <00024240><11:32:30.729> Serial: Info SerialOutput Start uname -r <00008030><11:32:30.729> Serial: SerialOutput End <00024230><11:32:30.729> Serial: Info SerialInput Start uname -r 4.14.48-2.7.5 / # <00008040><11:32:30.730> Serial: SerialInput End <00023060><11:32:30.730> Info: Fct Dut Linux version: 4.14.48-2.7.5 <00016215><11:32:30.730> Info: EthernetTest Checking Network Interface <00024240><11:32:30.730> Serial: Info SerialOutput Start LSPCI=`lspci | grep "Ethernet controller"` <00008030><11:32:30.731> Serial: SerialOutput End <00024230><11:32:30.731> Serial: Info SerialInput Start LSPCI=`lspci | grep "Ethernet controller"` / # <00008040><11:32:30.731> Serial: SerialInput End <00024240><11:32:30.731> Serial: Info SerialOutput Start echo $LSPCI | grep -c "1532" <00008030><11:32:30.732> Serial: SerialOutput End <00024230><11:32:30.732> Serial: Info SerialInput Start echo $LSPCI | grep -c "1532" 0 / # <00008040><11:32:30.732> Serial: SerialInput End <00024240><11:32:30.733> Serial: Info SerialOutput Start echo $LSPCI | grep -c "1531" <00008030><11:32:30.733> Serial: SerialOutput End <00024230><11:32:30.733> Serial: Info SerialInput Start echo $LSPCI | grep -c "1531" 1 / # <00008040><11:32:30.733> Serial: SerialInput End <00024240><11:32:30.734> Serial: Info SerialOutput Start mkdir -p /run/tools <00008030><11:32:30.734> Serial: SerialOutput End <00024230><11:32:30.734> Serial: Info SerialInput Start mkdir -p /run/tools / # <00008040><11:32:30.734> Serial: SerialInput End <00024240><11:32:30.735> Serial: Info SerialOutput Start mount /dev/mmcblk2p1 /run/tools <00008030><11:32:30.735> Serial: SerialOutput End <00024230><11:32:30.735> Serial: Info SerialInput Start mount /dev/mmcblk2p1 /run/tools / # <00008040><11:32:30.735> Serial: SerialInput End <00016218><11:32:30.735> Info: EthernetTest Programming Network Interface <00024240><11:32:30.736> Serial: Info SerialOutput Start /run/tools/ApalisT30/TestingImage/eepromARMtool -nic=1 -f=/run/tools/ApalisT30/TestingImage/I210_Invm_Copper_APM_v0.6.HEX <00008030><11:32:30.737> Serial: SerialOutput End <00024230><11:32:30.737> Serial: Info SerialInput Start /run/tools/ApalisT30/TestingImage/eepromARMtool -nic=1 -f=/run/tools/ApalisT30/TestingImage/I210_Invm_Copper_APM_v0.6.HEX Intel(R) Eeprom ARM Tool NVM/OTP Programming Tool Provided under the terms of a CNDA. Do Not Distribute. Copyright(C) 2013-2014 by Intel(R) Corporation Version 0.6.7 / # <00008040><11:32:30.737> Serial: SerialInput End <00016219><11:32:30.737> Info: EthernetTest Programming Network Interface Passed <00005175><11:32:30.738> Info: BootTest Reboot Start <00024240><11:32:30.738> Serial: Info SerialOutput Start <00008030><11:32:30.738> Serial: SerialOutput End <00003070><11:32:30.738> Serial: Download SerialOutput Start <00008030><11:32:30.738> Serial: SerialOutput End <00003080><11:32:30.739> Serial: Download SerialInput Start Model: Toradex Apalis T30 1GB IT V1.1B, Serial# Net: No ethernet found. Hit any key to stop autoboot: 1 0 Apalis T30 # <00008040><11:32:30.739> Serial: SerialInput End <00024240><11:32:30.739> Serial: Info SerialOutput Start setenv stdout serial <00008030><11:32:30.739> Serial: SerialOutput End <00024230><11:32:30.740> Serial: Info SerialInput Start setenv stdout serial Apalis T30 # <00008040><11:32:30.740> Serial: SerialInput End <00005050><11:32:30.740> Info: BootTest Booting Fct Dut Linux <00005130><11:32:30.740> Serial: BootTest SerialOutput Start setenv bootargs video=HDMI-A-1:640x480-32@60 console=ttyS0,115200n rootfstype=squashfs igb_mac=${ethaddr} autoinstall root=/dev/ram lp0_vec=2064@0xf46ff000 core_edp_mv=1150 core_edp_ma=4000 usb_port_owner_info=2 lane_owner_info=6 emc_max_dvfs=0 user_debug=30 && load mmc 2:1 ${kernel_addr_r} ApalisT30/TestingImage/zImage && load mmc 2:1 ${fdt_addr_r} ApalisT30/TestingImage/zImage-tegra30-apalis-eval.dtb && load mmc 2:1 ${ramdisk_addr_r} ApalisT30/TestingImage/tester-apalis-t30-mainline.squashfs &&bootz ${kernel_addr_r} ${ramdisk_addr_r}:${filesize} ${fdt_addr_r} <00008030><11:32:30.741> Serial: SerialOutput End <00005120><11:32:30.741> Serial: BootTest SerialInput Start setenv bootargs video=HDMI-A-1:640x480-32@60 console=ttyS0,115200n rootfstype=squashfs igb_mac=${ethaddr} autoinstall root=/dev/ram lp0_vec=2064@0xf46ff000 core_edp_mv=1150 core_edp_ma=4000 usb_port_owner_info=2 lane_owner_info=6 emc_max_dvfs=0 user_debug=30 && load mmc 2:1 ${kernel_addr_r} ApalisT30/TestingImage/zImage && load mmc 2:1 ${fdt_addr_r} ApalisT30/TestingImage/zImage-tegra30-apalis-eval.dtb && load mmc 2:1 ${ramdisk_addr_r} ApalisT30/TestingImage/tester-apalis-t30-mainline.squashfs &&bootz ${kernel_addr_r} ${ramdisk_addr_r}:${filesize} ${fdt_addr_r} reading ApalisT30/TestingImage/zImage 6190336 bytes read in 356 ms (16.6 MiB/s) reading ApalisT30/TestingImage/zImage-tegra30-apalis-eval.dtb 30719 bytes read in 28 ms (1 MiB/s) reading ApalisT30/TestingImage/tester-apalis-t30-mainline.squashfs 21983232 bytes read in 1240 ms (16.9 MiB/s) ## Flattened Device Tree blob at 82000000 Booting using the fdt blob at 0x82000000 Using Device Tree in place at 82000000, end 8200a7fe Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.14.48-2.7.5 (pil@linuxdev2.toradex.int) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11)) #6 SMP Thu Jun 7 12:50:09 CEST 2018 [ 0.000000] CPU: ARMv7 Processor [412fc099] revision 9 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: Toradex Apalis T30 on Apalis Evaluation Board [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] cma: Reserved 320 MiB at 0xac000000 [ 0.000000] percpu: Embedded 16 pages/cpu @ab700000 s34892 r8192 d22452 u65536 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 260096 [ 0.000000] Kernel command line: video=HDMI-A-1:640x480-32@60 console=ttyS0,115200n rootfstype=squashfs igb_mac=00:14:2d:61:d1:7e autoinstall root=/dev/ram lp0_vec=2064@0xf46ff000 core_edp_mv=1150 core_edp_ma=4000 usb_port_owner_info=2 lane_owner_info=6 emc_max_dvfs=0 user_debug=30 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 675280K/1048576K available (9216K kernel code, 367K rwdata, 2544K rodata, 1024K init, 413K bss, 45616K reserved, 327680K cma-reserved, 0K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xc0800000 - 0xff800000 (1008 MB) [ 0.000000] lowmem : 0x80000000 - 0xc0000000 (1024 MB) [ 0.000000] pkmap : 0x7fe00000 - 0x80000000 ( 2 MB) [ 0.000000] modules : 0x7f000000 - 0x7fe00000 ( 14 MB) [ 0.000000] .text : 0x80008000 - 0x80a00000 (10208 kB) [ 0.000000] .init : 0x80d00000 - 0x80e00000 (1024 kB) [ 0.000000] .data : 0x80e00000 - 0x80e5bd40 ( 368 kB) [ 0.000000] .bss : 0x80e5d000 - 0x80ec463c ( 414 kB) [ 0.000000] Hierarchical RCU implementation. [ 0.000000] RCU event tracing is enabled. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] /interrupt-controller@60004000: 160 interrupts forwarded to /interrupt-controller@50041000 [ 0.000000] L2C: platform modifies aux control register: 0x02080000 -> 0x3e480001 [ 0.000000] L2C: DT/platform modifies aux control register: 0x02080000 -> 0x3e480001 [ 0.000000] L2C-310 erratum 769419 enabled [ 0.000000] L2C-310 enabling early BRESP for Cortex-A9 [ 0.000000] L2C-310: enabling full line of zeros but not enabled in Cortex-A9 [ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled [ 0.000000] L2C-310 cache controller enabled, 8 ways, 1024 kB [ 0.000000] L2C-310: CACHE_ID 0x410000c7, AUX_CTRL 0x4e480001 [ 0.000016] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns [ 0.000048] clocksource: timer_us: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns [ 0.000066] Switching to timer-based delay loop, resolution 1000ns [ 0.000991] Console: colour dummy device 80x30 [ 0.001024] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=10000) [ 0.001045] pid_max: default: 32768 minimum: 301 [ 0.001221] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001241] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001928] CPU: Testing write buffer coherency: ok [ 0.002278] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.002728] Setting up static identity map for 0x80100000 - 0x801000a0 [ 0.002886] Hierarchical SRCU implementation. [ 0.003658] Tegra Unknown SKU 176 [ 0.003697] Tegra Revision: A03 SKU: 176 CPU Process: 0 SoC Process: 0 [ 0.004841] smp: Bringing up secondary CPUs ... [ 0.010302] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.020296] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 [ 0.030272] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 [ 0.030405] smp: Brought up 1 node, 4 CPUs [ 0.030432] SMP: Total of 4 processors activated (8.00 BogoMIPS). [ 0.030441] CPU: All CPU(s) started in SVC mode. [ 0.031531] devtmpfs: initialized [ 0.039383] random: get_random_u32 called from bucket_table_alloc+0x100/0x250 with crng_init=0 [ 0.039986] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [ 0.040285] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.040312] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 0.058719] pinctrl core: initialized pinctrl subsystem [ 0.059744] NET: Registered protocol family 16 [ 0.063422] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.064375] cpuidle: using governor menu [ 0.088984] No ATAGs? [ 0.089152] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers. [ 0.089171] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.090836] tegra-mc 7000f000.memory-controller: no memory timings for RAM code 0 registered [ 0.091025] iommu: Adding device reg-dummy to group 0 [ 0.091074] iommu: Adding device 3000.pcie to group 1 [ 0.091118] iommu: Adding device 50000000.host1x to group 2 [ 0.091158] iommu: Adding device 54040000.mpe to group 3 [ 0.091204] iommu: Adding device 54080000.vi to group 4 [ 0.091245] iommu: Adding device 540c0000.epp to group 5 [ 0.091285] iommu: Adding device 54100000.isp to group 6 [ 0.091324] iommu: Adding device 54140000.gr2d to group 7 [ 0.091363] iommu: Adding device 54180000.gr3d to group 8 [ 0.091454] iommu: Adding device 54200000.dc to group 9 [ 0.091539] iommu: Adding device 54240000.dc to group 10 [ 0.091582] iommu: Adding device 54280000.hdmi to group 11 [ 0.091628] iommu: Adding device 50040600.timer to group 12 [ 0.091670] iommu: Adding device 50043000.cache-controller to group 13 [ 0.091710] iommu: Adding device 60005000.timer to group 14 [ 0.091749] iommu: Adding device 60007000.flow-controller to group 15 [ 0.091790] iommu: Adding device 6000a000.dma to group 16 [ 0.091828] iommu: Adding device 6000c000.ahb to group 17 [ 0.091869] iommu: Adding device 6000d000.gpio to group 18 [ 0.091908] iommu: Adding device 70000800.apbmisc to group 19 [ 0.091948] iommu: Adding device 70000868.pinmux to group 20 [ 0.091997] iommu: Adding device 70006000.serial to group 21 [ 0.092037] iommu: Adding device 70006040.serial to group 22 [ 0.092077] iommu: Adding device 70006200.serial to group 23 [ 0.092117] iommu: Adding device 70006300.serial to group 24 [ 0.092157] iommu: Adding device 7000a000.pwm to group 25 [ 0.092197] iommu: Adding device 7000e000.rtc to group 26 [ 0.092238] iommu: Adding device 7000c000.i2c to group 27 [ 0.092278] iommu: Adding device 7000c500.i2c to group 28 [ 0.092320] iommu: Adding device 7000c700.i2c to group 29 [ 0.092361] iommu: Adding device 7000d000.i2c to group 30 [ 0.092416] iommu: Adding device 7000d400.spi to group 31 [ 0.092458] iommu: Adding device 7000da00.spi to group 32 [ 0.092499] iommu: Adding device 7000dc00.spi to group 33 [ 0.092540] iommu: Adding device 7000de00.spi to group 34 [ 0.092580] iommu: Adding device 7000e400.pmc to group 35 [ 0.092621] iommu: Adding device 7000f000.memory-controller to group 36 [ 0.092660] iommu: Adding device 7000f800.fuse to group 37 [ 0.092701] iommu: Adding device 70030000.hda to group 38 [ 0.092741] iommu: Adding device 70080000.ahub to group 39 [ 0.092786] iommu: Adding device 78000000.sdhci to group 40 [ 0.092828] iommu: Adding device 78000400.sdhci to group 41 [ 0.092873] iommu: Adding device 78000600.sdhci to group 42 [ 0.092915] iommu: Adding device 7d000000.usb to group 43 [ 0.092958] iommu: Adding device 7d000000.usb-phy to group 44 [ 0.092999] iommu: Adding device 7d004000.usb to group 45 [ 0.093040] iommu: Adding device 7d004000.usb-phy to group 46 [ 0.093081] iommu: Adding device 7d008000.usb to group 47 [ 0.093122] iommu: Adding device 7d008000.usb-phy to group 48 [ 0.093165] iommu: Adding device pmu to group 49 [ 0.093203] iommu: Adding device clocks to group 50 [ 0.093243] iommu: Adding device regulators to group 51 [ 0.093285] iommu: Adding device regulators:regulator@100 to group 52 [ 0.093331] iommu: Adding device regulators:regulator@101 to group 53 [ 0.093373] iommu: Adding device regulators:regulator@102 to group 54 [ 0.093414] iommu: Adding device regulators:regulator@103 to group 55 [ 0.093455] iommu: Adding device regulators:regulator@1 to group 56 [ 0.093495] iommu: Adding device regulators:regulator@2 to group 57 [ 0.093540] iommu: Adding device regulators:regulator@3 to group 58 [ 0.093580] iommu: Adding device sound to group 59 [ 0.093619] iommu: Adding device backlight to group 60 [ 0.093658] iommu: Adding device gpio-keys to group 61 [ 0.093696] iommu: Adding device panel to group 62 [ 0.093744] iommu: Adding device pwmleds to group 63 [ 0.105842] 5v0: Failed to create debugfs directory [ 0.105988] usbo1_vbus: Failed to request enable GPIO157: -517 [ 0.106008] reg-fixed-voltage regulators:regulator@2: Failed to register regulator: -517 [ 0.106126] usbh_vbus: Failed to request enable GPIO233: -517 [ 0.106142] reg-fixed-voltage regulators:regulator@3: Failed to register regulator: -517 [ 0.107269] vgaarb: loaded [ 0.107766] SCSI subsystem initialized [ 0.108202] usbcore: registered new interface driver usbfs [ 0.108264] usbcore: registered new interface driver hub [ 0.108365] usbcore: registered new device driver usb [ 0.114187] iommu: Adding device tps65910-gpio to group 64 [ 0.114642] iommu: Adding device tps65910-pmic to group 65 [ 0.117369] vrtc: supplied by 5v0 [ 0.120871] vio: supplied by 3v3 [ 0.132036] vdd1: supplied by 3v3 [ 0.142004] vdd2: supplied by 3v3 [ 0.143461] vdd_pexa,vdd_pexb,vdd_sata: Bringing 1500000uV into 1050000-1050000uV [ 0.146809] vdd_cpu,vdd_sys: Bringing 1012500uV into 1150000-1150000uV [ 0.151982] ldo1: supplied by vdd_1v8_gen [ 0.154541] ldo2: supplied by vdd_1v8_gen [ 0.155071] en_3v3: Bringing 1200000uV into 3300000-3300000uV [ 0.161996] ldo3: supplied by 3v3 [ 0.162517] avdd_dsi_csi,pwrdet_mipi: Bringing 1000000uV into 1200000-1200000uV [ 0.164937] ldo4: supplied by 3v3 [ 0.172004] ldo5: supplied by 3v3 [ 0.172527] avdd_vdac: Bringing 1000000uV into 2800000-2800000uV [ 0.181996] ldo6: supplied by vdd_1v8_gen [ 0.182529] avdd_plle: Bringing 1000000uV into 1100000-1100000uV [ 0.184928] ldo7: supplied by vdd_1v8_gen [ 0.191997] ldo8: supplied by vdd_1v8_gen [ 0.200245] iommu: Adding device tps65910-rtc to group 66 [ 0.200383] iommu: Adding device tps65910-power to group 67 [ 0.201321] stmpe-i2c 3-0041: stmpe811 detected, chip id: 0x811 [ 0.231113] iommu: Adding device stmpe-ts to group 68 [ 0.232064] random: fast init done [ 0.233556] Linux video capture interface: v2.00 [ 0.233624] pps_core: LinuxPPS API ver. 1 registered [ 0.233635] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.233661] PTP clock support registered [ 0.234097] Advanced Linux Sound Architecture Driver Initialized. [ 0.234938] iommu: Adding device regulatory.0 to group 69 [ 0.235905] clocksource: Switched to clocksource timer_us [ 0.236058] VFS: Disk quotas dquot_6.6.0 [ 0.236144] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.246457] NET: Registered protocol family 2 [ 0.247172] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 0.247276] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 0.247439] TCP: Hash tables configured (established 8192 bind 8192) [ 0.247586] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.247670] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.247890] NET: Registered protocol family 1 [ 0.248411] RPC: Registered named UNIX socket transport module. [ 0.248425] RPC: Registered udp transport module. [ 0.248434] RPC: Registered tcp transport module. [ 0.248443] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.248673] Trying to unpack rootfs image as initramfs... [ 0.248925] rootfs image is not initramfs (junk in compressed archive); looks like an initrd [ 0.349156] Freeing initrd memory: 21468K [ 0.350213] hw perfevents: no interrupt-affinity property for /pmu, guessing. [ 0.350685] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available [ 0.351344] iommu: Adding device alarmtimer to group 70 [ 0.352453] workingset: timestamp_bits=30 max_order=18 bucket_order=0 [ 0.353045] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.353377] NFS: Registering the id_resolver key type [ 0.353426] Key type id_resolver registered [ 0.353437] Key type id_legacy registered [ 0.353459] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.353881] ntfs: driver 2.1.32 [Flags: R/W]. [ 0.354101] fuse init (API version 7.26) [ 0.361589] io scheduler noop registered (default) [ 0.361604] io scheduler mq-deadline registered [ 0.361615] io scheduler kyber registered [ 0.369260] tegra-pcie 3000.pcie: 4x1, 1x2 configuration [ 0.372367] tegra-pcie 3000.pcie: probing port 0, using 4 lanes [ 0.779195] tegra-pcie 3000.pcie: link 0 down, retrying [ 1.186038] tegra-pcie 3000.pcie: link 0 down, retrying [ 1.592880] tegra-pcie 3000.pcie: link 0 down, retrying [ 1.595935] tegra-pcie 3000.pcie: link 0 down, ignoring [ 1.596023] tegra-pcie 3000.pcie: probing port 1, using 1 lanes [ 1.633405] tegra-pcie 3000.pcie: probing port 2, using 1 lanes [ 1.662868] tegra-pcie 3000.pcie: PCI host bridge to bus 0000:00 [ 1.662888] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] [ 1.662905] pci_bus 0000:00: root bus resource [mem 0x20000000-0x27ffffff] [ 1.662921] pci_bus 0000:00: root bus resource [mem 0x28000000-0x3fffffff pref] [ 1.662935] pci_bus 0000:00: root bus resource [bus 00-ff] [ 1.663012] pci_bus 0000:00: 2-byte config write to 0000:00:02.0 offset 0x4 may corrupt adjacent RW1C bits [ 1.663032] pci_bus 0000:00: 2-byte config write to 0000:00:02.0 offset 0x4 may corrupt adjacent RW1C bits [ 1.663066] pci 0000:00:02.0: enabling Extended Tags [ 1.663085] pci_bus 0000:00: 2-byte config write to 0000:00:02.0 offset 0x88 may corrupt adjacent RW1C bits [ 1.663129] pci_bus 0000:00: 2-byte config write to 0000:00:02.0 offset 0x52 may corrupt adjacent RW1C bits [ 1.663185] pci_bus 0000:00: 2-byte config write to 0000:00:02.0 offset 0x4c may corrupt adjacent RW1C bits [ 1.663479] pci_bus 0000:00: 2-byte config write to 0000:00:03.0 offset 0x4 may corrupt adjacent RW1C bits [ 1.663500] pci_bus 0000:00: 2-byte config write to 0000:00:03.0 offset 0x4 may corrupt adjacent RW1C bits [ 1.663532] pci 0000:00:03.0: enabling Extended Tags [ 1.663551] pci_bus 0000:00: 2-byte config write to 0000:00:03.0 offset 0x88 may corrupt adjacent RW1C bits [ 1.663586] pci_bus 0000:00: 2-byte config write to 0000:00:03.0 offset 0x52 may corrupt adjacent RW1C bits [ 1.663637] pci_bus 0000:00: 2-byte config write to 0000:00:03.0 offset 0x4c may corrupt adjacent RW1C bits [ 1.663895] PCI: bus0: Fast back to back transfers disabled [ 1.663915] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 1.663936] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 1.685986] PCI: bus1: Fast back to back transfers disabled [ 1.715968] PCI: bus2: Fast back to back transfers disabled [ 1.716041] pci 0000:00:02.0: BAR 8: assigned [mem 0x20000000-0x200fffff] [ 1.716061] pci 0000:00:03.0: BAR 8: assigned [mem 0x20100000-0x201fffff] [ 1.716078] pci 0000:00:03.0: BAR 7: assigned [io 0x1000-0x1fff] [ 1.716100] pci 0000:01:00.0: BAR 0: assigned [mem 0x20000000-0x20001fff 64bit] [ 1.716138] pci 0000:00:02.0: PCI bridge to [bus 01] [ 1.716156] pci 0000:00:02.0: bridge window [mem 0x20000000-0x200fffff] [ 1.716182] pci 0000:02:00.0: BAR 0: assigned [mem 0x20100000-0x2011ffff] [ 1.716204] pci 0000:02:00.0: BAR 3: assigned [mem 0x20120000-0x20123fff] [ 1.716223] pci 0000:02:00.0: BAR 2: assigned [io 0x1000-0x101f] [ 1.716241] pci 0000:00:03.0: PCI bridge to [bus 02] [ 1.716256] pci 0000:00:03.0: bridge window [io 0x1000-0x1fff] [ 1.716272] pci 0000:00:03.0: bridge window [mem 0x20100000-0x201fffff] [ 1.716314] pci 0000:00:02.0: nv_msi_ht_cap_quirk didn't locate host bridge [ 1.716451] pcieport 0000:00:02.0: enabling device (0140 -> 0142) [ 1.716738] pcieport 0000:00:02.0: Signaling PME with IRQ 384 [ 1.716881] pci 0000:00:03.0: nv_msi_ht_cap_quirk didn't locate host bridge [ 1.716990] pcieport 0000:00:03.0: enabling device (0140 -> 0143) [ 1.717239] pcieport 0000:00:03.0: Signaling PME with IRQ 385 [ 1.717381] pci 0000:01:00.0: enabling device (0140 -> 0142) [ 1.718175] pwm-backlight backlight: backlight supply power not found, using dummy regulator [ 1.723082] tegra-apbdma 6000a000.dma: Tegra20 APB DMA driver register 32 channels [ 1.724649] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled. [ 1.725212] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 1.725351] iommu: Adding device serial8250 to group 71 [ 1.727281] console [ttyS0] disabled [ 1.727349] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 331, base_baud = 25500000) is a Tegra [ 3.305791] console [ttyS0] enabled [ 3.310257] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 332, base_baud = 0) is a TEGRA_UART [ 3.319617] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 333, base_baud = 0) is a TEGRA_UART [ 3.328963] 70006300.serial: ttyTHS3 at MMIO 0x70006300 (irq = 334, base_baud = 0) is a TEGRA_UART [ 3.340046] tegra-dc 54200000.dc: failed to probe RGB output: -517 [ 3.347075] tegra-hdmi 54280000.hdmi: 54280000.hdmi supply hdmi not found, using dummy regulator [ 3.355960] tegra-hdmi 54280000.hdmi: failed to get PLL regulator [ 3.366777] panel-simple panel: panel supply power not found, using dummy regulator [ 3.383568] brd: module loaded [ 3.395239] loop: module loaded [ 3.405396] iommu: Adding device Fixed MDIO bus.0 to group 72 [ 3.411363] libphy: Fixed MDIO Bus: probed [ 3.415456] CAN device driver interface [ 3.430312] mcp251x spi1.1 can0: MCP2515 successfully initialized. [ 3.447515] mcp251x spi3.0 can1: MCP2515 successfully initialized. [ 3.453745] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k [ 3.460734] igb: Copyright (c) 2007-2014 Intel Corporation. [ 3.466476] igb 0000:02:00.0: enabling device (0140 -> 0142) [ 3.704975] pps pps0: new PPS source ptp0 [ 3.709020] igb 0000:02:00.0: added PHC on eth0 [ 3.713547] igb 0000:02:00.0: Intel(R) Gigabit Ethernet Network Connection [ 3.720437] igb 0000:02:00.0: eth0: (PCIe:2.5Gb/s:Width x1) 00:14:2d:61:d1:7e [ 3.727582] igb 0000:02:00.0: eth0: PBA No: FFFFFF-0FF [ 3.732718] igb 0000:02:00.0: Using MSI-X interrupts. 4 rx queue(s), 4 tx queue(s) [ 3.740442] usbcore: registered new interface driver asix [ 3.745921] usbcore: registered new interface driver ax88179_178a [ 3.752049] usbcore: registered new interface driver cdc_ether [ 3.757936] usbcore: registered new interface driver cdc_eem [ 3.763624] usbcore: registered new interface driver net1080 [ 3.769336] usbcore: registered new interface driver rndis_host [ 3.775285] usbcore: registered new interface driver cdc_subset [ 3.781255] usbcore: registered new interface driver zaurus [ 3.786902] usbcore: registered new interface driver cdc_ncm [ 3.793282] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 3.799829] ehci-pci: EHCI PCI platform driver [ 3.804321] tegra-ehci: Tegra EHCI driver [ 3.808984] xhci_hcd 0000:01:00.0: Resetting [ 4.886191] xhci_hcd 0000:01:00.0: xHCI Host Controller [ 4.891444] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1 [ 4.904796] xhci_hcd 0000:01:00.0: hcc params 0x014051cf hci version 0x100 quirks 0x00000090 [ 4.914633] hub 1-0:1.0: USB hub found [ 4.918453] hub 1-0:1.0: 2 ports detected [ 4.922987] xhci_hcd 0000:01:00.0: xHCI Host Controller [ 4.928248] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2 [ 4.935647] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed [ 4.942132] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 4.950941] hub 2-0:1.0: USB hub found [ 4.954729] hub 2-0:1.0: 2 ports detected [ 4.959747] usbcore: registered new interface driver cdc_acm [ 4.965398] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 4.973460] usbcore: registered new interface driver cdc_wdm [ 4.979247] usbcore: registered new interface driver usb-storage [ 4.985342] usbcore: registered new interface driver usbserial [ 4.991233] usbcore: registered new interface driver usbserial_generic [ 4.997803] usbserial: USB Serial support registered for generic [ 5.003842] usbcore: registered new interface driver ftdi_sio [ 5.009635] usbserial: USB Serial support registered for FTDI USB Serial Device [ 5.017136] usbcore: registered new interface driver pl2303 [ 5.022731] usbserial: USB Serial support registered for pl2303 [ 5.030446] tegra-udc 7d000000.usb: failed to get PHY: -517 [ 5.043752] input: stmpe-ts as /devices/soc0/7000d000.i2c/i2c-3/3-0041/stmpe-ts/input/input0 [ 6.085973] tegra-i2c 7000c000.i2c: i2c transfer timed out [ 6.091581] rtc-ds1307: probe of 0-0068 failed with error -110 [ 6.098133] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc2 [ 6.105318] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock [ 6.125185] tps65910-rtc tps65910-rtc: rtc core: registered tps65910-rtc as rtc1 [ 6.132655] i2c /dev entries driver [ 6.137093] IR NEC protocol handler initialized [ 6.141618] IR RC5(x/sz) protocol handler initialized [ 6.146697] IR RC6 protocol handler initialized [ 6.151221] IR JVC protocol handler initialized [ 6.155741] IR Sony protocol handler initialized [ 6.160372] IR SANYO protocol handler initialized [ 6.165067] IR Sharp protocol handler initialized [ 6.169780] IR MCE Keyboard/mouse protocol handler initialized [ 6.175603] IR XMP protocol handler initialized [ 6.182330] tegra-wdt 60005000.timer: initialized (heartbeat = 120 sec, nowayout = 0) [ 6.190890] sdhci: Secure Digital Host Controller Interface driver [ 6.197087] sdhci: Copyright(c) Pierre Ossman [ 6.201436] sdhci-pltfm: SDHCI platform and OF driver helper [ 6.207564] sdhci-tegra 78000000.sdhci: Got CD GPIO [ 6.220789] mmc2: Invalid maximum block size, assuming 512 bytes [ 6.286147] mmc2: SDHCI controller on 78000000.sdhci [78000000.sdhci] using ADMA [ 6.294926] sdhci-tegra 78000400.sdhci: Got CD GPIO [ 6.310810] mmc1: Invalid maximum block size, assuming 512 bytes [ 6.340371] mmc2: host does not support reading read-only switch, assuming write-enable [ 6.349649] mmc2: new high speed SDHC card at address 59b4 [ 6.355535] mmcblk2: mmc2:59b4 USD 3.75 GiB [ 6.361063] mmcblk2: p1 [ 6.376102] mmc1: SDHCI controller on 78000400.sdhci [78000400.sdhci] using ADMA [ 6.390140] mmc0: Invalid maximum block size, assuming 512 bytes [ 6.455971] mmc0: SDHCI controller on 78000600.sdhci [78000600.sdhci] using ADMA [ 6.468049] usbcore: registered new interface driver usbhid [ 6.473666] usbhid: USB HID core driver [ 6.482832] iommu: Adding device snd-soc-dummy to group 73 [ 6.489838] sgtl5000 3-000a: sgtl5000 revision 0x11 [ 6.496461] sgtl5000 3-000a: Using internal LDO instead of VDDD: check ER1 [ 6.516621] mmc0: new high speed MMC card at address 0001 [ 6.522427] mmcblk0: mmc0:0001 Q2J54A 3.59 GiB [ 6.527220] mmcblk0boot0: mmc0:0001 Q2J54A partition 1 16.0 MiB [ 6.533332] mmcblk0boot1: mmc0:0001 Q2J54A partition 2 16.0 MiB [ 6.539467] mmcblk0rpmb: mmc0:0001 Q2J54A partition 3 512 KiB [ 6.546597] mmcblk0: p1 p2 [ 6.549597] mmcblk0: p2 size 15175680 extends beyond EOD, truncated [ 6.558625] iommu: Adding device 70080500.i2s to group 74 [ 6.565014] tegra30-i2s 70080500.i2s: DMA channels sourced from device 70080000.ahub [ 6.583105] tegra-snd-sgtl5000 sound: sgtl5000 <-> 70080500.i2s mapping ok [ 6.591409] NET: Registered protocol family 10 [ 6.597167] Segment Routing with IPv6 [ 6.600918] mip6: Mobile IPv6 [ 6.603883] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 6.611154] NET: Registered protocol family 17 [ 6.615613] NET: Registered protocol family 15 [ 6.620072] can: controller area network core (rev 20170425 abi 9) [ 6.626340] NET: Registered protocol family 29 [ 6.630810] can: raw protocol (rev 20170425) [ 6.635073] can: broadcast manager protocol (rev 20170425 t) [ 6.640750] can: netlink gateway (rev 20170425) max_hops=1 [ 6.646497] Key type dns_resolver registered [ 6.651435] Registering SWP/SWPB emulation handler [ 6.667695] +V1.8_AVDD_HDMI_PLL: supplied by vdd_1v8_gen [ 6.673454] +V3.3_AVDD_HDMI: supplied by 3v3 [ 6.678145] usbo1_vbus: supplied by 5v0 [ 6.682358] usbh_vbus: supplied by 5v0 [ 6.687074] tegra-hdmi 54280000.hdmi: 54280000.hdmi supply hdmi not found, using dummy regulator [ 6.700476] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 6.707136] [drm] No driver support for vblank timestamp query. [ 6.777535] Console: switching to colour frame buffer device 80x30 [ 6.800122] drm drm: fb0: frame buffer device [ 6.804599] [drm] Initialized tegra 0.0.0 20120330 for drm on minor 0 [ 6.816599] tegra-ehci 7d004000.usb: EHCI Host Controller [ 6.822021] tegra-ehci 7d004000.usb: new USB bus registered, assigned bus number 3 [ 6.830005] tegra-ehci 7d004000.usb: irq 351, io mem 0x7d004000 [ 6.866243] tegra-ehci 7d004000.usb: USB 2.0 started, EHCI 1.00 [ 6.872970] hub 3-0:1.0: USB hub found [ 6.876805] hub 3-0:1.0: 1 port detected [ 6.881607] tegra-ehci 7d008000.usb: EHCI Host Controller [ 6.887056] tegra-ehci 7d008000.usb: new USB bus registered, assigned bus number 4 [ 6.894962] tegra-ehci 7d008000.usb: irq 352, io mem 0x7d008000 [ 6.926248] tegra-ehci 7d008000.usb: USB 2.0 started, EHCI 1.00 [ 6.932888] hub 4-0:1.0: USB hub found [ 6.936712] hub 4-0:1.0: 1 port detected [ 6.941536] iommu: Adding device ci_hdrc.0 to group 75 [ 6.951054] input: gpio-keys as /devices/soc0/gpio-keys/input/input1 [ 6.957751] hctosys: unable to open rtc device (rtc0) [ 6.963392] ALSA device list: [ 6.966395] #1: Toradex Apalis T30 [ 7.246499] RAMDISK: squashfs filesystem found at block 0 [ 7.251951] RAMDISK: Loading 21465KiB [1 disk] into ram disk... | [ 7.252167] input: tegra-hda HDMI/DP,pcm=3 as /devices/soc0/70030000.hda/sound/card0/input2 [ 7.252268] /-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/ [ 7.415860] -\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/- [ 7.579347] \|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\ [ 7.743105] |/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/ [ 7.778298] done. [ 7.982808] VFS: Mounted root (squashfs filesystem) readonly on device 1:0. [ 7.990495] devtmpfs: mounted [ 7.995194] Freeing unused kernel memory: 1024K Running /etc/rc.local... / # <00008040><11:32:30.742> Serial: SerialInput End <00005177><11:32:30.742> Info: BootTest Reboot Passed <00005130><11:32:30.742> Serial: BootTest SerialOutput Start stty columns 200 <00008030><11:32:30.743> Serial: SerialOutput End <00005140><11:32:30.743> Serial: BootTest Extend Line Lenght Start stty columns 200 / # <00008040><11:32:30.743> Serial: SerialInput End <00016000><11:32:30.743> Info: Setting DUT IP: 10.0.0.106/22 <00016210><11:32:30.744> Serial: EthernetTest SerialOutput Start ip addr add 10.0.0.106/22 dev eth0 <00008030><11:32:30.744> Serial: SerialOutput End <00016200><11:32:30.744> Serial: EthernetTest SerialInput Start ip addr add 10.0.0.106/22 dev eth0 / # <00008040><11:32:30.744> Serial: SerialInput End <00016210><11:32:30.744> Serial: EthernetTest SerialOutput Start ip link set up dev eth0 <00008030><11:32:30.745> Serial: SerialOutput End <00016200><11:32:30.745> Serial: EthernetTest SerialInput Start ip link set up dev eth0 / # <00008040><11:32:30.745> Serial: SerialInput End <00016010><11:32:30.745> Info: EthernetTest DUT IP SET <00017150><11:32:30.745> Serial: USBTest SerialOutput Start gadget-import g1 /etc/usbg/g1.schema <00008030><11:32:30.746> Serial: SerialOutput End <00017140><11:32:30.746> Serial: USBTest SerialInput Start gadget-import g1 /etc/usbg/g1.schema / # <00008040><11:32:30.746> Serial: SerialInput End <00017150><11:32:30.746> Serial: USBTest SerialOutput Start echo $(ls /sys/class/udc/) > /sys/kernel/config/usb_gadget/g1/UDC <00008030><11:32:30.746> Serial: SerialOutput End <00017140><11:32:30.746> Serial: USBTest SerialInput Start echo $(ls /sys/class/udc/) > /sys/kernel/config/usb_gadget/g1/UDC / # <00008040><11:32:30.747> Serial: SerialInput End <00017000><11:32:30.747> Info: USBTest Start <00017010><11:32:30.747> Info: USBTest Disconnecting <00017150><11:32:30.747> Serial: USBTest SerialOutput Start lsusb <00008030><11:32:30.747> Serial: SerialOutput End <00017140><11:32:30.748> Serial: USBTest SerialInput Start lsusb Bus 002 Device 001: ID 1d6b:0003 Bus 004 Device 001: ID 1d6b:0002 Bus 001 Device 001: ID 1d6b:0002 Bus 003 Device 001: ID 1d6b:0002 / # <00008040><11:32:30.748> Serial: SerialInput End <00017090><11:32:30.748> Info: USBTest Succesfully disconnected <00017070><11:32:30.748> Info: Connecting USB Host: 2 <00017110><11:32:30.748> Info: USBTest Succesfully multiplexed <00017150><11:32:30.748> Serial: USBTest SerialOutput Start lsusb <00008030><11:32:30.749> Serial: SerialOutput End <00017140><11:32:30.749> Serial: USBTest SerialInput Start lsusb Bus 003 Device 002: ID 1b67:0000 Bus 002 Device 001: ID 1d6b:0003 Bus 004 Device 001: ID 1d6b:0002 Bus 001 Device 001: ID 1d6b:0002 Bus 003 Device 001: ID 1d6b:0002 / # <00008040><11:32:30.749> Serial: SerialInput End <00017100><11:32:30.749> Info: USB Host: 2 successfully detected <00017010><11:32:30.749> Info: USBTest Disconnecting <00017150><11:32:30.750> Serial: USBTest SerialOutput Start lsusb <00008030><11:32:30.750> Serial: SerialOutput End <00017140><11:32:30.750> Serial: USBTest SerialInput Start lsusb Bus 002 Device 001: ID 1d6b:0003 Bus 004 Device 001: ID 1d6b:0002 Bus 001 Device 001: ID 1d6b:0002 Bus 003 Device 001: ID 1d6b:0002 / # <00008040><11:32:30.750> Serial: SerialInput End <00017090><11:32:30.750> Info: USBTest Succesfully disconnected <00017070><11:32:30.751> Info: Connecting USB Host: 3 <00017110><11:32:30.751> Info: USBTest Succesfully multiplexed <00017150><11:32:30.751> Serial: USBTest SerialOutput Start lsusb <00008030><11:32:30.751> Serial: SerialOutput End <00017140><11:32:30.751> Serial: USBTest SerialInput Start lsusb Bus 002 Device 001: ID 1d6b:0003 Bus 004 Device 002: ID 1b67:0000 Bus 004 Device 001: ID 1d6b:0002 Bus 001 Device 001: ID 1d6b:0002 Bus 003 Device 001: ID 1d6b:0002 / # <00008040><11:32:30.752> Serial: SerialInput End <00017100><11:32:30.752> Info: USB Host: 3 successfully detected <00017050><11:32:30.752> Info: USBTest Passed <00024240><11:32:30.752> Serial: Info SerialOutput Start cat /sys/devices/system/cpu/present <00008030><11:32:30.752> Serial: SerialOutput End <00024230><11:32:30.752> Serial: Info SerialInput Start cat /sys/devices/system/cpu/present 0-3 / # <00008040><11:32:30.753> Serial: SerialInput End <00011120><11:32:30.753> Info: Number of cores=4 <00024240><11:32:30.753> Serial: Info SerialOutput Start dmesg | grep 'can0: MCP2515 successfully initialized' <00008030><11:32:30.753> Serial: SerialOutput End <00024230><11:32:30.753> Serial: Info SerialInput Start dmesg | grep 'can0: MCP2515 successfully initialized' [ 3.430312] mcp251x spi1.1 can0: MCP2515 successfully initialized. / # <00008040><11:32:30.754> Serial: SerialInput End <00011083><11:32:30.754> Info: MCP2515 CAN0 Detected <00024240><11:32:30.754> Serial: Info SerialOutput Start dmesg | grep 'can1: MCP2515 successfully initialized' <00008030><11:32:30.754> Serial: SerialOutput End <00024230><11:32:30.754> Serial: Info SerialInput Start dmesg | grep 'can1: MCP2515 successfully initialized' [ 3.447515] mcp251x spi3.0 can1: MCP2515 successfully initialized. / # <00008040><11:32:30.754> Serial: SerialInput End <00011083><11:32:30.755> Info: MCP2515 CAN1 Detected <00016210><11:32:30.755> Serial: EthernetTest SerialOutput Start dmesg | grep 'sgtl5000 3-000a: sgtl5000 revision' <00008030><11:32:30.755> Serial: SerialOutput End <00016200><11:32:30.755> Serial: EthernetTest SerialInput Start dmesg | grep 'sgtl5000 3-000a: sgtl5000 revision' [ 6.489838] sgtl5000 3-000a: sgtl5000 revision 0x11 / # <00008040><11:32:30.755> Serial: SerialInput End <00011080><11:32:30.755> Info: SGTL5000=SGTL5000 revision 0x11 <00016210><11:32:30.755> Serial: EthernetTest SerialOutput Start dmesg | grep 'stmpe811' <00008030><11:32:30.756> Serial: SerialOutput End <00016200><11:32:30.756> Serial: EthernetTest SerialInput Start dmesg | grep 'stmpe811' [ 0.201321] stmpe-i2c 3-0041: stmpe811 detected, chip id: 0x811 / # <00008040><11:32:30.756> Serial: SerialInput End <00011070><11:32:30.756> Info: STMPE881=STMPE881 revision 0x811 <00024240><11:32:30.756> Serial: Info SerialOutput Start cat sys/bus/mmc/devices/mmc0\:0001/erase_size <00008030><11:32:30.756> Serial: SerialOutput End <00024230><11:32:30.756> Serial: Info SerialInput Start cat sys/bus/mmc/devices/mmc0\:0001/erase_size 524288 / # <00008040><11:32:30.756> Serial: SerialInput End <00011042><11:32:30.757> Info: eMMC Erase Unit=524288 <00024240><11:32:30.757> Serial: Info SerialOutput Start i2cget -f -y 3 0x2D 0x80 <00008030><11:32:30.757> Serial: SerialOutput End <00024230><11:32:30.757> Serial: Info SerialInput Start i2cget -f -y 3 0x2D 0x80 0x02 / # <00008040><11:32:30.757> Serial: SerialInput End <00011091><11:32:30.757> Info: ChipIDs TPS659110 Detected <00024240><11:32:30.757> Serial: Info SerialOutput Start i2cget -f -y 3 0x4C 0xFF <00008030><11:32:30.758> Serial: SerialOutput End <00024230><11:32:30.758> Serial: Info SerialInput Start i2cget -f -y 3 0x4C 0xFF 0xb3 / # <00008040><11:32:30.758> Serial: SerialInput End <00011093><11:32:30.758> Info: ChipIDs LM95245 Detected <00024240><11:32:30.758> Serial: Info SerialOutput Start i2cget -f -y 3 0x60 0x8 <00008030><11:32:30.758> Serial: SerialOutput End <00024230><11:32:30.758> Serial: Info SerialInput Start i2cget -f -y 3 0x60 0x8 0x88 / # <00008040><11:32:30.759> Serial: SerialInput End <00011095><11:32:30.759> Info: ChipIDs TPS62362 Detected <00024240><11:32:30.759> Serial: Info SerialOutput Start cat sys/bus/mmc/devices/mmc0\:0001/cid <00008030><11:32:30.759> Serial: SerialOutput End <00024230><11:32:30.759> Serial: Info SerialInput Start cat sys/bus/mmc/devices/mmc0\:0001/cid 13014e51324a35344110089e23d9c400 / # <00008040><11:32:30.759> Serial: SerialInput End <00011030><11:32:30.759> Info: eMMC CID=13014e51324a35344110089e23d9c400 <00024240><11:32:30.759> Serial: Info SerialOutput Start cat sys/bus/mmc/devices/mmc0\:0001/name <00008030><11:32:30.760> Serial: SerialOutput End <00024230><11:32:30.760> Serial: Info SerialInput Start cat sys/bus/mmc/devices/mmc0\:0001/name Q2J54A / # <00008040><11:32:30.760> Serial: SerialInput End <00011190><11:32:30.760> Info: eMMC name=Q2J54A <00016040><11:32:30.760> Info: EthernetTest Start <00016040><11:32:30.760> Info: EthernetTest Start <00016210><11:32:30.760> Serial: EthernetTest SerialOutput Start lspci -mm <00008030><11:32:30.761> Serial: SerialOutput End <00016200><11:32:30.761> Serial: EthernetTest SerialInput Start lspci -mm 00:02.0 "PCI bridge" "NVIDIA Corporation" "Tegra3+ PCIe x2 Bridge" -ra1 "" "" 00:03.0 "PCI bridge" "NVIDIA Corporation" "Tegra3+ PCIe x2 Bridge" -ra1 "" "" 01:00.0 "USB controller" "Renesas Technology Corp." "uPD720202 USB 3.0 Host Controller" -r02 -p30 "Renesas Technology Corp." "uPD720202 USB 3.0 Host Controller" 02:00.0 "Ethernet controller" "Intel Corporation" "I210 Gigabit Network Connection" -r03 "Intel Corporation" "Device 0000" / # <00008040><11:32:30.761> Serial: SerialInput End <00011160><11:32:30.761> Info: Ethernet PHY= I210 Gigabit Network Connection <00016210><11:32:30.761> Serial: EthernetTest SerialOutput Start cat /sys/class/net/eth0/operstate <00008030><11:32:30.761> Serial: SerialOutput End <00016200><11:32:30.761> Serial: EthernetTest SerialInput Start cat /sys/class/net/eth0/operstate up / # <00008040><11:32:30.761> Serial: SerialInput End <00016180><11:32:30.762> Info: Ethernet Link is up <00016210><11:32:30.762> Serial: EthernetTest SerialOutput Start cat /sys/class/net/eth0/carrier <00008030><11:32:30.762> Serial: SerialOutput End <00016200><11:32:30.762> Serial: EthernetTest SerialInput Start cat /sys/class/net/eth0/carrier 1 / # <00008040><11:32:30.762> Serial: SerialInput End <00016160><11:32:30.762> Info: Ethernet carrier is connected <00016210><11:32:30.762> Serial: EthernetTest SerialOutput Start cat /sys/class/net/eth0/duplex <00008030><11:32:30.763> Serial: SerialOutput End <00016200><11:32:30.763> Serial: EthernetTest SerialInput Start cat /sys/class/net/eth0/duplex full / # <00008040><11:32:30.763> Serial: SerialInput End <00016140><11:32:30.763> Info: Ethernet full duplex <00016210><11:32:30.763> Serial: EthernetTest SerialOutput Start cat /sys/class/net/eth0/speed <00008030><11:32:30.763> Serial: SerialOutput End <00016200><11:32:30.763> Serial: EthernetTest SerialInput Start cat /sys/class/net/eth0/speed 1000 / # <00008040><11:32:30.764> Serial: SerialInput End <00016118><11:32:30.764> Info: Ethernet running at 1000Mbps <00016020><11:32:30.764> Info: EthernetTest Passed <00007040><11:32:30.764> Info: Flashing Toradex-Easy-Installer <00024240><11:32:30.764> Serial: Info SerialOutput Start mkdir -p /run/src <00008030><11:32:30.765> Serial: SerialOutput End <00024230><11:32:30.765> Serial: Info SerialInput Start mkdir -p /run/src / # <00008040><11:32:30.765> Serial: SerialInput End <00024240><11:32:30.765> Serial: Info SerialOutput Start mount /dev/mmcblk2p1 /run/src <00008030><11:32:30.765> Serial: SerialOutput End <00024230><11:32:30.765> Serial: Info SerialInput Start mount /dev/mmcblk2p1 /run/src / # <00008040><11:32:30.765> Serial: SerialInput End <00024240><11:32:30.765> Serial: Info SerialOutput Start echo "8192,65536,0c" | sfdisk /dev/mmcblk0 <00008030><11:32:30.765> Serial: SerialOutput End <00024230><11:32:30.765> Serial: Info SerialInput Start echo "8192,65536,0c" | sfdisk /dev/mmcblk0 Checking that no-one is using this disk right now ... OK [1mDisk /dev/mmcblk0: 3.6 GiB, 3850371072 bytes, 7520256 sectors [0mUnits: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x04bd40af Old situation: [1mDevice[0m [1mBoot[0m [1mStart[0m [1m End[0m [1m Sectors[0m [1m Size[0m [1mId[0m [1mType[0m /dev/mmcblk0p1 8192 40959 32768 16M c W95 FAT32 (LBA) /dev/mmcblk0p2 40960 15216639 15175680 7.2G 83 Linux >>> Created a new DOS disklabel with disk identifier 0x23a6a1ce. Created a new partition 1 of type 'W95 FAT32 (LBA)' and of size 32 MiB. /dev/mmcblk0p2: New situation: [1mDevice[0m [1mBoot[0m [1mStart[0m [1m End[0m [1mSectors[0m [1mSize[0m [1mId[0m [1mType[0m /dev/mmcblk0p1 8192 73727 65536 32M c W95 FAT32 (LBA) The partition table has been altered. Calling ioctl() to re-read partition table. Syncing disks. / # <00008040><11:32:30.766> Serial: SerialInput End <00024240><11:32:30.766> Serial: Info SerialOutput Start mkfs.fat /dev/mmcblk0p1 <00008030><11:32:30.766> Serial: SerialOutput End <00024230><11:32:30.766> Serial: Info SerialInput Start mkfs.fat /dev/mmcblk0p1 mkfs.fat 4.0 (2016-05-06) / # <00008040><11:32:30.766> Serial: SerialInput End <00024240><11:32:30.766> Serial: Info SerialOutput Start mkdir -p /run/dst <00008030><11:32:30.766> Serial: SerialOutput End <00024230><11:32:30.766> Serial: Info SerialInput Start mkdir -p /run/dst / # <00008040><11:32:30.766> Serial: SerialInput End <00024240><11:32:30.767> Serial: Info SerialOutput Start mount /dev/mmcblk0p1 /run/dst <00008030><11:32:30.767> Serial: SerialOutput End <00024230><11:32:30.767> Serial: Info SerialInput Start mount /dev/mmcblk0p1 /run/dst / # <00008040><11:32:30.767> Serial: SerialInput End <00024240><11:32:30.767> Serial: Info SerialOutput Start cp /run/src/ApalisT30/FactoryImage/boot.scr /run/dst <00008030><11:32:30.767> Serial: SerialOutput End <00024230><11:32:30.768> Serial: Info SerialInput Start cp /run/src/ApalisT30/FactoryImage/boot.scr /run/dst / # <00008040><11:32:30.768> Serial: SerialInput End <00024240><11:32:30.768> Serial: Info SerialOutput Start cp /run/src/ApalisT30/FactoryImage/tezi.itb /run/dst <00008030><11:32:30.768> Serial: SerialOutput End <00024230><11:32:30.768> Serial: Info SerialInput Start cp /run/src/ApalisT30/FactoryImage/tezi.itb /run/dst / # <00008040><11:32:30.768> Serial: SerialInput End <00024240><11:32:30.768> Serial: Info SerialOutput Start umount /run/dst <00008030><11:32:30.768> Serial: SerialOutput End <00024230><11:32:30.768> Serial: Info SerialInput Start umount /run/dst / # <00008040><11:32:30.768> Serial: SerialInput End <00024240><11:32:30.768> Serial: Info SerialOutput Start umount /run/src <00008030><11:32:30.768> Serial: SerialOutput End <00024230><11:32:30.769> Serial: Info SerialInput Start umount /run/src / # <00008040><11:32:30.769> Serial: SerialInput End <00024240><11:32:30.769> Serial: Info SerialOutput Start sync <00008030><11:32:30.769> Serial: SerialOutput End <00024230><11:32:30.769> Serial: Info SerialInput Start sync / # <00008040><11:32:30.769> Serial: SerialInput End <00007060><11:32:30.769> Info: Flashing Toradex-Easy-Installer Passed <00024240><11:32:30.769> Serial: Info SerialOutput Start cat /sys/class/hwmon/hwmon?/temp1_input <00008030><11:32:30.769> Serial: SerialOutput End <00024230><11:32:30.769> Serial: Info SerialInput Start cat /sys/class/hwmon/hwmon?/temp1_input 32750 / # <00008040><11:32:30.769> Serial: SerialInput End <00026100><11:32:30.770> Info: Current temperature 32.75 C <00005120><11:32:30.770> Serial: BootTest SerialInput Start U-Boot SPL 2016.11-1.7.0+gf4db39ecb6 (Jul 31 2018 - 11:22:24) Trying to boot from RAM U-Boot 2016.11-1.7.0+gf4db39ecb6 (Jul 31 2018 - 11:22:24 +0000) SoC: tegra30 Reset cause: POR DRAM: 1 GiB MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1, Tegra SD/MMC: 2 Using default environment In: serial Out: vidconsole Err: vidconsole Model: Toradex Apalis T30 1GB IT V1.1B, Serial# Net: No ethernet found. Hit any key to stop autoboot: 1 0 MMC: no card present MMC: no card present switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:1... Found U-Boot script /boot.scr reading /boot.scr 506 bytes read in 9 ms (54.7 KiB/s) ## Executing script at 90000000 reading /tezi.itb 21547832 bytes read in 550 ms (37.4 MiB/s) ## Loading kernel from FIT Image at 82100000 ... Using 'config@1' configuration Trying 'kernel@1' kernel subimage Description: Linux Kernel 4.14 Type: Kernel Image (no loading done) Compression: uncompressed Data Start: 0x82fe7ac8 Data Size: 5917952 Bytes = 5.6 MiB Hash algo: md5 Hash value: 2adf9f24213987fbdf224421bba31a47 Verifying Hash Integrity ... md5+ OK ## Loading ramdisk from FIT Image at 82100000 ... Using 'config@1' configuration Trying 'ramdisk@1' ramdisk subimage Description: SquashFS RAMdisk Type: RAMDisk Image Compression: uncompressed Data Start: 0x821000dc Data Size: 15597568 Bytes = 14.9 MiB Architecture: ARM OS: Linux Load Address: unavailable Entry Point: unavailable Hash algo: md5 Hash value: 5344a6304a7cdd9e434d8dd3cc2f63df Verifying Hash Integrity ... md5+ OK ## Loading fdt from FIT Image at 82100000 ... Using 'config@1' configuration Trying 'fdt@1' fdt subimage Description: Apalis T30 Device Tree Type: Flat Device Tree Compression: uncompressed Data Start: 0x82fe01a4 Data Size: 30830 Bytes = 30.1 KiB Architecture: ARM Hash algo: md5 Hash value: 3a81f928d1b75efef266917bdf6c7283 Verifying Hash Integrity ... md5+ OK Booting using the fdt blob at 0x82fe01a4 XIP Kernel Image (no loading done) ... OK CACHE: Misaligned operation at range [82fe7ac8, 8358c7c8] Loading Device Tree to 8fff5000, end 8ffff86d ... OK Starting kernel ... [ 0.000000] L2C-310: enabling full line of zeros but not enabled in Cortex-A9 [ 0.103643] usbo1_vbus: Failed to request enable GPIO157: -517 [ 0.103666] reg-fixed-voltage regulators:regulator@2: Failed to register regulator: -517 [ 0.103784] usbh_vbus: Failed to request enable GPIO233: -517 [ 0.103802] reg-fixed-voltage regulators:regulator@3: Failed to register regulator: -517 [ 0.740275] tegra-pcie 3000.pcie: link 0 down, retrying [ 1.146171] tegra-pcie 3000.pcie: link 0 down, retrying [ 1.553081] tegra-pcie 3000.pcie: link 0 down, retrying [ 1.741157] tegra-dc 54200000.dc: failed to probe RGB output: -517 [ 1.748280] tegra-hdmi 54280000.hdmi: failed to get PLL regulator [ 3.138778] tegra-udc 7d000000.usb: failed to get PHY: -517 [ 4.165614] tegra-i2c 7000c000.i2c: i2c transfer timed out Running /etc/rc.local... Apalis-T30_ToradexEasyInstaller_1.7-20180731 [1mWelcome to Toradex Easy Installer[0m This is a Linux based installer for Toradex modules. Currently the installer does not have a serial console interface. You can use the Toradex Easy Installer through any of the available display interfaces using USB mouse/keyboard or via network using VNC. Use: # ip addr show eth0 to display the Ethernet IP address or use USB RNDIS at IP 192.168.11.1. / # <00008040><11:32:30.770> Serial: SerialInput End <00009080><11:32:30.770> Info: i_bat_idle = 17e-6 [A] <00009100><11:32:30.770> Info: i_main_idle = 1225e-3 [A] <00007085><11:32:30.770> Info: Flashing OS From Tezi <00005120><11:32:30.770> Serial: BootTest SerialInput Start [ 90.465240] reboot: Restarting system <00008040><11:32:30.770> Serial: SerialInput End <00007087><11:32:30.770> Info: Flashing OS From Tezi Passed <00005100><11:32:30.770> Info: BootTest Start Booting Factory OS <00005120><11:32:30.770> Serial: BootTest SerialInput Start U-Boot SPL 2016.11-2.7.4+g1b121c6 (Oct 05 2017 - 03:58:08) Trying to boot from RAM U-Boot 2016.11-2.7.4+g1b121c6 (Oct 05 2017 - 03:58:08 +0000) TEGRA30 DRAM: 1 GiB MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1, Tegra SD/MMC: 2 In: serial Out: vidconsole Err: vidconsole Model: Toradex Apalis T30 1GB IT V1.1B, Serial# Net: No ethernet found. Hit any key to stop autoboot: 1 0 Booting from internal eMMC chip... reading tegra30-apalis-eval.dtb ** Unable to read file tegra30-apalis-eval.dtb ** reading uImage 4243840 bytes read in 149 ms (27.2 MiB/s) ## Booting kernel from Legacy Image at 81000000 ... Image Name: Linux-3.1.10-2.7.4+g7753763 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 4243776 Bytes = 4 MiB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK Loading Kernel Image ... OK Starting kernel ... [ 0.000000] Linux version 3.1.10-2.7.4+g7753763 (yocto@cef42bef2ef3) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP PREEMPT Thu Oct 5 03:07:49 UTC 2017 [ 0.000000] CPU: ARMv7 Processor [412fc099] revision 9 (ARMv7), cr=10c5387d [ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Toradex Apalis T30 [ 0.000000] Found fbmem: 00c00000@bf400000 [ 0.000000] Tegra reserved memory: [ 0.000000] LP0: 00000000 - 00000000 [ 0.000000] Bootloader framebuffer: bf400000 - bfffffff [ 0.000000] Bootloader framebuffer2: 00000000 - 00000000 [ 0.000000] Framebuffer: be700000 - beffffff [ 0.000000] 2nd Framebuffer: bf000000 - bfffffff [ 0.000000] Carveout: 00000000 - 00000000 [ 0.000000] Vpr: 00000000 - 00000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] fuse_speedo_calib: ATE prog ver 4.0 [ 0.000000] Tegra3: CPU Speedo ID 2, Soc Speedo ID 2 [ 0.000000] Tegra Revision: A03 SKU: 0xb0 CPU Process: 1 Core Process: 0 [ 0.000000] tegra: PLLP fixed rate: 408000000 [ 0.000000] Lowering sbus maximum rate from 378000000 to 334000000 [ 0.000000] Lowering vde maximum rate from 600000000 to 520000000 [ 0.000000] Lowering mpe maximum rate from 600000000 to 520000000 [ 0.000000] Lowering 2d maximum rate from 600000000 to 520000000 [ 0.000000] Lowering epp maximum rate from 600000000 to 520000000 [ 0.000000] Lowering 3d maximum rate from 600000000 to 520000000 [ 0.000000] Lowering 3d2 maximum rate from 600000000 to 520000000 [ 0.000000] Lowering se maximum rate from 625000000 to 520000000 [ 0.000000] Lowering host1x maximum rate from 300000000 to 267000000 [ 0.000000] Lowering cbus maximum rate from 700000000 to 520000000 [ 0.000000] Lowering pll_c maximum rate from 1400000000 to 1066000000 [ 0.000000] Lowering ndflash maximum rate from 240000000 to 200000000 [ 0.000000] Lowering sbc1 maximum rate from 160000000 to 100000000 [ 0.000000] Lowering sbc2 maximum rate from 160000000 to 100000000 [ 0.000000] Lowering sbc3 maximum rate from 160000000 to 100000000 [ 0.000000] Lowering sbc4 maximum rate from 160000000 to 100000000 [ 0.000000] Lowering sbc5 maximum rate from 160000000 to 100000000 [ 0.000000] Lowering sbc6 maximum rate from 160000000 to 100000000 [ 0.000000] Lowering dsia maximum rate from 500000000 to 432500000 [ 0.000000] Lowering dsib maximum rate from 500000000 to 432500000 [ 0.000000] Lowering cpu_g maximum rate from 1700000000 to 1400000000 [ 0.000000] tegra3_dvfs: cold offset 50000000 is too high for regular dvfs limit 1000000 [ 0.000000] tegra3_dvfs: cold offset 50000000 is too high for regular dvfs limit 1000000 [ 0.000000] tegra3_dvfs: cold offset 50000000 is too high for regular dvfs limit 1000000 [ 0.000000] tegra3_dvfs: cold offset 50000000 is too high for regular dvfs limit 1000000 [ 0.000000] tegra dvfs: VDD_CPU nominal 1150mV, scaling enabled [ 0.000000] tegra dvfs: VDD_CORE nominal 1300mV, scaling enabled [ 0.000000] L310 cache controller enabled [ 0.000000] l2x0: 8 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x7e080001, Cache size: 1048576 B [ 0.000000] PERCPU: Embedded 8 pages/cpu @c12f6000 s10336 r8192 d14240 u32768 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 253211 [ 0.000000] Kernel command line: core_edp_mv=1300 usb_high_speed=1 ip=off root=/dev/mmcblk0p2 ro rootfstype=ext3 rootwait igb_mac=00:14:2d:61:d1:7e consoleblank=0 no_console_suspend=1 console=tty1 console=ttyS0,115200n8 debug_uartport=lsport,0 vmalloc=128M mem=1012M@2048M fbmem=12M@3060M video=tegrafb0:640x480-16@60 fbcon=map:1 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 998MB = 998MB total [ 0.000000] Memory: 1001600k/1001600k available, 34688k reserved, 235520K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] DMA : 0xff000000 - 0xffe00000 ( 14 MB) [ 0.000000] vmalloc : 0xf0800000 - 0xf8000000 ( 120 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0818df8 (8260 kB) [ 0.000000] .init : 0xc0819000 - 0xc086d860 ( 339 kB) [ 0.000000] .data : 0xc086e000 - 0xc08fb924 ( 567 kB) [ 0.000000] .bss : 0xc08fb948 - 0xc09745f8 ( 484 kB) [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] NR_IRQS:800 [ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms [ 0.000000] Console: colour dummy device 80x30 [ 0.000000] console [tty1] enabled [ 0.003089] Calibrating delay loop... 1196.85 BogoMIPS (lpj=5984256) [ 0.090127] pid_max: default: 32768 minimum: 301 [ 0.090489] Mount-cache hash table entries: 512 [ 0.091740] Initializing cgroup subsys blkio [ 0.091882] CPU: Testing write buffer coherency: ok [ 0.091982] ftrace: allocating 23283 entries in 69 pages [ 0.123811] Brought up 4 CPUs [ 0.123857] SMP: Total of 4 processors activated (4787.40 BogoMIPS). [ 0.125020] devtmpfs: initialized [ 0.130817] print_constraints: dummy: [ 0.131222] NET: Registered protocol family 16 [ 0.132523] host1x bus init [ 0.132757] Serial: 8250/16550 driver, 9 ports, IRQ sharing disabled [ 0.406284] apalis_t30_edp_init: CPU regulator 6000 mA [ 0.406377] Selecting UARTA as the debug console [ 0.406420] The debug console clock name is uarta_dbg [ 0.406786] serial8250.0: ttyS0 at MMIO 0x70006000 (irq = 68) is a Tegra [ 0.943112] console [ttyS0] enabled [ 0.972803] Registering the device TPS62360 [ 0.977571] Clear bootloader IO dpd settings [ 1.063142] tegra: invalid EMC DFS table: entry for max rate 800000 kHz is not found [ 1.073844] tegra_iovmm_register: added iovmm-smmu [ 1.090422] bio: create slab <bio-0> at 0 [ 1.095256] i2c-core: driver [tps6591x] using legacy suspend method [ 1.101568] i2c-core: driver [tps6591x] using legacy resume method [ 1.108246] SCSI subsystem initialized [ 1.115020] usbcore: registered new interface driver usbfs [ 1.120674] usbcore: registered new interface driver hub [ 1.126133] usbcore: registered new device driver usb [ 1.131350] tegra-otg tegra-otg: otg transceiver registered [ 1.139222] stmpe 4-0041: stmpe811 detected, chip id: 0x811 [ 1.147215] tps6591x 4-002d: VERNUM is 02 [ 1.156415] print_constraints: tps6591x_VDD_1: 1350 mV normal standby [ 1.166899] print_constraints: tps6591x_VDD_2: 1050 mV normal standby [ 1.176793] print_constraints: tps6591x_VDDCTRL: 800 <--> 1300 mV at 1012 mV normal standby [ 1.186395] print_constraints: tps6591x_VIO: 1800 mV normal standby [ 1.194978] print_constraints: tps6591x_LDO_1: 1800 mV normal standby [ 1.201481] set_supply: tps6591x_LDO_1: supplied by tps6591x_VIO [ 1.209700] print_constraints: tps6591x_LDO_2: 1200 mV normal standby [ 1.216202] set_supply: tps6591x_LDO_2: supplied by tps6591x_VIO [ 1.223133] print_constraints: tps6591x_LDO_3: 1200 mV normal standby [ 1.230850] print_constraints: tps6591x_LDO_4: 1000 <--> 1400 mV at 1200 mV normal standby [ 1.239971] print_constraints: tps6591x_LDO_5: 2800 mV normal standby [ 1.247309] print_constraints: tps6591x_LDO_6: 1000 <--> 1100 mV at 1100 mV normal standby [ 1.255643] set_supply: tps6591x_LDO_6: supplied by tps6591x_VIO [ 1.264281] print_constraints: tps6591x_LDO_7: 1200 mV normal standby [ 1.270786] set_supply: tps6591x_LDO_7: supplied by tps6591x_VIO [ 1.278937] print_constraints: tps6591x_LDO_8: 1000 mV normal standby [ 1.285443] set_supply: tps6591x_LDO_8: supplied by tps6591x_VIO [ 1.297674] print_constraints: tps62360: 900 <--> 1400 mV at 1200 mV normal standby [ 1.305649] pps_core: LinuxPPS API ver. 1 registered [ 1.310653] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.319849] PTP clock support registered [ 1.324148] Advanced Linux Sound Architecture Driver Version 1.0.24. [ 1.331196] Bluetooth: Core ver 2.16 [ 1.334847] NET: Registered protocol family 31 [ 1.339309] Bluetooth: HCI device and connection manager initialized [ 1.345704] Bluetooth: HCI socket layer initialized [ 1.350612] Bluetooth: L2CAP socket layer initialized [ 1.355723] Bluetooth: SCO socket layer initialized [ 1.362007] print_constraints: fixed_reg_en_hdmi: 1800 mV normal [ 1.368434] print_constraints: fixed_reg_v3_3: 3300 mV normal [ 1.374761] print_constraints: gpio_reg_sdmmc3_vdd_sel: 1800 <--> 3300 mV at 1800 mV normal standby [ 1.383877] set_supply: gpio_reg_sdmmc3_vdd_sel: supplied by fixed_reg_v3_3 [ 1.391744] tegra: failed to map regulator to power detect cell pwrdet_sdmmc3(-19) [ 1.399435] tegra: failed regulators mapping - io power detection is left always on [ 1.407142] Switching to clocksource timer_us [ 1.424464] nvmap_page_pool_init: nvmap uc page pool size=31300 pages [ 1.464527] nvmap_page_pool_init: nvmap pool = uc, highmem=31300, pool_size=31300,totalram=250400, freeram=218287, totalhigh=58880, freehigh=27515 [ 1.618686] nvmap_page_pool_init: nvmap wc page pool size=31300 pages [ 1.665787] nvmap_page_pool_init: nvmap pool = wc, highmem=27456, pool_size=31300,totalram=250400, freeram=186928, totalhigh=58880, freehigh=0 [ 1.821473] nvmap_page_pool_init: nvmap iwb page pool size=31300 pages [ 1.917509] nvmap_page_pool_init: nvmap pool = iwb, highmem=0, pool_size=31300,totalram=250400, freeram=155556, totalhigh=58880, freehigh=0 [ 2.091610] tegra-nvmap tegra-nvmap: created carveout iram (255KiB) [ 2.112721] NET: Registered protocol family 2 [ 2.117360] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 2.125157] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 2.135129] TCP bind hash table entries: 65536 (order: 7, 786432 bytes) [ 2.143591] TCP: Hash tables configured (established 131072 bind 65536) [ 2.150225] TCP reno registered [ 2.153406] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 2.159381] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 2.166189] NET: Registered protocol family 1 [ 2.171026] RPC: Registered named UNIX socket transport module. [ 2.177010] RPC: Registered udp transport module. [ 2.181752] RPC: Registered tcp transport module. [ 2.186474] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 2.195759] host1x host1x: initialized [ 2.199644] PMU: registered new PMU device of type 0 [ 2.205183] Tegra auto-hotplug initialized: disabled [ 2.210178] cpu-tegra: init EDP limit: 1250 MHz [ 2.215542] PCIE.C: tegra_pcie_enable_regulators : regulator hvdd_pex [ 2.222080] PCIE.C: tegra_pcie_enable_regulators : regulator pexio [ 2.228294] tegra_pcie_enable_regulators: unable to get pexio regulator [ 2.234950] PCIE.C: tegra_pcie_enable_regulators : regulator avdd_plle [ 2.443553] PCIE: port 0: link down, retrying [ 2.648355] PCIE: port 0: link down, retrying [ 2.853038] PCIE: port 0: link down, retrying [ 2.857396] PCIE: port 0: link down, ignoring [ 2.861993] PCI: bus0: Fast back to back transfers disabled [ 2.881617] PCI: bus1: Fast back to back transfers disabled [ 2.887617] PCI: bus2: Fast back to back transfers disabled [ 2.911607] PCI: bus3: Fast back to back transfers disabled [ 2.917452] pci 0000:02:00.0: BAR 8: assigned [mem 0x10000000-0x100fffff] [ 2.924260] pci 0000:02:00.0: BAR 7: assigned [io 0x10000000-0x10000fff] [ 2.931051] pci 0000:03:00.0: BAR 0: assigned [mem 0x10000000-0x1001ffff] [ 2.937857] pci 0000:03:00.0: BAR 0: set to [mem 0x10000000-0x1001ffff] (PCI address [0x10000000-0x1001ffff]) [ 2.947783] pci 0000:03:00.0: BAR 3: assigned [mem 0x10020000-0x10023fff] [ 2.954593] pci 0000:03:00.0: BAR 3: set to [mem 0x10020000-0x10023fff] (PCI address [0x10020000-0x10023fff]) [ 2.964521] pci 0000:03:00.0: BAR 2: assigned [io 0x10000000-0x1000001f] [ 2.971314] pci 0000:03:00.0: BAR 2: set to [io 0x10000000-0x1000001f] (PCI address [0x10000000-0x1000001f]) [ 2.981238] pci 0000:02:00.0: PCI bridge to [bus 03-03] [ 2.986477] pci 0000:02:00.0: bridge window [io 0x10000000-0x10000fff] [ 2.993276] pci 0000:02:00.0: bridge window [mem 0x10000000-0x100fffff] [ 3.000082] pci 0000:00:00.0: BAR 8: assigned [mem 0x10100000-0x101fffff] [ 3.006885] pci 0000:01:00.0: BAR 0: assigned [mem 0x10100000-0x10101fff 64bit] [ 3.014216] pci 0000:01:00.0: BAR 0: set to [mem 0x10100000-0x10101fff 64bit] (PCI address [0x10100000-0x10101fff]) [ 3.024662] pci 0000:00:00.0: PCI bridge to [bus 01-01] [ 3.029889] pci 0000:00:00.0: bridge window [mem 0x10100000-0x101fffff] [ 3.052398] highmem bounce pool size: 64 pages [ 3.057452] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 3.064517] fuse init (API version 7.17) [ 3.068712] msgmni has been set to 1496 [ 3.073493] io scheduler noop registered (default) [ 3.080240] mpe mpe: initialized [ 3.085757] gr3d gr3d: initialized [ 3.091340] gr2d gr2d: initialized [ 3.095319] isp isp: initialized [ 3.099110] tegradc tegradc.0: probed [ 3.102886] tegradc tegradc.0: use cmd options for tegrafb0: 640x480-16@60 [ 3.109786] tegradc tegradc.0: switching framebuffer to 640x480 [ 3.115719] tegradc tegradc.0: Calculated sync href=0 vref=1 [ 3.121382] tegradc tegradc.0: using mode 640x480 pclk=25175000 href=0 vref=1 [ 3.133032] tegradc tegradc.0: probed [ 3.150007] tegradc tegradc.1: probed [ 3.153913] tegradc tegradc.1: use default mode for tegrafb1: 640x480-16@60 [ 3.160882] tegradc tegradc.1: Unusuall display aspect ratio. You may encounter problems with base resolution [ 3.172201] tegradc tegradc.1: Unusuall display aspect ratio. You may encounter problems with base resolution [ 3.183521] tegradc tegradc.1: Unusuall display aspect ratio. You may encounter problems with base resolution [ 3.194839] tegradc tegradc.1: switching framebuffer to 640x480 [ 3.200762] tegradc tegradc.1: using mode 640x480 pclk=23750000 href=1 vref=1 [ 3.212992] tegradc tegradc.1: hdmi: can't set audio to 44100 at 23750000 pix_clock [ 3.220779] tegradc tegradc.1: switching framebuffer to 640x480 [ 3.220789] tegradc tegradc.1: using mode 640x480 pclk=23750000 href=1 vref=1 [ 3.276311] Console: switching to colour frame buffer device 80x30 [ 3.316693] tegradc tegradc.1: probed [ 3.363012] tegra_uart.3: ttyHS3 at MMIO 0x70006300 (irq = 122) is a TEGRA_UART [ 3.481601] Registered UART port ttyHS3 [ 3.487322] tegra_uart.1: ttyHS1 at MMIO 0x70006040 (irq = 69) is a TEGRA_UART [ 3.641594] Registered UART port ttyHS1 [ 3.647361] tegra_uart.2: ttyHS2 at MMIO 0x70006200 (irq = 78) is a TEGRA_UART [ 3.801607] Registered UART port ttyHS2 [ 3.808019] Initialized tegra uart driver [ 3.819739] loop: module loaded [ 3.825986] create_regulator: tps6591x_LDO_6: Failed to create debugfs directory [ 3.839003] tegra-sata tegra-sata.0: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl TEGRA-SATA mode [ 3.853145] tegra-sata tegra-sata.0: flags: 64bit ncq sntf pm led pio slum part apst [ 3.867021] scsi0 : tegra-sata [ 3.872987] ata1: SATA max UDMA/133 irq 55 [ 3.880392] Intel(R) Gigabit Ethernet Network Driver - version 5.2.17 [ 3.889372] Copyright (c) 2007-2015 Intel Corporation. [ 3.993908] igb 0000:03:00.0: added PHC on eth0 [ 4.000921] igb 0000:03:00.0: Intel(R) Gigabit Ethernet Network Connection [ 4.010296] igb 0000:03:00.0: eth0: (PCIe:2.5GT/s:Width x1) [ 4.015968] igb 0000:03:00.0: eth0: MAC: 00:14:2d:61:d1:7e [ 4.026364] igb 0000:03:00.0: eth0: PBA No: Unknown [ 4.033575] igb 0000:03:00.0: LRO is disabled [ 4.040196] igb 0000:03:00.0: Using MSI-X interrupts. 1 rx queue(s), 1 tx queue(s) [ 4.052319] CAN device driver interface [ 4.070403] mcp251x spi1.0: probed [ 4.087774] mcp251x spi3.1: probed [ 4.093372] PPP generic driver version 2.4.2 [ 4.100011] PPP Deflate Compression module registered [ 4.107266] PPP BSD Compression module registered [ 4.115052] PPP MPPE Compression module registered [ 4.122062] NET: Registered protocol family 24 [ 4.129856] tun: Universal TUN/TAP device driver, 1.6 [ 4.137480] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com> [ 4.146594] usbcore: registered new interface driver asix [ 4.154597] usbcore: registered new interface driver cdc_ether [ 4.162939] usbcore: registered new interface driver cdc_subset [ 4.171201] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 4.180215] tegra USB phy - inst[1] platform info: [ 4.187406] port_otg: no [ 4.192211] has_hostpc: yes [ 4.197192] phy_interface: USB_PHY_INTF_UTMI [ 4.203709] op_mode: TEGRA_USB_OPMODE_HOST [ 4.209972] vbus_gpio: 233 [ 4.214844] vbus_gpio_inverted: 0 [ 4.214857] vbus_reg: NULL [ 4.214867] hot_plug: enabled [ 4.214877] remote_wakeup: enabled [ 4.219870] tegra-ehci tegra-ehci.1: Tegra EHCI Host Controller [ 4.220084] tegra-ehci tegra-ehci.1: new USB bus registered, assigned bus number 1 [ 4.221668] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300) [ 4.241650] tegra-ehci tegra-ehci.1: irq 53, io mem 0x7d004000 [ 4.261638] tegra-ehci tegra-ehci.1: USB 2.0 started, EHCI 1.00 [ 4.261770] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 4.261791] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.261809] usb usb1: Product: Tegra EHCI Host Controller [ 4.261825] usb usb1: Manufacturer: Linux 3.1.10-2.7.4+g7753763 ehci_hcd [ 4.261841] usb usb1: SerialNumber: tegra-ehci.1 [ 4.262606] hub 1-0:1.0: USB hub found [ 4.262641] hub 1-0:1.0: 1 port detected [ 4.263177] tegra USB phy - inst[2] platform info: [ 4.263191] port_otg: no [ 4.263200] has_hostpc: yes [ 4.263209] phy_interface: USB_PHY_INTF_UTMI [ 4.263220] op_mode: TEGRA_USB_OPMODE_HOST [ 4.263230] vbus_gpio: -1 [ 4.263239] vbus_gpio_inverted: 0 [ 4.263249] vbus_reg: NULL [ 4.263257] hot_plug: enabled [ 4.263266] remote_wakeup: enabled [ 4.264622] tegra-ehci tegra-ehci.2: Tegra EHCI Host Controller [ 4.264698] tegra-ehci tegra-ehci.2: new USB bus registered, assigned bus number 2 [ 4.271687] ata1.00: ATA-8: SSD08G, 06051016, max UDMA/133 [ 4.271708] ata1.00: 15650208 sectors, multi 0: LBA48 [ 4.291770] tegra-ehci tegra-ehci.2: irq 129, io mem 0x7d008000 [ 4.311620] tegra-ehci tegra-ehci.2: USB 2.0 started, EHCI 1.00 [ 4.311752] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 4.311773] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.311791] usb usb2: Product: Tegra EHCI Host Controller [ 4.311807] usb usb2: Manufacturer: Linux 3.1.10-2.7.4+g7753763 ehci_hcd [ 4.311822] usb usb2: SerialNumber: tegra-ehci.2 [ 4.312633] hub 2-0:1.0: USB hub found [ 4.312668] hub 2-0:1.0: 1 port detected [ 4.313412] Initializing USB Mass Storage driver... [ 4.313591] usbcore: registered new interface driver usb-storage [ 4.313604] USB Mass Storage support registered. [ 4.313763] usbcore: registered new interface driver libusual [ 4.313987] usbcore: registered new interface driver usbserial [ 4.314059] USB Serial support registered for generic [ 4.314166] usbcore: registered new interface driver usbserial_generic [ 4.314181] usbserial: USB Serial Driver core [ 4.314260] USB Serial support registered for pl2303 [ 4.314377] usbcore: registered new interface driver pl2303 [ 4.314391] pl2303: Prolific PL2303 USB to serial adaptor driver [ 4.314408] Nvidia Tegra High-Speed USB SOC Device Controller driver (Apr 30, 2012) [ 4.314532] tegra USB phy - inst[0] platform info: [ 4.314545] port_otg: yes [ 4.314554] has_hostpc: yes [ 4.314563] phy_interface: USB_PHY_INTF_UTMI [ 4.314574] op_mode: TEGRA_USB_OPMODE_DEVICE [ 4.314584] vbus_pmu_irq: 0 [ 4.314593] vbus_gpio: -1 [ 4.314602] charging: disabled [ 4.314611] remote_wakeup: disabled [ 4.317271] tegra-udc tegra-udc.0: usb_bat_chg regulator not registered: USB charging will not be enabled [ 4.667627] android_usb gadget: Mass Storage Function, version: 2009/09/11 [ 4.667723] ata1.00: configured for UDMA/133 [ 4.682305] scsi 0:0:0:0: Direct-Access ATA SSD08G 0605 PQ: 0 ANSI: 5 [ 4.683161] sd 0:0:0:0: [sda] 15650208 512-byte logical blocks: (8.01 GB/7.46 GiB) [ 4.683446] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 4.683853] sd 0:0:0:0: [sda] Write Protect is off [ 4.684082] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 4.686259] sda: [ 4.744350] android_usb gadget: Number of LUNs=1 [ 4.745594] sd 0:0:0:0: [sda] Attached SCSI disk [ 4.758793] lun0: LUN: removable file: (no medium) [ 4.766830] android_usb gadget: android_usb ready [ 4.774141] tegra-udc: bind to driver android_usb [ 4.789263] input: stmpe-ts as /devices/virtual/input/input0 [ 5.791711] ------------[ cut here ]------------ [ 5.799061] WARNING: at /workdir/build/tmp-glibc/work-shared/apalis-t30/kernel-source/drivers/i2c/busses/i2c-tegra.c:728 tegra_i2c_xfer+0x3a0/0x4c8() [ 5.818179] Modules linked in: [ 5.824261] [<c00147f0>] (unwind_backtrace+0x0/0xe8) from [<c0594898>] (dump_stack+0x20/0x24) [ 5.838927] [<c0594898>] (dump_stack+0x20/0x24) from [<c005a6a8>] (warn_slowpath_common+0x5c/0x74) [ 5.854066] [<c005a6a8>] (warn_slowpath_common+0x5c/0x74) from [<c005a77c>] (warn_slowpath_null+0x2c/0x34) [ 5.870076] [<c005a77c>] (warn_slowpath_null+0x2c/0x34) from [<c03a6588>] (tegra_i2c_xfer+0x3a0/0x4c8) [ 5.885820] [<c03a6588>] (tegra_i2c_xfer+0x3a0/0x4c8) from [<c03a2de4>] (i2c_transfer+0xb8/0xe8) [ 5.901064] [<c03a2de4>] (i2c_transfer+0xb8/0xe8) from [<c03a3348>] (i2c_smbus_xfer+0x478/0x4d0) [ 5.916581] [<c03a3348>] (i2c_smbus_xfer+0x478/0x4d0) from [<c03a39cc>] (i2c_smbus_read_i2c_block_data+0x50/0x78) [ 5.933800] [<c03a39cc>] (i2c_smbus_read_i2c_block_data+0x50/0x78) from [<c058c6f4>] (ds1307_probe+0x208/0x598) [ 5.951163] [<c058c6f4>] (ds1307_probe+0x208/0x598) from [<c03a1f78>] (i2c_device_probe+0x90/0xd4) [ 5.967658] [<c03a1f78>] (i2c_device_probe+0x90/0xd4) from [<c02d2ff8>] (driver_probe_device+0x120/0x198) [ 5.985026] [<c02d2ff8>] (driver_probe_device+0x120/0x198) from [<c02d3120>] (__driver_attach+0x5c/0x9c) [ 6.002456] [<c02d3120>] (__driver_attach+0x5c/0x9c) from [<c02d1bd0>] (bus_for_each_dev+0x98/0xa0) [ 6.019470] [<c02d1bd0>] (bus_for_each_dev+0x98/0xa0) from [<c02d2be4>] (driver_attach+0x28/0x30) [ 6.036355] [<c02d2be4>] (driver_attach+0x28/0x30) from [<c02d287c>] (bus_add_driver+0x168/0x234) [ 6.053253] [<c02d287c>] (bus_add_driver+0x168/0x234) from [<c02d3814>] (driver_register+0xb4/0x124) [ 6.070463] [<c02d3814>] (driver_register+0xb4/0x124) from [<c03a3fe0>] (i2c_register_driver+0x54/0xbc) [ 6.087900] [<c03a3fe0>] (i2c_register_driver+0x54/0xbc) from [<c0837514>] (ds1307_init+0x18/0x20) [ 6.105393] [<c0837514>] (ds1307_init+0x18/0x20) from [<c00087d8>] (do_one_initcall+0x13c/0x164) [ 6.117257] [<c00087d8>] (do_one_initcall+0x13c/0x164) from [<c08199ac>] (kernel_init+0x100/0x130) [ 6.129287] [<c08199ac>] (kernel_init+0x100/0x130) from [<c000e9c4>] (kernel_thread_exit+0x0/0x8) [ 6.141229] ---[ end trace 1c932e9403793ab9 ]--- [ 6.147367] tegra-i2c tegra-i2c.0: i2c transfer timed out, addr 0x0068, data 0x00 [ 6.157896] rtc-ds1307: probe of 0-0068 failed with error -5 [ 6.165410] using rtc device, tegra_rtc, for alarms [ 6.170178] tegra_rtc tegra_rtc: rtc core: registered tegra_rtc as rtc0 [ 6.179905] tegra_rtc tegra_rtc: Tegra internal Real Time Clock [ 6.190324] rtc_tps6591x rtc_tps6591x.0: RTC Time : 1/1/2000 0:1:36 [ 6.200666] tps6591x 4-002d: [ 6.200670] getting alarm time:: [ 6.209689] rtc_tps6591x rtc_tps6591x.0: RTC Time : 1/1/2000 0:0:0 [ 6.217359] rtc_tps6591x rtc_tps6591x.0: rtc core: registered rtc_tps6591x as rtc1 [ 6.235032] rtc_tps6591x rtc_tps6591x.0: RTC Time : 1/1/2000 0:1:36 [ 6.331609] i2c /dev entries driver [ 6.336913] lirc_dev: IR Remote Control driver registered, major 242 [ 6.344670] IR NEC protocol handler initialized [ 6.350462] IR RC5(x) protocol handler initialized [ 6.356496] IR RC6 protocol handler initialized [ 6.362239] IR JVC protocol handler initialized [ 6.367924] IR Sony protocol handler initialized [ 6.373671] IR RC5 (streamzap) protocol handler initialized [ 6.380353] IR MCE Keyboard/mouse protocol handler initialized [ 6.387283] IR LIRC bridge handler initialized [ 6.393283] Linux video capture interface: v2.00 [ 6.399464] usbcore: registered new interface driver uvcvideo [ 6.406549] USB Video Class driver (1.1.1) [ 6.412108] trpc_sema_init: registered misc dev 10:55 [ 6.418554] trpc_node_register: Adding 'local' to node list [ 6.426591] nvavp nvavp: allocated IOVM at ff00000 for AVP os [ 6.449157] tegra_wdt tegra_wdt.0: tegra_wdt_probe done [ 6.455831] tegra_wdt tegra_wdt.1: tegra_wdt_probe done [ 6.462475] tegra_wdt tegra_wdt.2: tegra_wdt_probe done [ 6.468936] Bluetooth: HCI UART driver ver 2.2 [ 6.474593] Bluetooth: HCI H4 protocol initialized [ 6.480554] Bluetooth: HCILL protocol initialized [ 6.486426] Bluetooth: BlueSleep Mode Driver Ver 1.1 [ 6.492922] cpuidle: using governor ladder [ 6.498468] cpuidle: using governor menu [ 6.503487] sdhci: Secure Digital Host Controller Interface driver [ 6.510735] sdhci: Copyright(c) Pierre Ossman [ 6.516139] sdhci-pltfm: SDHCI platform and OF driver helper [ 6.522866] sdhci_tegra_init+ ##### [ 6.527518] sdhci-tegra sdhci-tegra.3: Error: tegra3 io dpd not supported for sdhci-tegra.3 [ 6.539131] mmc0: Invalid maximum block size, assuming 512 bytes [ 6.546346] mmc0: no vmmc regulator found [ 6.554790] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA [ 6.564561] Failed gpio lp0 enable for irq=395, error=-22 [ 6.571197] sdhci-tegra sdhci-tegra.2: SD card wake-up event registrationfailed with eroor: -22 [ 6.571210] Unable to handle kernel NULL pointer dereference at virtual address 00000028 [ 6.571220] pgd = c0004000 [ 6.571226] [00000028] *pgd=00000000 [ 6.571237] Internal error: Oops: 805 [#1] PREEMPT SMP [ 6.571244] Modules linked in: [ 6.571254] CPU: 1 Tainted: G W (3.1.10-2.7.4+g7753763 #1)"irq/395-mmc1" (82) is an active IRQ thread (irq 395) [ 7.821407] mmc1: Invalid maximum block size, assuming 512 bytes [ 7.830863] mmc1: no vmmc regulator found [ 7.840669] Registered led device: mmc1:: [ 7.853466] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA [ 7.865533] Failed gpio lp0 enable for irq=453, error=-22 [ 7.874324] sdhci-tegra sdhci-tegra.0: SD card wake-up event registrationfailed with eroor: -22 [ 7.887732] sdhci-tegra sdhci-tegra.0: vddio_sdmmc regulator not found: -19.Assuming vddio_sdmmc is not required. [ 7.900758] sdhci-tegra sdhci-tegra.0: vddio_sd_slot regulator not found: -19. Assuming vddio_sd_slot is not required. [ 7.914192] sdhci-tegra sdhci-tegra.0: Error: tegra3 io dpd not supported for sdhci-tegra.0 [ 7.926248] mmc2: Invalid maximum block size, assuming 512 bytes [ 7.933622] mmc2: no vmmc regulator found [ 7.940004] Registered led device: mmc2:: [ 7.947482] [mmc]:mmc_decode_cid:123 cid.prv 0x10 [ 7.947492] mmc2: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA [ 7.947543] sdhci_tegra_init- ##### [ 7.947642] Registered led device: SATA1_ACT_N [ 7.947747] Registered led device: PWM3 [ 7.947792] Registered led device: PWM2 [ 7.947837] Registered led device: PWM1 [ 7.949698] tegra-se tegra-se: tegra_se_probe: complete [ 7.950266] usbcore: registered new interface driver usbhid [ 7.950272] usbhid: USB HID core driver [ 7.953784] stmpe-adc stmpe-adc.1: Initialized [ 8.023552] [mmc]:mmc_read_ext_csd:297 ext_csd.sectors 0x72c000 prod_name Q2J54A BOOT_MULTI 0x80 [ 8.043411] mmc0: new high speed DDR MMC card at address 0001 [ 8.050533] mmcblk0: mmc0:0001 Q2J54A 3.58 GiB [ 8.056287] mmcblk0boot0: mmc0:0001 Q2J54A partition 1 16.0 MiB [ 8.063396] mmcblk0boot1: mmc0:0001 Q2J54A partition 2 16.0 MiB [ 8.071246] mmcblk0: p1 p2 [ 8.077124] mmcblk0boot1: unknown partition table [ 8.084730] mmcblk0boot0: unknown partition table [ 8.090534] [mmc]:mmc_rescan_try_freq:2119 mmc0: eMMC completed [ 8.451593] HDMI status: Codec=3 Pin=5 Presence_Detect=0 ELD_Valid=0 [ 8.493013] usbcore: registered new interface driver snd-usb-audio [ 8.539071] sgtl5000 4-000a: Failed to get supply 'VDDD': -19 [ 8.546988] print_constraints: 4-000a: 850 <--> 1600 mV at 1200 mV normal [ 8.581805] sgtl5000 4-000a: Using internal LDO instead of VDDD [ 8.606456] sgtl5000 4-000a: sgtl5000 revision 17 [ 8.621399] asoc: sgtl5000 <-> tegra30-i2s.2 mapping ok [ 8.629098] asoc: dit-hifi <-> tegra30-spdif mapping ok [ 8.637495] ALSA device list: [ 8.671594] #0: apalis_t30-sgtl5000 [ 8.677222] #1: HDA NVIDIA Tegra at 0x70038000 irq 113 [ 8.691687] oprofile: hardware counters not available [ 8.698724] oprofile: using timer interrupt. [ 8.711334] GACT probability NOT on [ 8.716807] Mirror/redirect action on [ 8.722491] u32 classifier [ 8.726982] Actions configured [ 8.732150] Netfilter messages via NETLINK v0.30. [ 8.738685] nf_conntrack version 0.5.0 (15650 buckets, 62600 max) [ 8.777372] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 8.794552] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 8.805616] ip_tables: (C) 2000-2006 Netfilter Core Team [ 8.813179] arp_tables: (C) 2002 David S. Miller [ 8.819840] TCP cubic registered [ 8.825184] NET: Registered protocol family 10 [ 8.832874] Mobile IPv6 [ 8.837212] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 8.845209] NET: Registered protocol family 17 [ 8.851522] NET: Registered protocol family 15 [ 8.857726] can: controller area network core (rev 20090105 abi 8) [ 8.865822] NET: Registered protocol family 29 [ 8.872097] can: raw protocol (rev 20090105) [ 8.878169] can: broadcast manager protocol (rev 20090105 t) [ 8.885838] Bluetooth: RFCOMM TTY layer initialized [ 8.892619] Bluetooth: RFCOMM socket layer initialized [ 8.899588] Bluetooth: RFCOMM ver 1.11 [ 8.905126] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 8.912262] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 8.920130] 8021q: 802.1Q VLAN Support v1.8 [ 8.926206] Registering the dns_resolver key type [ 8.932857] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [ 8.944436] Registering SWP/SWPB emulation handler [ 8.965565] Disabling clocks left on by bootloader: [ 8.972412] audio_2x [ 8.976761] audio4_2x [ 8.981097] audio3_2x [ 8.985388] audio2_2x [ 8.989609] audio1_2x [ 8.993795] audio0_2x [ 8.997921] audio [ 9.001645] audio4 [ 9.005384] audio3 [ 9.009120] audio2 [ 9.012862] audio1 [ 9.016455] audio0 [ 9.020026] dsi2-fixed [ 9.023898] dsi1-fixed [ 9.027694] uarta [ 9.031007] i2c2-fast [ 9.034674] nor [ 9.037759] bsev [ 9.040873] bsea [ 9.043951] fuse_burn [ 9.047407] cclk_lp [ 9.050591] pll_x_out0 [ 9.053972] pll_p_out2 [ 9.057271] pll_c_out1 [ 9.060511] pll_m_out1 [ 9.063806] CPU rate: 620 MHz [ 9.067620] tegra_fuse_program_init: no vdd_fuse. fuse write disabled [ 9.074929] DVFS: Got RTC device name:rtc0 [ 9.079895] tegra_dvfs: vdd_cpu: stats above 1237 mV will be squashed [ 9.090404] tegra3_dvfs: minimum cap.emc rate 800000000 requires 1300 mV [ 9.097320] tegra dvfs: tegra sysfs cap interface is initialized [ 9.106147] tegra_actmon.emc: Completed initialization (0) [ 9.112327] tegra_actmon.avp: Completed initialization (0) [ 9.119299] registered taskstats version 1 [ 9.124261] regulator_init_complete: tps6591x_LDO_5: disabling [ 9.131463] input: gpio-keys as /devices/platform/gpio-keys.0/input/input1 [ 9.139237] tegra_rtc tegra_rtc: setting system clock to 1970-01-01 00:00:13 UTC (13) [ 9.153706] kjournald starting. Commit interval 5 seconds [ 9.153774] EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode [ 9.153802] VFS: Mounted root (ext3 filesystem) readonly on device 179:2. [ 9.155046] devtmpfs: mounted [ 9.269509] systemd[1]: System time before build time, advancing clock. [ 9.552074] systemd[1]: systemd 230 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS -ACL -XZ +LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD +IDN) [ 9.578664] systemd[1]: Detected architecture arm. Welcome to [1;35mThe ??ngstr??m Distribution v2016.12[0m! [ 9.603314] systemd[1]: Set hostname to <apalis-t30>. [ 9.614444] systemd[1]: Initializing machine ID from random generator. [ 9.624439] systemd[1]: Installed transient /etc/machine-id file. [ 10.037236] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [[0;32m OK [0m] Started Forward Password Requests to Wall Directory Watch. [ 10.072189] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [[0;32m OK [0m] Listening on /dev/initctl Compatibility Named Pipe. [ 10.102768] systemd[1]: Created slice System Slice. [[0;32m OK [0m] Created slice System Slice. [ 10.132356] systemd[1]: Created slice system-getty.slice. [[0;32m OK [0m] Created slice system-getty.slice. [ 10.162285] systemd[1]: Created slice system-serial\x2dgetty.slice. [[0;32m OK [0m] Created slice system-serial\x2dgetty.slice. [ 10.192178] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [[0;32m OK [0m] Started Dispatch Password Requests to Console Directory Watch. [ 10.221857] systemd[1]: Reached target Paths. [[0;32m OK [0m] Reached target Paths. [ 10.241848] systemd[1]: Reached target Remote File Systems. [[0;32m OK [0m] Reached target Remote File Systems. [ 10.272272] systemd[1]: Listening on Network Service Netlink Socket. [[0;32m OK [0m] Listening on Network Service Netlink Socket. [ 10.302188] systemd[1]: Created slice User and Session Slice. [[0;32m OK [0m] Created slice User and Session Slice. [ 10.332138] systemd[1]: Listening on udev Control Socket. [[0;32m OK [0m] Listening on udev Control Socket. [ 10.362086] systemd[1]: Listening on Journal Socket (/dev/log). [[0;32m OK [0m] Listening on Journal Socket (/dev/log). [ 10.391864] systemd[1]: Reached target Slices. [[0;32m OK [0m] Reached target Slices. [ 10.412048] systemd[1]: Listening on udev Kernel Socket. [[0;32m OK [0m] Listening on udev Kernel Socket. [ 10.442135] systemd[1]: Listening on Journal Socket. [[0;32m OK [0m] Listening on Journal Socket. [ 10.467730] systemd[1]: Starting Apply Kernel Variables... Starting Apply Kernel Variables... [ 10.495236] systemd[1]: Starting Journal Service... Starting Journal Service... [ 10.526721] systemd[1]: Starting File System Check on Root Device... [ 10.528427] systemd-journald[116]: Failed to register hostname fd in event loop, ignoring: Operation not permitted Starting File System Check on Root Device... [ 10.577444] systemd[1]: Mounting FUSE Control File System... Mounting FUSE Control File System... [ 10.596521] systemd[1]: Starting Setup Virtual Console... Starting Setup Virtual Console... [ 10.618574] systemd[1]: Mounting Debug File System... Mounting Debug File System... [ 10.631098] systemd[1]: Reached target Swap. [[0;32m OK [0m] Reached target Swap. [ 10.648581] systemd[1]: Mounting Temporary Directory... Mounting Temporary Directory... [ 10.670307] systemd[1]: Mounted FUSE Control File System. [[0;32m OK [0m] [ 10.680564] systemd[1]: Mounted Debug File System. Mounted FUSE Control File System. [[0;32m OK [0m] Mounted Debug File System. [ 10.696406] systemd[1]: Mounted Temporary Directory. [[0;32m OK [0m] Mounted Temporary Directory. [ 10.781997] systemd[1]: Started Apply Kernel Variables. [[0;32m OK [0m] Started Apply Kernel Variables. [ 10.971904] systemd[1]: Started File System Check on Root Device. [[0;32m OK [0m] Started File System Check on Root Device. [ 11.131949] systemd[1]: Started Setup Virtual Console. [[0;32m OK [0m] Started Setup Virtual Console. [ 11.153804] systemd[1]: Started Journal Service. [[0;32m OK [0m] Started Journal Service. Starting Remount Root and Kernel File Systems... [ 11.220503] EXT3-fs (mmcblk0p2): using internal journal [[0;32m OK [0m] Started Remount Root and Kernel File Systems. Starting Create System Users... Starting Rebuild Hardware Database... Starting Flush Journal to Persistent Storage... [[0;32m OK [0m] Started Create System Users. Starting Create Static Device Nodes in /dev... [ 11.487975] systemd-journald[116]: Received request to flush runtime journal from PID 1 [[0;32m OK [0m] Started Create Static Device Nodes in /dev. Starting udev Kernel Device Manager... [[0;32m OK [0m] Reached target Local File Systems (Pre). Mounting /var/volatile... [[0;32m OK [0m] Mounted /var/volatile. Starting Load/Save Random Seed... [[0;32m OK [0m] Reached target Local File Systems. Starting Commit a transient machine-id on disk... Starting Rebuild Journal Catalog... Starting Rebuild Dynamic Linker Cache... [[0;32m OK [0m] Started udev Kernel Device Manager. [[0;32m OK [0m] Started Flush Journal to Persistent Storage. [[0;32m OK [0m] Started Load/Save Random Seed. [[0;1;31mFAILED[0m] Failed to start Commit a transient machine-id on disk. See 'systemctl status systemd-machine-id-commit.service'#1 [ 17.983294] tegradc tegradc.1: switching framebuffer to 640x480 [ 17.983306] tegradc tegradc.1: using mode 640x480 pclk=23750000 href=1 vref=1 .---O---. | | .-. o o | | |-----.-----.-----.| | .----..-----.-----. | | | __ | ---'| '--.| .-'| | | | | | | | |--- || --'| | | ' | | | | '---'---'--'--'--. |-----''----''--' '-----'-'-'-' -' | '---' The Angstrom Distribution apalis-t30 ttyS0 Angstrom v2016.12 - Kernel Apalis-T30_LXDE-Image 2.7b4 20171005 apalis-t30 login: <00008040><11:32:30.774> Serial: SerialInput End <00005110><11:32:30.774> Info: BootTest Passed. OS booted in 23[s] <00008000><11:32:30.774> Info: Test Passed <00000130><11:32:30.774> Info: Total Test Time: 178[s]
